Reply 60 of 126, by Gemini000
- l33t
I still don't understand how an SSD is gonna help me out after an application/game is fully loaded. Especially with extra RAM present. :P
The reason for going 16 GB RAM is for being able to handle things now and in the future, as well as for being able to set up temporary RAM drives for certain programs. I know few programs now could ever burn through all of that, but then that's what I believed about having 2 GB of RAM just three years ago... >_>;
I understand that the 1155 socket is likely on the way out. Quite frankly, by the time I'm ready to upgrade to a new CPU again, I'll bet even the AM3+ socket will be obsolete, so it's a moot point. I've been faced with the ever-changing sockets problem every single time I've had to consider performing upgrades. The other catch too is that, just because your motherboard has a particular socket, doesn't mean it will be compatible with every CPU that fits in it. x_x;
Most of the benchmarks I was looking up prior only detailed raw power, in which the FX-8350 beat everything at its price range. However, when I started looking up gaming performance, it turned out the FX-8350 was good, but not VERY good, even compared to cheaper i5 CPUs. The i5-3570 is only $20ish more expensive than the FX-8350 yet has the best gaming performance possible before going i7, and making THAT jump also jumps the price. :P
I've also had a motherboard fail on me, plus a motherboard recently failed on a friend after only two years of operation. I'm not skimping on the motherboard because past experience has taught me not to. That said, MSI never got back to me about my concerns regarding their BIOS updates, and it's been over three days now. Even if ASUS' tech support sucked in the past, at least they had the decency to respond. :P
And again, I'd rather start without an SSD as I can always install one later on if the loading times without one bother me. ;)
--- Kris Asick (Gemini)
--- Pixelmusement Website: www.pixelships.com
--- Ancient DOS Games Webshow: www.pixelships.com/adg
