PcBytes wrote on 2024-06-01, 21:26:
Ozzuneoj wrote on 2024-06-01, 20:57:Not a bad selection of hardware! […]
PcBytes wrote on 2024-05-30, 17:10:'ight, since you quoted me, I figured I'd reveal the cards first. I'll put up the mainboards later tonight (hopefully).
https:// […]
Top:
- Inno3d FX 5500 128MB
- Genius CMI 8738 PCI soundcard
- Palit TNT2 M64 32MB (that golden PCB lookin' sweet 😀 )
- Supergrace S3 Trio 3D/2X AGP
- Sparkle GF4 MX440-8X 64MB
- ATI Rage LT Pro AGP
Middle:
- "ST Labs" Geforce 2 MX
- Sapphire Radeon 9250
- Powercolor S3 Trio 3D AGP
- Dell OEM adapter - laptop IDE format to standard PATA
- a few I/O shields
Bottom row:
- unknown MX440-8X w/ DVI
- PCChips ATX form card w/o cable
- ASUS USB/MIR form card
- Sparkle 8400GS Rev II 512MB (needs a HSF 😀 )
- Sparkle GF4 MX4000
- PCChips ATX form card w/ cable
- "MS" Radeon X300SE
- ALi M5273 USB card
- Diamond Multimedia S3 Savage 4 SDRAM
- Winfast A340 128MB - FX5200
- Sound Blaster Live 5.1 Digital SB0220
EDIT:
- ASUS P5B-VM + C2D E4400
- MSI GF615M-P33 + some AM3 Sempron
- ASUS M4N68T-M + Athlon II X2 250
- ECS P6STP-FL + VIA C3 "Ezra" 800A
One thing though... I think that green card with the silver heatsink in the center is an FX5200, rather than an MX4000 (Google search results seem a bit inconsistent and Sparkle seems to have used SP7310 for different cards). With all 8 memory chips on one side, it is probably a 128bit card, which isn't common for an MX4000... they are often only 32bit (blegh!).
Anyway, if the caps are good a 128bit 5200 is a decent card for a Win9x build and you don't have to worry about it having a bad fan since it is passive. 😀
It's a MX4000 though. 128bit somehow, according to their label.
Oh wow, my mistake, that's a pretty unusual card for sure!
GPU-Zoo has a very comprehensive database of card specs, and it looks like only 7 out of around 40 MX4000 cards listed have a 128bit interface, including yours which will probably have 166Mhz (333 DDR) memory.
... it's really sad that EVGA even sold a 32bit model with only 133Mhz (266 DDR) memory. That is 25% less actual memory bandwidth than a Geforce2 MX200. 🤢
... so yeah, as far as MX4000s go, yours is actually pretty decent.
