Reply 60 of 158, by Tevian
I'm actually working on a related side project to make a drop in replacement for the DM9368N HEX decoders. I posted that over on VCFED... Cuz I want to complicate my life... 😅
The attachment 1736575534873.jpeg is no longer available
https://forum.vcfed.org/index.php?threads/dm9 … design.1251311/
Reply 61 of 158, by H3nrik V!
Tevian wrote on 2025-01-14, 01:23:
I've always been a big fan of 45 degree mounted components - especially when it's for the sake of even having room for them! 😎
Reply 62 of 158, by Tevian
myne wrote on 2025-01-12, 04:24:
Any updates on this? […]
BTW what takes the most time with assembly?
If it's hand soldering every pin, a pre-heater plate and solder paste might do the job if it can get hot enough.
I made the attached too - which is probably too late to be useful to you, but you might wish it already existed before you started!
I see you posted some kind of script file. Although I appreciate your efforts, I don't know what it does or what software it goes to so I'm not inclined to run such code on my machine blindly.
Reply 63 of 158, by Tevian
H3nrik V! wrote on 2025-01-14, 07:16:
I'm still hammering out the best way to fit everything, which is outside of the scope of this post. For "reasons" I had to route a larger PIC and in doing so, I actually needed to go back to standard mounting orientations. The device will probably look something like this. I'll continue updating the VCFED forum post for this one.
The attachment BWDM9368N.png is no longer available
Reply 64 of 158, by Tevian
I got the preliminary V1.0 boards in the mail today! I should find time to build one this weekend. 😎
The attachment Backwards V1.0_3.jpg is no longer available
The attachment Backwards_V1.0_1.png is no longer available
The attachment Backwards_V1.0_2.png is no longer available
I feel good about the changes. And, unless someone points out a "MUST HAVE" feature, this will be the final revision. I will have to schedule the time, but now I will focus on the schematics and description for the GitHub page.
And... Here is a timelapse of the assembly of a V0.5 board. As I mentioned, my process isn't optimized and the total time is about 4 hours.
Go ahead and point out my clumsy mistakes, just remember this is a hobby of mine and not what I do for a living! 😶😁
(the hairy-armed guy doing PCB assembly) 🫣😂---> https://youtu.be/yVl_P7OsK4I
Reply 65 of 158, by myne
Probably silly thought, but how hard would it be to make it fully reversible?
Ie, slots on the current back, or front.
I figure all the slots would remain correct since they'd all flip 180*, but the sound and other chips would be backwards, so would need second footprints.
After all... It is project backwards ;p
I built:
Reply 66 of 158, by Tevian
myne wrote on 2025-01-15, 15:02:
Probably silly thought, but how hard would it be to make it fully reversible? Ie, slots on the current back, or front. I figure […]
I assume this is a poor attempt at humor. 😅 🤣
While the physical connectors would fit on the reverse side, along with the ATX power connector for that matter, that would invert all the routed connections! Absolutely meltdown! Reversing the connectors would require a complete rewire of the board which is not something I'm interested in downing! 🫣🫣
Reply 67 of 158, by Tevian
Wow! See, your comment short circuited my brain and I was only a few minutes out of bed...
The ISA connector could physically be reversed, but still melt down. The EISA and PCI wouldn't physically be reversible because of the pin alignment. Duh! 🤣
Reply 68 of 158, by myne
Fair enough. I was thinking a bit too much like all slots were just one pin to one pin, so flipping wouldn't change that, but I obviously forgot about power.
I built:
Reply 69 of 158, by Tevian
The time has come! I'm happy to say that Project Backwards has reached V1.0!! 🥳🥳🎆
The latest V1.0 boards are all working. The ONLY thing not working is the anti-pop circuit, but I'm not going to freak out. The system has a pop during power up, but it's no worse than my other ESS sound card. Once I exhaust the V1.0 boards, I might consider a V1.1 to fix that very small issue.
All related information will be on the GitHub. https://github.com/MagicPhase/Backwards-DIY-Backplane
The attachment Backwards_V1.0.jpg is no longer available
The attachment Dual system setup.jpg is no longer available
If you're interested in owning one, feel free to PM me. 😉
Thanks for putting up with my nonsense!
Reply 70 of 158, by myne
Good to see it in a case.
Is that atx or eatx?
Looks like you've got the 7th slot available still
I built:
Reply 71 of 158, by Tevian
It's a crappy 7 slot ATX bench platform. The big issue is the card slots aren't notched at the top making it impossible to install an SBC due to the VGA ports extending from the edge. I had to cut this one to make it work. I know I was saying "left-most" slot, but It's really only second from the left-most slot. There really isn't a mounting option for the left most slot unless I make the board larger again. I like the size as is.
Besides, the issue of both powering and access to the connections is an issue. Having an open slot or two will be needed for something like a custom slot shim that has things like sound output, joystick port, and possibly a 12V in for one of those Pico ATX power supplies. Loading a case with two power supplies isn't unheard of, but a setup like this will be a challenge to make work in a system already populated with a modern ITX board and its accessories.
Reply 72 of 158, by myne
Fair enough.
I built:
Reply 73 of 158, by Tevian
Okay... I was honestly confused when I added the second ATX mounting position to the backplane and I finally realized why it didn't mesh with what I said earlier.
It's simple and obvious but I only realized once I looked back at my main case over the ATX bench chassis. The backplane does in fact mount to the left-most slot on a 7-slot case! The confusion is that my cheapo bench chassis has... 8 slots! 🤣
So I was right initially, but there might be larger cases with an 8th slot out there. Either way, things turned out great and now I can sleep! 😂
The attachment 8 slot.jpg is no longer available
Reply 74 of 158, by myne
Lol
So it was eatx
I built:
Reply 75 of 158, by mbandalauk
Tevian wrote on 2025-01-27, 08:38:
I need one! I noticed you added a wavetable at the back of your backplane — is that an RPi Zero on an MT-32 Pi adapter? Did you design that yourself, or is it something that’s available to buy?
I have another question: I own a PC/104 PC104 PCM-3370 along with a slot adapter for it — the adapter is for ISA, of course. I think I could easily use your backplane with it. The PCM-3370 also supports the PC/104+ standard, which includes the 120-pin PCI connector. I was thinking about making an extension from that connector to one of the PCI slots on your backplane so I could use both the ISA and PCI capabilities of the PCM-3370.
Do you think that could work?
Reply 76 of 158, by mbandalauk
I also noticed that the wavetable header appears to be reversed. Most wavetable boards have the header positioned at the top, with pin 1 on the right. However, it seems that your backplane is designed for wavetables with the pin header at the bottom, also with pin 1 on the right. I haven’t seen any wavetable boards with the connector on the bottom edge, so this means boards like this one won’t work as-is — the header is literally backwards!
Reply 77 of 158, by Tevian
mbandalauk wrote on 2025-07-13, 20:22:
Ah, the wavetable header is a normal pinout, but simply upside-down! Any standard wavetable card will work as long as it clears the ATX power connector on the right side. The Wavetable cards I make work correctly on my ISA soundcards, so there shouldn't be an issue. This was done simply for the sake of a compact footprint.
Your're correct in that a wavetable card wouldn't work if a standard pin header is installed! The right-angle header allows for the wavetable card to be installed vertically, upside-down.
Reply 78 of 158, by Tevian
mbandalauk wrote on 2025-07-13, 09:19:
I need one! I noticed you added a wavetable at the back of your backplane — is that an RPi Zero on an MT-32 Pi adapter? Did you […]
The link for the adaptor is broken, so I can't see it. However, if it's a simple PC/104 to ISA, then it should work just fine. An adaptor to the PCI slots would work as well, I just don't know of any. An adaptor card with the EISA edge connector would be ideal since the PCI pins are there, but one would have to be made, I think. A flex ribbon connector to the PCI slots would also work, though... But, one would have to be made. If you do make such a connector, I'd be curious to see it.
I do have the Backplanes up on eBay, https://www.ebay.com/usr/tevianbusselle.
As far as the wavetable card, yes I did design them. It's a simple carrier card for a Rasp Pi Zero 2 with the DAC installed. I don't have them on eBay at the moment and only have a few prototypes handy. I still haven't ordered a final version of the PCB, and I'm not sure what kind of demand there is for it.
The attachment wavee.jpg is no longer available
Reply 79 of 158, by ajacocks
Thanks for all the hard work @Tevian! I just bought one of your backplanes.
- Alex
