Quake2 + Acebot for DOSBox (128mb)
Reply 541 of 862, by Maraakate
Here is the Voodoo 5 lib you gave me previously. you may be able to link with that as well for me to test
    libglide3x.7z
    112.67 KiB
    49 downloads
Reply 544 of 862, by __ggorts
Headers and libraries for glide3/cvg. However, only glide lib has strings for "voodoo 2". Perhaps mesa3d requires an additional definition line, but it's worth attempting to try the attached.
I'll wait before replacing files with V5 lib. It may require headers which I don't have for sure, but I can check another archive to verify.
    mesa-cvg-devpmt.zip
    885.98 KiB
    48 downloads
    mesa cvg devpmt
Reply 550 of 862, by Maraakate
Oh my god. It's like playing it in windows. It's insane.
The only complaint with any of it is that vsync seems to be stuck ON. Setting gl_swapinterval=0 makes no difference.
Reply 553 of 862, by Maraakate
Yup. I'm trying to do some small changes to make a few different make files and then I'll post the voodoo 5 file shortly for others to check out. I want to make sure curl and gamespy still work
Reply 554 of 862, by __ggorts
I think the attached is the correct patch. But please verify that the pointer recasts look ok. The asm change should be fine and the patch is for djgpp205 I believe. I didn't yet ensure x86 is active or the swapinterval issue.
    glide3x_dj205.diff
    13.53 KiB
    53 downloads
    glide3 v5 patch
Reply 555 of 862, by __ggorts
I think the attached glide3 lib for v5 is already updated. I may have rebuilt it a while ago, but we can research the swapinterval issue (I think I recall something in a readme in mesa, but not sure). However, I have to verify whether x86 was used, although I think it wasn't.
Edit: trying x86, but there are also mmx/sse versions to try. 😀
    glide3-v5.7z
    112.66 KiB
    43 downloads
    glide3 v5 updated?
Reply 557 of 862, by Maraakate
Here is my first go at Voodoo 5, with the original code. Vid gamma doesn't work either afaict. You'll have to use gl_modulate. A value of 2.5-3.0 seems ok on CRT monitors (which if you're using voodoos in real life it better be on a real CRT!)
I also forgot to mention that you don't need updated gamex86.dxe's I found out. You can use the latest ones available from the q2dos site and play it all OK.
    q2fx_v5.7z
    1005.71 KiB
    47 downloads
