Reply 55900 of 59086, by Wes1262
Part 2
Reply 55901 of 59086, by Ozzuneoj
Aw man, he covered up the serial numbers. I was going to try to track him down based on the serial numbers of a 20 year old video card he bought second hand...
Wait! Did I just type that? I meant to think it silently in my evil brain.
... anyway! Nice find! You should put that in an overpowered PCI-E Windows 98SE build. 😁
Reply 55902 of 59086, by AGP4LIfe?
Wes1262 wrote on 2025-01-30, 14:06:
Sealed 6800u
Hit jackpot
That's a pretty sweet find! Unused too... incredible. I bet it was a STEAL! Nice work. (wrong interface tho 😉)
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 55903 of 59086, by PTherapist
Bought myself another 8-Bit Micro for my collection, a Tangerine Oric-1:
The attachment oric.jpg is no longer available
eBay purchase, -"sold as seen" / "untested", the usual bullshit.
The seller somehow neglected to mention that the case had all of it's screws missing and somebody had been inside and unscrewed the voltage regulator from it's heatsink. The nut that was supposed to hold it in place was missing and the washer was dangling precariously from the internal speaker, whilst the screw and heatsink were just swinging loose. It's a good job I didn't try to just power it on first without checking!
Reply 55904 of 59086, by BitWrangler
Ozzuneoj wrote on 2025-01-30, 14:34:
Heh. I have come across one or two instances in the past where special software suites or extra featured support stuff only available for download from the manufacturer if you provide serial number. So if you leave photos of your stuff showing serials, maybe your serial gets used, and manufacturer blocks it when it's been seen from 5 or 20 different places in the world or something. Rare thing probably for most hardware, but if it's something you particularly value like this, then no harm taking extra precautions.... Though things can get super shady in the collecting world too, someone filing a police theft report with your serials on, that either ain't gonna turn out right or be a bunch of hassle for nothing.
Reply 55905 of 59086, by Shagittarius
BitWrangler wrote on 2025-01-30, 18:58:
I doubt you can even redeem anything tied to a serial number of a 6800Ultra. I doubt the company maintains any active program for this.
Reply 55906 of 59086, by justin1985
I bought this plain looking PC on eBay for what seemed to be a very unusual case - it's MiniITX but with both full sized 5.25" and 3.5" drive bays ...
The attachment IMG20250130165523.jpg is no longer available
When I saw it I though it would be ideal for giving a VIA EPIA both an optical drive and a floppy/Gotek (via a USB adapter).
Of course, it turns out that the 3.5" bay doesn't have enough depth to take a floppy drive. I guess it was intended for card readers only. But perhaps a Gotek could be hidden away in the space meant for a 3.5" hard drive below the optical drive, with just the bezel and screen etc on longer wires? That's getting a bit extreme though isn't it ...
The board it came with is an interesting little system itself, a Biostar board with soldered on AMD FX9830, supplied with a 256Gb NVMe drive, installed with Win11, which seems pretty snappy. Would the APU work with XP?
Reply 55907 of 59086, by Duffman
justin1985 wrote on 2025-01-30, 23:06:
Try snappy driver installer, it found an XP driver for my E2-6110 APU, so it might work for you.
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 55908 of 59086, by Wes1262
you joke but that actually happened. someone found me with reverse image search and the card's serial number.
on some local marketplaces you can see my name, surname, location and the stuff i bought... not a good time.
plus stickers are copied for counterfeit cards, or so I heard
Reply 55910 of 59086, by PcBytes
From last Sunday, I almost forgot to mention another great PC (known by us Romanian VOGON-ers) I had snagged at that car boot sale - ICE Felix HC91. IIRC it's based on the Spectrum 48k.
Reply 55911 of 59086, by PcBytes
And a P2B-S arrived today.
Disregard the "LS" printing - they likely used the same board for S and LS.
Tested with Katmai 500MHz, Creative Annihilator II GTS 32S (thabks to @Robert B for the card!) and
Reply 55912 of 59086, by PARKE
PcBytes wrote on 2025-01-31, 13:59:
The 'S ' version has a yellow sticker over that location. If you have rev. 1.03 it may or will most likely support Coppermines.
Reply 55913 of 59086, by PcBytes
PARKE wrote on 2025-01-31, 14:46:
There is sticker residue right above the Rev 1.03 tag so it definitely is an -S (that and it obviously is missing the onboard LAN).
As for Coppermine support - that's another success, since it uses HIP6004BCB, which in theory goes as far as Tualatins working there.
Reply 55914 of 59086, by PARKE
They are very nice boards and fast. The only disadvantage is the limited fsb range (and the 133 setting is buggy) but I seem to remember that someone here on Vogons succeeded in replacing the chip.
sorry: edited
The attachment FSB.JPG is no longer available
Reply 55915 of 59086, by myne
Isc9250 does decent fsb clocks. 150iirc.
Softfsb should sort that out.
I built:
Reply 55916 of 59086, by PcBytes
Mine has a ICS9150
Reply 55917 of 59086, by myne
https://www.alldatasheet.com/datasheet-pdf/pd … ICS9150-08.html
I built:
Reply 55918 of 59086, by Kahenraz
Is the P2B-S/L wider than standard ATX? It has that L-shape to it.
Reply 55919 of 59086, by PcBytes
Kahenraz wrote on 2025-01-31, 17:15:
Ever so slightly. From what I can tell it'll fit in a normal case, with a bit of care of that L side.
myne wrote on 2025-01-31, 16:36:
According to the datasheet it seems to do 133. How well that would run, idk.
