Hardware you regret parting with, or you wish didn't die
Reply 60 of 85, by dirkmirk
I threw away a Phillips all in one pc, 14" screen, ps2 ports, cyrix 5x86, 36meg ram, 850mb hard disk.
Actually the only thing I regret throwing away is the cyrix 5x86-100 cpu and the ram, it would come in handy, I cant remember what I did with a Voodoo2 12mb, probably gave it away but at least I kept the Voodoo3.
Reply 61 of 85, by RichB93
I don't regret it as it was ridiculously slow anyway but I chucked out a Super Socket 7 mobo and a AMD K6-2 350 (or 400, I can't remember).
Reply 62 of 85, by crash.
3Dfx Voodoo5 6000 - currently non-operational
Reply 63 of 85, by luckybob
pics or it doesn't exist....
Reply 64 of 85, by MaxWar
FM sound card comparison on a Grand Scale!!
The Grand OPL3 Comparison Run.
Reply 66 of 85, by luckybob
I feel like I'm looking at an adult magazine for the first time... It looks like there are 2 caps ripped off. C17 & C13 have you tried to replace them? I'd be more than happy to do it for you. seriously.
Reply 67 of 85, by F2bnp
That's some hot hardware pr0n right there
Reply 68 of 85, by DonutKing
Hmm, if you google image search it seems most V5 6000's don't have those caps installed.
But in any case, that card is too rare to simply let it die, surely there is still someone around that can do repairs...
I also found this, 😳
Reply 69 of 85, by crash.
I assume that these caps were deemed unnecessary at some point in the testing phase, or at least for certain versions of the card (there were several). This card was originally repaired by one of the 3Dfx engineers in 2003 (I think) and worked until recently. The solder pads for those caps are clean and there were no pins currently or formerly apparent. The symptoms of the malfunction are screen corruption and hang when a game is started, which most likely indicates a failed memory IC. The only person I have found that is able to replace one of these is in another country, unless I send it to a generic PCB rework company who would not be able to test it. In any case, it is heartbreaking and generally irreplaceable. There are a few guys that own a stack of these cards, which also hurts.
Reply 70 of 85, by DonutKing
Where are you located?
If you look on www.amibay.com there are several people there that can do intricate board level repairs, including replacing surface mount IC's and even CPU's. The most common repair/mod they perform is desoldering the 68040 CPU on an Amiga accelerator and replacing it with a 68060.
Reply 71 of 85, by crash.
Honolulu - the problem is that this card is very picky about which motherboards it is compatible with, so it would have to be tested by someone that has a system which is known to support this card. For example, I have Voodoo5 5500 cards that don't work with the motherboard that is compatible with the Voodoo5 6000. I literally had to buy three motherboards before I found one that had the right kind of slot and also actually booted with this card. I would probably have to ship an entire computer and some motherboards to someone if they don't already have a Voodoo5 6000 of their own. Sigh
Reply 72 of 85, by luckybob
Actually, my motherboard is known to be compatible. Just saying.
Reply 73 of 85, by MobyGamer
SavantStrike wrote:
So what have you parted with or lost that you wish you could get back.
Two Media Vision cards:
- A Pro Movie Spectrum which captured directly into MSV1 format and had a DOS player (sold it to a coworker)
- A Pro Audio Studio 3D card (Pro Audio Spectrum-compatible that had a 3D/surround/reverb module built-in). I might be munging the name of the card a bit, but it was definitely a Media Vision card circa 1995 or later and definitely had those extra features. I don't know what happened to it; it just disappeared 🙁
Reply 74 of 85, by jmrydholm
@DonutKing, when I saw all the Voodoo 5 6000's, I couldn't help but think- "You must choose. But choose wisely! For as the compatible motherboard will bring your card life, the false motherboard...will take it from you." Indiana Jones moment there. 😀
"The height of strategy, is to attack your opponent’s strategy” -Sun Tzu
“Make your fighting stance, your everyday stance and make your everyday stance, your fighting stance.” - Musashi
SET BLASTER = A220 I5 D1 T3 P330 E620 OMG WTF BBQ
Reply 75 of 85, by luckybob
I once used a dual tualatin board as my home server. I sold it because I thought I would never need it. Finally one comes to ebay and look how much it sells for: http://www.ebay.com/itm/360492640866 $325. I'm so sad right now.
Reply 76 of 85, by PcBytes
What didn't deserve to die were for me a Pentium II board which I got from someone and repaired it,so much time of work,destroyed in seconds:depressed:
Another one was a LuckyTech P5MVP3 which died after a broken capacitor.So sad,it was my first ever custom built PC and it died.😵
Reply 78 of 85, by madcrow
My biggest disposal regret is my old IBM PC300. It had 64 MB of RAM, a Pentium MMX 233, a good mix of PCI and ISA slots and one of the most elegant white desktop cases of the late 90s. As for hardware death, my biggest regert is the death of my Northgate Omnikey Ultra keyboard.
Reply 79 of 85, by MrTentacleGuy
I had the Creative Multimedia Upgrade Kit with SB Pro 2.0 and 1x CDROM, a regular Sound Blaster and an earlier model SB Pro all complete in the box until about 2007. I can't remember what I did with them TBH... I got rid of a lot of stuff that year because I was sick of moving it from apartment to apartment. I had a pretty clean 486, the Acer 386 I posted earlier on this thread, a Sun Sparc 2, a Sparc 5, a 19" Sparc monitor, an Apple IIe with Duodisk, an Amiga 500 (sigh), two earlier macs, a PowerPC 9500, and an Atari ST monitor (was planning on getting a Falcon). Around the same time I got rid of all my Sega hardware (all consoles + Nomad), an Atari 2600 + 7800, and a ton of assorted games / accessories. I traded in the console stuff for a 360 Elite and one game.
