Reply 5960 of 30147, by brostenen
- l33t++
I created a fully working standard workbench installation on a CF card for my Amiga600. Just the standard, nothing like whdloader and other software. For this I used my Linux laptop, with FS-UAE emulator installed. Kickstart ROM 37.300 and Workbench 2.05 and a 32mb CF card. I ran into some quirks down the road, like not being able to access the CF card in the USB reader and stuff like that.
The procedure was somewhat like this:
- Install the emulator and set it up with kickrom and the four disks mounted.
- Blank the card, using disks tool in Linux.
- Edit the configuration file for FS-UAE to know that it need to use the IDE controller and what USB reader/drive.
- Set the ownership of the cardreader/card to the user logged in. (need to be done each time a card is inserted)
- When workbench is loaded from the floppy, then I copied the HD-ToolBox to ramdisk.
- Started up the toolbox from ramdisk and made it read info from the CF-Card.
- Exited the toolbox and "prepped" the CF card with the prep'-tool.
- Ran the Harddrive installer tool.
Had to boot from the boot-disk at first for the hdtoolbox program, and had to boot from the installer disk for the rest of the installation. I used the 32mb card, as my Amiga does not have kickrom 37.350. Only 37.300. So I can not go past 40mb drives. For this I have to upgrade my kickstart rom. Now I am only waiting for the 44-pin CF adaptor to arive, as I recieved the cable yesterday. 32mb is ok enough for me, as I am not going to store anything else, than tools/programs for disk image writing and documents written in a wordprocesssor.
