Reply 56820 of 58509, by Trashbytes
AGP4LIfe? wrote on 2025-05-21, 22:00:
Trashbytes wrote on 2025-05-21, 11:50:
Kahenraz wrote on 2025-05-21, 11:48:
I was watching this listing, but decided to let it go. I'm happy to see what it ended up in the hands of someone here on VOGONS. Good job. 💪
I wasn't sure if I was going to jump in, had been watching it shortly after it got listed .. but threw a bid at it in the last hour, honestly expected it to go for more than it did.
Nice! I hope it works for you! I didn't jump in because it smells dead, but maybe its just the crappy pictures that makes me feel that way.
It certainly needs some TLC and some screens of it working would have been good but I've seen worse work out of the mail.
Reply 56821 of 58509, by Kahenraz
I skipped on it because of the fans. They are probably difficult or impossible to replace. That would mean that the entire heatsink would have to be swapped out, necessitating a compatible replacement. It just makes things a little more complicated.
Reply 56822 of 58509, by AGP4LIfe?
Trashbytes wrote on 2024-09-25, 15:17:
AGP4LIfe? wrote on 2024-09-25, 14:28:
Trashbytes wrote on 2024-09-25, 08:28:
I have the ASUS AGP-V6800DDR Deluxe/64M which should be similar to this model. […]
Just had a closer look and mine is this one here
https://www.techpowerup.com/gpu-specs/asus-v6 … 00-deluxe.b1879 has the 3d glasses as well along with the video in/out stuff.
Nabbed it in 2022 for about 125 USD which is a good price for one of these cards.
Deluxe version with 64MB of SGRAM, Nice!! That is a great card. Beefy Chonker 256.
I had not seen a 64Mb DDR model before mine so its nice to see another in working order !
The 3d glasses are kinda cool too but more of a novelty rather than useful.
Do you have a picture of this card and its memories? I'm curious if its SGRAM or SDRAM!
Infineon or Samsung? Do you have the model number on the Ram chips?
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 56823 of 58509, by PcBytes
Good thing: I got a P2B-DS
Bad thing: It keeps resetting if I have two CPUs installed. It'll get as far as doing the usual beep then it automatically restarts. BIOS doesn't look retail (VMP in the Sign-On string instead of "ASUS P2B-DS ACPI BIOS Revision nnnn").
Other than that... couldn't get the P3B-F working. Bits und Bolts' videos didn't help either.
Reply 56824 of 58509, by Nexxen
PcBytes wrote on 2025-05-22, 16:35:
Is there any chip responsible for Vcore ref? Maybe the 2nd cpu adds a value that isn't recognized correctly.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 56825 of 58509, by devius
AGP4LIfe? wrote on 2025-05-22, 15:04:
Mine is SGRAM from Infineon in case that helps.
The attachment 04.123_03.jpg is no longer available
Reply 56826 of 58509, by amadeus777999
devius wrote on 2025-05-22, 17:28:
Are the SG-Rams slower than DDR ones?
Reply 56827 of 58509, by AGP4LIfe?
amadeus777999 wrote on 2025-05-22, 18:04:
SGRam is supposedly the better one,but the memory timings/latency's are mostly identical
Reply 56828 of 58509, by AGP4LIfe?
Is this the 64MB version or 32MB Version of the card?
Reply 56829 of 58509, by cansting
Arrived today 😁
Win98:
InWin A500 with Asus P2B, Pentium II 450, 512MB PC100, Creative 3D Blaster Annihilator Pro +Diamond Monster 3D II, YMF719E-S+ Diamond Monster Sound MX300
Win XP
Deepcool Tesseract with D875PBZ, P4 3.0 prescott, 2GB DDR400, Radeon HD2600pro
Reply 56830 of 58509, by AGP4LIfe?
cansting wrote on 2025-05-22, 19:50:
Arrived today 😁
That is quite the awesome combo!
Reply 56831 of 58509, by cansting
Thanks, took me a while to find it, ultimate 1999 combo 😂
Win98:
Win XP
Reply 56832 of 58509, by devius
AGP4LIfe? wrote on 2025-05-22, 18:08:
64MB with chips on both sides. It's the only one I have of the DDR model.
Reply 56833 of 58509, by AGP4LIfe?
devius wrote on 2025-05-22, 21:19:
Hmmm I'm confused becuase unless im reading the data sheet wrong these are 4MB chips x 8 on the card for a total of 32MB's of ram.
Reply 56834 of 58509, by Kittyboy
Collecting components for my new mATX build featuring my 2.5" Seagate 80GB IDE with adaptor, (see images). Curious to learn other members experiences using same/similar drive combos. I chose the smaller drive to lessen bulk and weight, but at the same time wanted to remain partially period authentic, plus I felt using an IDE may also help me avoid compatibility issues in particular circumstances?
Pentium III 1.4GHz-S (SL6BY), Asus TUV4X, Plextor 760A, ATI 9800 Pro, MS-DOS 6.22/Win98se dual boot
Reply 56835 of 58509, by Trashbytes
What you loose in bulk and weight you also lose in speed, these smaller drives are slower than their 3.5" brothers, this one is 5400 RPM.
But depending on what system its going into that may not be a huge issue.
Reply 56836 of 58509, by myne
I see zero reason to not use an SSD.
They're so damn cheap.
I built:
Reply 56837 of 58509, by PcBytes
True that. I got a 120GB Samsung 840EVO that I plan to use although IDK if I should use it on an Athlon XP or something older (like 440BX "high end" build, P2B-DS build if I get the board running, or a Tualatin 1133 OC build with either ABIT ST6R or MSI 815EPT Pro-R.)
Reply 56838 of 58509, by amadeus777999
AGP4LIfe? wrote on 2025-05-22, 18:07:
Interesting - I read an article where somebody compared sg and ddr versions of these "256er"-cards and the sg-based card was a bit slower.
Reply 56839 of 58509, by clownwolf
Got a Gainbery P120 Upgrade CPU for socket 4. While I am happy to have it, there's not much use-case for retro computing. In my opinion the point of using a Socket 4 is to use the P60 or P66 after all.
The attachment 20250523_025553.jpg is no longer available
