Star Trek: A Final Unity on Windows XP
Reply 60 of 81, by Troi Tribble
Snover wrote:
That thread has absolutely nothing to do with DOSBox.
Ok, I thought it did. And I just noticed that that thread is locked and I CAN'T post on there, so I am sorry to say, that I will have to ask you: How do I get my sound on in the AFU game, and how do I fix the video so it runs smooth and NOT slow & choppy? Please advise. Thanks.
Reply 61 of 81, by wd
Rank DOSBox Author
DOSBox Author
That thread was locked beacuse, as noted there, only one topic is to be
created for a problem.
Now you've got something different, and this new problem is dosbox
related so you could post there (before you should look through various
postings that deal with sound configuration).
The soundblaster settings for dosbox are addr=220, irq=7, dma=1
which you must tell the game (installer, setup.exe or something).
To get more speed: use dosbox 0.65 and change the core to dynamic,
and the cycles to auto (both things in dosbox.conf).
Reply 62 of 81, by Troi Tribble
Ok, I set the cores & cycles, and I found out where to set the sound, but here is what happened: I managed to find it here:
but, it turns out, I don't think I have soundblaster:
I have something else, instead:
So, what do I do, buy a new soundcard, or is there a way to install Soundblaster 8, or what? Is there some other way that I can configure it?
Reply 63 of 81, by wd
Rank DOSBox Author
DOSBox Author
You must run the setup program from within dosbox. There the soundblaster
is emulated as well (with the settings you chose correctly).
Reply 64 of 81, by Troi Tribble
Ok, thanks. I sure hope it works! UPDATE: Well, the video seems slightly better, I don't know, but the sound still is not on. I must be missing something! But, what? What is it that I need to do about the sound to make it work! I don't get it? I have done everything that you instructed me to do, but I don't know what it is I did wrong! Could it be because instead of "addr" like you said (the one that should be set to 220), and I have it listed at "port"? I don't know, I am just grasping at straws here! Please advise!
Reply 65 of 81, by wd
Rank DOSBox Author
DOSBox Author
No, addr and port are equal.
Does it still say that the sound card detection failed? Does sound work
under windows in general?
Reply 66 of 81, by Troi Tribble
It still says "Not detected", or something like that whatever. Yes, my sound works in general. So, what now?
Reply 67 of 81, by Snover
You should not ever be double-clicking on an icon to run the Final Unity setup program, nor to run the game itself. If you are double-clicking on an icon, you're doing it wrong. You must do everything through DOSBox.
Yes, it’s my fault.
Reply 68 of 81, by Troi Tribble
Ok, I will try the "install" thing on dosbox, Snover. EDIT: Guess what! There is no option to configure the game on dosbox!
So, now, what do I do?
Reply 69 of 81, by Troi Tribble
How do I get my dosbox setup to look like the picture enclosed?
Reply 70 of 81, by wd
Rank DOSBox Author
DOSBox Author
Well don't run the installer on the cd, but on the (emulated) c drive.
In dosbox, change to the c drive (type "c:"), then change to the
directory where you installed the game, and type install or setup or
whatever that game uses.
Reply 71 of 81, by Troi Tribble
I did, but I only got what is in the pic. shown above. However, the sound actually seems to be working anyway now, so I was able to play thru the beginning scene. Hip Hip HOORAY!!!! 😁
Reply 72 of 81, by robsario
Hello everyone...
I have a problem with this game too, may be you would be able to help me.
I've managed to install the game perfectly, although it took ages to install. Really slow!
The sound works in the settings screen, but it takes too long to load.
Now, when I execute the game it shows a screen that says "Star Trek A Final Unity" etc. (a loading screen), the game stays there forever... then it shows the Spectrum HoloByte logo animation which also es really slooooooow... is like I'm watching the game in really slow motion. It takes forever to do anything.
If you need to know, I'm playing this game in a PIII 650Mhz 640 RAM with a GeForce 5200 128MB. But I play other games there too and I don't have any problems.
I hope you would be able to help me! Thanks in advance.
ROBBIE.
Reply 73 of 81, by MiniMax
Rank Moderator
Moderator
Look at the top of the DOSBox window. See the "CPU Cycles: XXXX" ?
What does it say for you? 3000 ?
Try hitting CTRL-F12 to increase the cycles (but watch your real CPU usage using Windows Task Manager - don't let your real CPU usage get over 90%).
_________________
Reply 74 of 81, by Qbix
Rank DOSBox Author
DOSBox Author
650 MHz isn't enough to run this game in dosbox I think
Water flows down the stream
Reply 75 of 81, by robsario
Yes, it says 3000. Could the problem be the 650mhz? 😳
Reply 76 of 81, by MiniMax
Rank Moderator
Moderator
No - the problem is that you have not configured DOSBox for optimal performance.
Somewhere in the directory where you installed DOSBox.exe there should be a dosbox.conf. Open it with Notepad, and change the line that says core=normal to core=dynamic.
Or - before you start the game, use the DOSBox commands
C:> config -set cpu core=dynamc
C:> config -set cpu cycles=5000
and use CTRL-F12 to increase you cycles as needed.
Or - download one of the DOSBox front-ends (e.g. DOSBox Game Launcher) and use that to configure DOSBox for you game.
_________________
Reply 77 of 81, by masu
Hello,
my mousespeed is really slow in the game. It takes years, until the mousecursor comes from one border to the other border. Is there any way how I can increase the mousespeed?
DOSBox 0.63
Windows XP SP2
Reply 78 of 81, by MiniMax
Rank Moderator
Moderator
I don't know if if helps, but there is a setting in the SDL-part of the DOSBox configuration file that says
sensitivity = ....
Maybe upping that will speed the mousing up?
_________________
Reply 79 of 81, by masu
perfect
I increased the value to 400 and now it works
thanks!!
DOSBox 0.63
Windows XP SP2
