Reply 55340 of 58555, by kwyjibo
Some of you may have noticed this item on eBay, now it is mine:
Seller picture's:
The attachment s-l1600.webp is no longer available
I was all sold out just because is part of the Vectra XU line, but I also noticed this:
The attachment s-l1600(2).webp is no longer available
Once received I can see I did the right thing 😌
The attachment PXL_20241129_153208719.jpg is no longer available
The attachment PXL_20241129_152937973.jpg is no longer available
Looking at the desktop it seems possible this was used to produce music...
The attachment s-l1600 (1).webp is no longer available
What do you think?
Reply 55341 of 58555, by dominusprog
myne wrote on 2024-11-30, 14:42:
Looks like it'll fit 4 if you remove 2x30s
True, but I don't have a desoldering gun.
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 55342 of 58555, by lolo799
kwyjibo wrote on 2024-11-30, 14:48:
Some of you may have noticed this item on eBay, now it is mine: […]
Seller picture's:
What do you think?
4 modded Ct1920 in one machine?
What does the AWE control panel shows?
Reply 55343 of 58555, by myne
dominusprog wrote on 2024-11-30, 15:02:
Iron +wick +low melt
I built:
Reply 55344 of 58555, by Shponglefan
myne wrote on 2024-11-30, 15:20:
For removing memory sockets? That's a bit ambitious.
A desoldering gun + hot air is going to be the safest and cleanest way to remove things with lots of pins like sockets.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 55345 of 58555, by Ujeen
Some of you may have noticed this item on eBay, now it is mine…
What do you think?
I guess I saw it , but not hundred percent sure 😀 I love this kind of form-factor when you can put CRT on the top
In meantime I acquired these three still sealed. I haven’t unboxed them yet. Radeon and Zalman are gonna be part of my Socket-A based build.
Not sure why I bought the PCI-E sound card though… it was just cheap and sealed. Still I have no application for it. Probably will just leave it sealed.
Reply 55346 of 58555, by smtkr
the AIW is a really cool pickup
Reply 55347 of 58555, by myne
Shponglefan wrote on 2024-11-30, 15:44:
They're 30 pin. All in a row.
Low melt the whole lot, and push.
Clean
I built:
Reply 55348 of 58555, by BitWrangler
I have done 30 pin back in the day with a Weller "wood burner" and a RadioShack bulb sucker, but I wouldn't fancy trying to clear the 72 pin holes with them.
Reply 55349 of 58555, by AGP4LIfe?
A couple of recent pickups.
Very cheap, 24$ + Shipping. GeForce 3 Ti 200 128MB Version ( Thanks Wes1262 for the find!) In perfect condition, overclocks to just above Ti 500 levels! 265/255 Core/Mem! ( Core might go higher,slider maxed out Riva Turner. ) Fantastic card.
And an MSI Ti-4800SE! Only has 3.6ns SGRAM, But overclocks very well from it's basic clocks.of 275/275 it was stable at 335 Core/345Memory! Decently over the Ti-4600/4800 default clocks!
The attachment PXL_20241201_031430960~3.jpg is no longer available
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 55350 of 58555, by dominusprog
Yes, that's the correct way. Besides, even if I own a desoldering gun and hot air station, I would practice on a dead board first. It doesn't worth the risk. In my opinion, 20MiB is far enough for a 486 build.
Reply 55351 of 58555, by Wes1262
Weird that nobody was bidding on that! I suppose it's because the Leadtek cards don't look like the reference counterparts so they are very easy to miss?
Reply 55352 of 58555, by PC@LIVE
Bought these, for a similar HW use, in reality they are chair feet 🪑, but the use I will make of them is different, they will go to the Antec case, of the originals there are only two left, at this point, I replace them all with these, they are made of hard plastic, but they will be fine, I have two alternatives, use the double-sided, or different screws, with a nut 🔩 at the other end.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
Reply 55353 of 58555, by mtest001
I just received a K6-2 plus 500 ACZ.
I am a bit anxious to put this on my (almost-super) Socket 7 mobo. I have read here that CPU running at speed over 300 MHz would result in voltage regulators overheating. I don't want to take the risk of damaging my motherboard...
The attachment 20241129_215732.jpg is no longer available
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB32 PnP + Sound Canvas SC-55ST = unlimited joy !
Reply 55354 of 58555, by myne
https://www.pcbway.com/project/shareproject/N … n_5c9fce55.html
Possible solution
I built:
Reply 55355 of 58555, by mtest001
Thanks. My motherboard, a Shuttle HOT-569, can do dual voltage so I probably do not need the device you mentioned, or perhaps I misunderstood what it is meant for.
Reply 55356 of 58555, by myne
If your existing vrm is not enough, then that is a viable replacement if you have the header.
I built:
Reply 55357 of 58555, by ChrisK
mtest001 wrote on 2024-12-02, 13:25:
This CPU is 18W 16W TDP (@2.0Vcore this is 9A 8A).
So if the board can run a K6-200 or 233 than it should have no probs with it.
Question is if it can run reliably with 83MHz FSB. If not then you may be stuck at 6 x 75MHz = 450MHz, further reducing the power required by the CPU.
Edit: Power values corrected. Looked at the 550MHz-version.
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 55358 of 58555, by mtest001
Good advice I'll keep it at 6x75 Mhz = 450 MHz to stay on the safe side. That should already be quite a boost compared to my current CPU (P200 MMX @ 225).
Reply 55359 of 58555, by Wes1262
- 8500LE works perfectly. it has one of the strangest configurations I've seen, 275/183.
- Radeon DDR 64mb 183/183, overclocks to 200/200 just fine, works perfectly. By the way Agp4Life, the one with the 06 bios I have was indeed 200/200.
- Geforce FX5700 Gainward works
- Radeon 7500 "LE" works, but it's 64 bits of disappointment
- Mx440 works. Radeon 9000 works.
- Elsa GF3 Gladiac 920 Black Edition............ doesn't work...... of course the one I truly wanted... because the universe clearly hates me.... hopefully one day I'll be able to fix these
- The two voodoos I got I haven't tested yet. Crossing fingers. Like twisting them. Multiple times. Like a rope. Rope fingers.
Overall I am happy. I am a long time 8500 and Ati aficionado so that was good.
