Reply 53460 of 57724, by BitWrangler
Hmmm, the proverbial radar picked up an E-mu SoundEngine for a less than crazy price... that's the easy bit done, now the figuring out if I actually want it or can use it. 🤣
Reply 53461 of 57724, by giantenemycat
Ozzuneoj wrote on 2024-07-04, 04:25:
Absolutely, they make great cards for most games made between 1998 and 2003. I've never overclocked one myself, but I used a 9600 Pro for a while back in the day and it was an excellent card (coming from a dead Ti 4400 and a terribly underpowered FX 5600 non-ultra that was sent as replacement). Getting anywhere in that performance range on a budget would be awesome for a P4 build. 😀
I never had a Pentium 4. This is going to be like a hypothetical "what if?" build where instead of the junkbox my family got in 2005, we got a hand-me-down, fairly capable but ageing 2002 P4 around the same time instead.
I'm going to limit myself to a 533MHz FSB board so there's room for an upgrade, without going crazy. Starting out with a low-ish clocked 400MHz FSB Northwood, then I'll drop in a 533MHz 3.06 GHz Northwood HT. Any ideas on what AGP card from 2003-2007 would go well when I do that upgrade?
Reply 53462 of 57724, by acl
giantenemycat wrote on 2024-07-04, 07:58:
AGP support stops at GeForce 7900 / 7950 series for nvidia. (bridged PCIe to AGP cards) last native ones were in the 6800 series i think. It was supported longer by ATi (up to HD4000 iirc).
Northwood 3.06 HT is from late 2002. As you suggested, a 9700/9800 would be period correct but harder to find (and you should stay away from the 128bit 9800 "pro"). A 9600XT should be easy to find. X800/850 other than XT/PE can still be found also quite easily. X1900 and newer is probably a bit "modern" for a Northwood. You can also try to find a Radeon 9500 (the regular one, not the pro) and softmod it into a 9700 as suggested by Ozzuneoj. The 9500 are not that hard to find but only buy tested ones with no artifacts etc.. because r300 cards tend to cook themselves. Also upgrading the cooling is advised if you're using one for gaming.
The fakes 9800 "pro" 128bit i mentioned above are not that awful. They are just not "real 9800 pro". In the end, performances are very similar to a real 9700. So if you find one for a good price, that might be a good deal after all.
Generally nVidia cards from that era tends to be more expensive than ATi ones.
I'm not recommending nVidia FX series if you're planning to use the system for real (the price is high for anything above Fx5700 because they are collectible, but performance is not great for DX9). 6600 is cheap, but not very original. 6800 can be expensive. 7600 AGP can be found easily but also not very original. 79XX AGP are not common.
Around 2002 there is also Matrox Parhelia. a DX8 card. Performance is around a GeForce4 Ti4400. Harder to find but definitely original.
Reply 53463 of 57724, by appiah4
I traded for something today. A friend needed a Slot-1 Coppermine and I had a 550 I could giveaway. He gave me back this in return.
The attachment Intel Pentium III 533B.jpg is no longer available
I accepted the trade because I never knew there were actual 133MHz Katmai Slot-1 parts. I am still kind of dumbfounded.. What platform did Intel make these for? i820? I thought that never got a mainstream release worth mentioning, so they made CPUs for VIA's Apollo Pro133 effectively? That is incredibly weird and ironic if true..
And the question is, why? I guess Athlon was busting their balls in 1999 and this was a desparation product that just got pushed out?
Regardless, it was a curiosity I wanted in my collection and I got it. I don't think I even have an Apollo Pro133 board I can test it on, funnily enough.
Reply 53464 of 57724, by Munx
Got myself this beautiful boy:
The attachment 20240704_152120.jpg is no longer available
A "graphite" Mac pro G4! Bottom of the case had some very light corrosion, one of the clips holding the side panel was broken. Looks alright a few hours of disassembly and cleaning. Booted into a confused Mac after a battery swap (both drives dont seem to be bootable), so I'll have to figure out the best OS for it later - 9.2 or 10.4 or both seem like good choices right now.
This is how it was shipped to me BTW, so I'm glad its just a broken panel clip:
The attachment 2024-07-04_15-28.png is no longer available
Old style Motherboard and included dial-up indicates that this was the initial 400MHz model. In 2003 someone added a 1000MHz CPU, SATA and GeForce 4600 cards. USB card from 2009. 1.5GB of RAM.
The attachment 20240704_152143.jpg is no longer available
The attachment 20240704_152226.jpg is no longer available
The attachment 20240704_152154.jpg is no longer available
Not a common this to find around where I live so I'm pretty stoked.
My builds!
The Underdog - The budget K6
Reply 53465 of 57724, by myne
appiah4 wrote on 2024-07-04, 12:26:
I traded for something today. A friend needed a Slot-1 Coppermine and I had a 550 I could giveaway. He gave me back this in re […]
There were all sorts of server boards - some with their own custom chipsets which may have been certified 133 before Intel got round to it.
Iirc soyo, and/or tyan had their own chipsets.
Basically, odds are, some big oem asked for it.
I built:
Reply 53466 of 57724, by BitWrangler
myne wrote on 2024-07-04, 13:45:
It's got a Dell part number 2492U so I'm gonna guess HP 🤣 ... no but just quick lazy searching I'm not managing to track that back to which machines it was used in.
Reply 53467 of 57724, by Baleog
luckybob wrote on 2024-07-02, 20:46:
I wont a battle against a gold-scrapper! I also know ebay links are taboo, but I dont care: https://www.ebay.com/itm/235627579 […]
I wont a battle against a gold-scrapper! I also know ebay links are taboo, but I dont care: https://www.ebay.com/itm/235627579658
Some choice images if you dont want to click the ePay link: https://imgur.com/a/Vx4Ebms
All those MCA-cards! And the memory cards looks gorgeous, they must also have cost a fortune in the day. Good job saving them! Are the CPU-complexes are for the Model 95?
Mixed PCs - Midi racks - Micros and more
Reply 53468 of 57724, by giantenemycat
SCORE! Picked up this Philips 107E CRT with a mystery box Mesh PC locally. Turned out to be a Socket A system. Original booklet included showing purchase date of 2001, and detailing troubleshooting up to 2007 for some neat little history to it. Came with ME but was upgraded to XP at some point.
How much for the lot? £50.
The attachment sfg0.webp is no longer available
The attachment 17.jpg is no longer available
The attachment 2.webp is no longer available
Reply 53469 of 57724, by Ozzuneoj
... welp, apparently I now have an ELSA Gloria-XL on it's way to me. Seems like these are quite hard to come by these days and I caved under the pressure. 🤦
It's a monster of a card for 1997.
The attachment ELSA_GloriaXL1.jpg is no longer available
The attachment ELSA_GloriaXL2.jpg is no longer available
I am not 100% sure what I'll be able to use a 40MB Glint MX + Delta card for, but it will be fun to tinker with and the price was tolerable. 3DLabs advertised the Glint MX as being 2x to 5x the performance of the 500TX. Plus, the onboard Trio64V2/DX for DOS is pretty generous compared to the GD5420 that some other professional 3D cards were saddled with. As far as I can tell, this is the last high end 3DLabs card that was PCI... and apparently it supports 66Mhz PCI? The only way I'd probably be able to make use of that would be to overclock the PCI bus (if that counts), but it's cool nonetheless. 😀
Reply 53470 of 57724, by luckybob
I think i have one of these (or similar)... what makes it special? I've always figured a CAD card was pretty much worthless if you aren't doing CAD.
Also quiet a few MACs run 66mhz pci by default. So it might be cross platform capable.
Reply 53471 of 57724, by Ozzuneoj
luckybob wrote on 2024-07-04, 23:58:
Being honest: Once you've seen your 100th Voodoo or Geforce, they are a lot less interesting to collect since I will absolutely *never* be able to collect all the different minor variations of them. So, at some point I started collecting very early cards that could be used for 3D gaming or at least were advertised as such since there is a fairly limited number of them and they are obscure enough that they sometimes fly under the radar. Some are ridiculously rare and barely do anything, but finding them is pretty cool. The Glint series can apparently be used for games with the right driver + OS combination... with horrid performance I'm sure... but hey, it's probably way better than an S3 Virge, right? 🤣
Anyway, I remember seeing cards like this all the time a while back but for whatever reason they seem to be more valuable now and much harder to find, so I jumped on this one... mostly just to prevent myself from buying one at a higher price later. I will probably tinker with it for a while and then put it on display because it is super impressive looking with the dual heatsinks, S3 chip and Glint Delta... plus all that tasty RAM.
Reply 53472 of 57724, by H3nrik V!
There was also 600MHz slot-1 Katmais in 133 (the 600B)
Reply 53473 of 57724, by A001
Ithink I've found my new favourite board. For one euro, since it was supposed to not work at all, but frankly it does...
BIOS voltage readings are somewhat concerning as I'm using a modern high quality ATX power supply. Where should I probe with multimeter or are these W83977EF likely to provide inaccurate readings in BIOS? Fan speed wasn't detected either.
The attachment 922.jpg is no longer available
The attachment 924.jpg is no longer available
Reply 53474 of 57724, by chrismeyer6
A001 wrote on 2024-07-05, 14:55:
Ithink I've found my new favourite board. For one euro, since it was supposed to not work at all, but frankly it does... BIOS v […]
I wouldn't be all that worried software reported voltage readings are very inaccurate.
Reply 53475 of 57724, by BitWrangler
On a bare board test, probably not pulling enough watts for the PSU to stabilise.
Reply 53476 of 57724, by A001
Would make sense if I didn't have one spinning rust there. Readings won't change at all when I swap the 333Mhz celery for a 500Mhz Katmai.
Reply 53478 of 57724, by zuldan
Shponglefan wrote on 2024-07-05, 23:30:
Picked up a couple systems from thrift stores recently.
I'm not normally a huge fan of 2000's style of cases, but I do appreciate them in the traditional beige.
Both are beautiful. Have you got any gear planned to go in them?
I’m so jealous you can walk into a store and grab retro gear.
Reply 53479 of 57724, by Shponglefan
zuldan wrote on 2024-07-06, 00:30:
I'm thinking of putting my Pentium 4 multi-OS build into the Antec case.
The other case, I'm not sure yet. Maybe a Pentium III build?
It's a numbers game. I've probably done between 5o to 100 visits to thrift stores this year alone.
Rarely is there any hardware worth getting, but once in awhile I get lucky. Mostly I'm just after old computer games.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
