Reply 560 of 965, by sergm
wrote:Excellent work on this release. Just been pumping an old game soundtrack (Hand of Fate) through it and it sounds fantastic! Just WOW!
Oh, thanks 😎
Honestly, there are a few things which still offend an ear. Like that in Zeliard capture I posted above. And similar thing breaks perfectness when listening to Dune Palace or Water Themes. And so on.
wrote:There seems to be a move on Windows towards XML in the user's AppData folder. What Reg key are you using?
The trend is clear. But Qt still uses the registry. The access keys are formed using "organization" and "application" names, as usual, i.e. "muntemu.org" and "Munt mt32emu-qt". So, the keys are:
HKEY_CURRENT_USER\Software\muntemu.org\Munt mt32emu-qt
and
HKEY_LOCAL_MACHINE\SOFTWARE\muntemu.org\Munt mt32emu-qt
The latter is a system-wide key. It can be used to setup some defaults for all the users (manually so far). Maybe, I'll add some system-wide setup options further.
