Reply 60 of 171, by keropi
- l33t++
Since MaxWar uploaded v1.4 of the voodoo3 cd, do we need my v1.2 ? I think not, right?
wrote:Since MaxWar uploaded v1.4 of the voodoo3 cd, do we need my v1.2 ? I think not, right?
I think if it just contains the driver alone, then no need, but if there are additional goodies like demos or apps, that may be useful.
I'll compare both cd's to see the difference , but I am almost certain only the driver version will be different...
wrote:I'll compare both cd's to see the difference , but I am almost certain only the driver version will be different...
If then it's ok. Thanks!
EDIT : Updated patches section with Archimedean Dynasty, Extreme Assault and Descent II. I've named them "Upgrade Packs" since they contain both the needed latest version upgrade patches plus the 3dfx patch.
Currently focusing on patches for Dos games.
OK did the comparison.
It appears that 1.4 is the latest version we have.
- the 1.2 cd has an older driver and lacks the APPS folder , total iso size is ~158MB
- the voodoo3 3000 cd is the same as the 1.2 one, no APPS , ~158MB and older version driver
So the 1.4 is all we need , ofcourse if there is a need for the older cds I'll iso them 😀
keropi, I hate to quote myself but have you read this ?
wrote:keropi: your part 2 of your Diamond_SuperCD_2_98 is either corrupt or faulty, cause I have tried to extract all the parts with both the 64bit and 32bit version of winrar. So keropi . That is why I can not yet make a rar of the iso. And yes, I have tried re-downloading part 2 and even tried to repair it, keropi you better make a new version of the iso or something, cause do I really need to try to repair part 2 with winrar 32bit before I can call it finally corrupt and fucked ? Or is an incompatibility flaw between the older winrar versions, and the newest ? Cause I am using the newest version 4.01 of winrar 64bit.
Added Workaround for Battle Isle 4 - Incubation - a patch with fix to allow later Voodoo cards (3/4/5 + Banshee) to play it using Glide.
(Workaround is Section 6 - The last section.)
@WolverineDK :
sorry, I did not see your previous message 🙁
using latest regged winrar/x64 here too, will re-upload now!
wrote:@WolverineDK :
Thanks, I will be checking it out later on, today or tomorrow.
Patches section updated.
Can't believe this whole day I'm in Vogons! And I'm NOT stopping! 😁
here is the new part2:
<new links on later post >
also there is a .sfv now for the SuperCD... 😀
@malik:
it could worth it if you added the patched 3D Control Center util from here: Is there a systray app to easily select primary/secondary D3D device? FOUND!!! 😊
Done. 3D Control Centre added into Resources Section (Section 4.) 😀
keropi: now it is giving me an error (crc error) on part 3 of this "adventure". Of a quest to get your iso file into one rared fellow. Before you ask, yes I have scanned this machine with Eset before I went to work with this just be sure I had no viruses which I had zero of on my pc. Anyway, I am getting off. See you in quite a few hours, since I am heading to bed soon.
@WolverineDK: I am not doubting you get an error, my internet connection is not to be trusted or the RS manager app has some bug, that's why I split to parts... I'll upload part3 first thing tomorrow morning as the archive is in my office pc... sorry for the inconvenience ...
wrote:@WolverineDK: I am not doubting you get an error, my internet connection is not to be trusted or the RS manager app has some bug, that's why I split to parts... I'll upload part3 first thing tomorrow morning as the archive is in my office pc... sorry for the inconvenience ...
Okay, try to re-upload all the parts, so if I get lucky in the end with this adventure. Since I will try to get it right in the end, even though it is a painful task for us both.
I'll run the remaining parts through sfv and see if there is another corrupted
edit: yep, parts 3 and 4 need re-upload 😖 😠
wrote:I'll run the remaining parts through sfv and see if there is another corrupted
@keropi: keropi, how about making a new ISO again of the CD and then uploading it?
the ISO or the rars on my computer are fine, the transfer to the internet screws them up...
You guys should be sure to run a verify pass on the image you create. Sometimes CDROM drives do stupid stuff like not notice read errors.
7-zip Ultra compression produces incredible tiny archived images, so I just uploaded another ISO with my humble 1 Mb/512Kb DSL. Creative 3D Blaster Voodoo2 Installation CD Image:
