Got the SV 242 throttle (aka Flight Force Fire Control System) from InterAct and after ordering a couple PS/2 to AT (and vice versa) adapters tried it out.
Was amazed that the whole mixed AT/Gameport operation actually held, and even worked fine enough to power wireless PS/2+mouse combo receiver.
On the device itself it seems to offer interesting options: one can use it to directly assign keyboard keypresses to any of the throttle and connected joystick buttons,
including POV hat, but not primary fire button on a Thrustmaster compatible joystick. This can be changed anytime, and there seem to be 4 separate configurations for the bindings that can be cycled through any time and without any additional software.
Build however has not aged very well; the throttle depends on a "suction cup" to stay on the table, rather then weight, and it has a dial for throttle spring adjustment, which just does not feel "linear enough" after all the years and usage (I got used one). While I was only able to get hands on the Mega Zoom software online, I found it useless - or it just does not work very well on my PC, as one can do pretty much everything with the joystick itself, and then calibration you would do in the games anyway.
One small disappointment was that no apparent way to switch the throttle into "digital" mode was found (as in being able to assign key presses to extreme position of the throttle itself), which meant that the device's use was mostly confined to classic flight sims, as opposed to the more "arcadey" games and space sims, which as I understand, with notable exception of Descent, did not offer support for analog throttles back in the days.
So, to conclude, a nice device to introduce oneself to the exciting worlds of flight sims controls of old, but if I enjoy it enough, personally, will be on a look out for a WCS mk II, or something from CH to replace it.
GA-G41M-Combo G41/ICH7 - Core 2 Quad Q9550 - DDR3 1033 - Radeon RX570 - YMF744 (Cobra) - X3MB (Buran)
Beetle/M/i815+ICH2 - Celeron 566Mhz - Opti 924 (Typhoon Media)
