Reply 60 of 61, by DustyShinigami
- Oldbie
DaveDDS wrote on Today, 01:01:I don't see why you couldn't - I've done it on 5.25" disks a few times - 3.5" seem more delicate and would be easier to damage. […]
DustyShinigami wrote on Yesterday, 17:33:Is it not possible to take a diskette out of it's case and put it into another? ...
Also, make sure you use the same case type as the original - there's an extra hole in 3.5" HD media that's not in DD media - that's how the FDC knows what
date rates it should try.
I tried it a few times with spare 3.5” disks and got the same result each time. 😕
Um, what’s HD, DD, and FDC? 😅 I’m not even sure what the original game disk uses.
I discovered the box of spares I ordered were all ‘corrupted’, or faulty, according to NFORMAT, save one or two, so I’ll need to order some more. Incidentally, what are the best brands? These were Maxwell, but they felt a bit cheap.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
