Recommend a PCI Sound Card for DOS
Reply 60 of 127, by Kamerat
dr.zeissler wrote:
That would be nice 😀 Thx!
Tried it out and think I had about the same results as you. Got sound FX from a couple of older games, Wolfenstein 3D, The Game: Winter Challenge and Space Quest IV (cache off), I think theese use single cycle DMA. In Doom, Descent and Epic Pinball I got no digitized sound. Sound card ran in TDMA mode.
YouTube channel
Reply 61 of 127, by dr.zeissler
Thank you!
The OPL-Emulation sound VERY! good to me and it seems to work for lots of dosgames, intros, demos, cracktros, but sfx/digisound seems to have much more issues, that should be a proboem according to the fast processors that are used on that board (S370>500Mhz).
Do you have a better solution for me? A better PCI-Card instead? This ESS was the best for me so far.
Reply 62 of 127, by Kamerat
dr.zeissler wrote:
Thank you!
For cards with good FM synth and working digitized sound there's the YMF7xx PCI cards running with the DSDMA TSR (can be a bit flaky, computer looses disk accsess when you exit a game sometimes, so you got to reboot).
Other options has bad and/or emulated FM synth, like the Sound Blaster PCI/Live!/Audigy, Ensoniq AudioPCI, Aureal Vortex and Forté Media FM801-AU.
YouTube channel
Reply 63 of 127, by Deksor
I didn't knew that it was flaky, I never had that problem (though I did'nt use that function that munch but every time I did, I did not encounter problems)
Reply 64 of 127, by Kamerat
It can have something to do with my setup, when in game it's stable, it's only when I quit the proble occurs. Last rig I had my YMF744 installed were an i965P based one.
YouTube channel
Reply 65 of 127, by Deksor
Mine has a BX chipset, maybe the BX chipset behaves better with this ?
Reply 66 of 127, by Kamerat
Yeah, I guess you run it without any TSR as the BX chipset support DDMA. 😀
YouTube channel
Reply 67 of 127, by Deksor
I'm using the SB_link connection, aka PC/PCI. (the DDMA works too though), but I still have to use the "setupds" program to initialize the card.
Oh I thought that you were saying that setupds was a tsr, now I understand X)
Reply 69 of 127, by Kamerat
dr.zeissler wrote:
I only have a YM744B, I do not own a YM724. I'll test these drivers for it. http://www.vogonsdrivers.com/getfile.php?fileid=693
Try this instead if that one lacks the DSDMA TSR.
    dsxgdos.exe
    2.13 MiB
    90 downloads
    Yamaha YMF7xx PCI DOS drivers with DSDMA TSR.
YouTube channel
Reply 70 of 127, by dr.zeissler
Thank you. I did some tests and the ym74x is a good card indeed, but the solo1 is much more compatible.
The dostools of the yamaha card need a tsr and that tsr needs emm386 loaded. on my machine no ems-window is possible, so I had to go for "noems" option. I ran into lot's a random shutdowns, hangs, reboots... I changed it back to the ess-solo1 but I have to admit, that the fm-sound is really crisp and clear on the yamaha! but none of the games that did not work with my solo1, did not work either with the ymf74x.
I put one just recently arrived dreamblaster-S2 on the solo1 and played some raptor with full general-midi music and sb-pro soundblaster sfx 😀 Very nice!
I did not get the Dreamblaster S2 to work within windows98se. I'll have to checkout the manual. There must be some tricks to get it work. If I install the old vxd-driver there is a "ess-dos-comptiblit entry". Within the base-adress 330 is already used by it. I think I will have to go for the WDM-Drivers.
Greetings
Doc
    DsSolo1.pdf
    776.74 KiB
    99 downloads
Reply 71 of 127, by dr.zeissler
Here is some stuff to test. Everything works nearly 100%, some minor issues are tolerated.
Software that has greater issues (not playing sound at all, stuttering gfx/scrollers, wrong colors, lock-ups are stored in _error)
The other software is a bit categorized. Very beautiful stuff.
The machine I use to test this is:
FSC SCOVERY XS S.370 PIII/600 FSB 133
MB D1215 ChipsetI810/i815 using the onboard gfx-chip (32MB via Bios)
ESS-SOLO1 PCI-Soundcard
ONLY HIMEM
Let me know what you think and please test your own PCI-Soundcards and GFX-Cards against this stuff.
Greatings
Doc
    MEDIA.ZIP
    4.36 MiB
    77 downloads
Reply 72 of 127, by dr.zeissler
Most later dosgames use a kind of "standard-sound-framework". Two major player seem to be "miles?" and " 3drealms?"
Games that use the "miles?" soundcard-setup work just fine with opl and digi-sfx, but the "3drealms?" soundcard-framework never works!
e.g.
WWF4 = miles = works just fine
DN3D,SW, BLOOD = 3drealms, no sound at all 🙁
I searched for patches of the soundframework for pci-soundcards, but I just found nothing 🙁
Does anyone have a suggestion for me?
(beside that there is a "tandy-driver" that perhaps can be used with a dac on lpt1 to get some sound out of the games)
Reply 73 of 127, by Kamerat
I guess you had a look at bristlehog's thread.
I don't know what game WWF4 is, but do you got sound FX in the game itself or only in the setup program? In my experience some games, like Warcraft II which also use Miles, you get sound FX in the setup program but not in the game itself with certain PCI sound card setups.
YouTube channel
Reply 74 of 127, by dr.zeissler
For DN3D the general-midi music works with my ess-solo1 and dreamblaster-s2 upgrade. But SFX does not work due to a reported DMA-Conflict,
but there is no real DMA-Conflict, it's only the problem of the "3D-Realms-Sound-engine" used in lot's of games combined with a PCI soundcard and a fast PIII-600.
For all games with that specific "sound-engine" neither setup, nor the game itself is working. I alway get a "DMA-Confict".
I tested the DN3DPCI-Soundcard-Fix on this, but this does not help for the reported DMA-Conflict 🙁
Reply 75 of 127, by Kamerat
Use a Windows port of Duke Nukem 3D or get a motherboard with VIA chipset.
YouTube channel
Reply 76 of 127, by dr.zeissler
Thx, this could be an option, but not for sw3dfx... (same sound-engine for dos and dosglide)
There are really lot's of dos-games with that specific sound-engine, perhaps a pci-soundcard-fix would be a BIG deal.
Reply 78 of 127, by dr.zeissler
ESS Solo1 does not require EMM386, but the SB-Part is not detected by some Dosgames, OPL Music is everywhere, that's really nice.
It would be a KILLER-PCI-SOUNDCARD if the SB-issues can be fixed in dos.
Reply 79 of 127, by dr.zeissler
by the way, the win-port seems to use the dos-sound-options so no digisound either 🙁
