S3 Virge DX and GX memory
Reply 60 of 62, by TM30
This is what it looks like at 63Mhz.
Reply 61 of 62, by Putas
Many patterns, but I guess it is the memory. Might be worth trying to give them a bit more juice, if you are into modding.
Reply 62 of 62, by mkarcher
Putas wrote on 2026-11-11, 16:16:
Giving a 5V memory chip more juice is difficult: There likely is no dedicated power plane for memory, and boost converters are not that common as buck converters. Also, there is a limit of permissible input voltage on the memory pins of the ViRGE chip, but it would likely deal with 5.3V, but margin for overshoot will go down.
There are other ways to try to improve behaviour above 60MHz: The card is (hopefully!) running in 1-cycle-EDO mode, which means the system clock is the the CAS cycle rate, which is not the only timing affecting memory access. Also take care to note these register bits:
  • CR58, bit 7: increase /RAS active time while reducing /RAS precharge time, without any change of /RAS cycle time.
  • CR68, bits 0,1: adjust either the trailing edge or both edges of /CAS and /OE
  • CR68, bit 2: reduce minimum /RAS active time by a clock
  • CR68, bit 3: reduce /RAS precharge time by a clock
  • CR6F, bit 3,4: adjust either the trailing edge or both edges of /WE
  • MMIO 8204, bit 1: reduce /RAS precharge by two clocks (takes precedence over CR68, bit 3)
  • MMIO 8204, bit 2: reduce /RAS active time by two clocks (takes precedence over CR68, bit 2)
  • MMIO 8204, bit 7: CR68, bits 0,1 also affect the leading edge of /CAS and /OE
  • MMIO 8204, bit 7: CR6F, bits 3,4 also affect the leading edge of /WE
Especially MMIO 8204, bits 1 and 2 if set may be the cause of RAM issue at increased memory clocks, because they allow /RAS active and precharge time to become quite short.
