DOSBox has stopped working and closes at startup.
Reply 60 of 111, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Scummvm, exult, xu4, pentagram...
Try exult from http://exult.sf.net you need Ultim7 for it to being really useful but for sound initialization it will work well enough without Ultima7 😉
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 61 of 111, by collector
Sorry, I was thinking of another thread where someone was having problems on Win8. You only see one device when you go to Control Panel => Sound => Playback? There is no SPDIF, USB or HDMI audio device listed in addition to your Realtek?
Reply 62 of 111, by Tanukitsune
Like I said in the start of the thread, I use ScummVM most of the time and it's never given me trouble. I could try that Ultima emulator, I have the Ultima collection and I'm pretty sure it goes up to 7 at least.
I do have an HDMI audio device, but I thought that was connected to my graphics card? And yes I do have SPDIF too, but I have to disable it with the main audio device to get DOSBox running. I could swear I mentioned the SPDIF before?
Reply 63 of 111, by Dominus
DOSBox Moderator
Sorry, didn't reread the thread so I forgot the ScummVM part. You just need to download, install and run Exult. It initializes music right away so that should make it crash or not...
Reply 64 of 111, by Tanukitsune
Well, Exult crashes in the exact same way.
Reply 65 of 111, by Dominus
DOSBox Moderator
Ok, that is at least a confirmatiom that it's probably an SDL 1.2 issue (does anyone know has ScummVm switched to SDL2 or are they patching SDL?).
Do you have OLDER drivers for your sound device still around? Preferably from a time DOSBox was still working (if you have a rough guess about that). And if you disable the device in the device manager is DOSBox working?
And just for hecks sake, can you try and run DOSBox as an administrator? Just a long shot...
Reply 66 of 111, by Tanukitsune
Running it as an admin was the the first thing I tried.
It would be weird if downgrading my driver would help, since the only time I updated my sound driver when was someone here suggest it, either way it says it's been the same since 2010, and I only started having this problem recently.
Hmm, come to think I'm not even sure what brand my audio device is... It says "High Definition Audio Device" everywhere I look on my PC, but I do know that the moment I disable it, DOSBox works.
And oddly enough, like people suggested before I disabled the sound in the config files and that does not do anything.
I also just checked, ScummVM still works fine.
Reply 67 of 111, by Dominus
DOSBox Moderator
thanks for checking and for being patient with all our different suggestions 😀
Downgrading drivers may help from time to time, always depends on what the problem is. Of course we first suggest updating it 😀
It might be good to find out what your device is and see whether you can find drivers from the manufacturer and not the generic MS drivers (worth a shot).
Can you think of *anything* major that you recently did? Anything audio related? Any software that is always running in the background? Can you try quitting *everything* except what the system needs? Quit Skype, etc... If the problem is there it's likely to be something that autostarts with your system.
If that helps turn them back on, one by one and test in between when DOSBox crashes. You got me interested now in solving this 😀
Reply 68 of 111, by Tanukitsune
The sound card is integrated to the motherboard, and has been the same way before this problem happened, it seems to have only one driver since I can't update or downgrade it, at least through the Windows Device Manager. If it helps, I'll open up my PC to find out the motherboard and then figure out the sound card that's integrated to it.
I disabled my antivirus and even though I have no VOIP I closed everything in my toolbar later. Hmm, do you think starting Windows in Safe Mode would help weed out if it's some other program messing everything up? Or would it be better to shut them down manually with the Windows Task Manager, one by one to see which one it could be?
Reply 69 of 111, by Dominus
DOSBox Moderator
Shutting down one by one in task manger would be best and only if that doesn't help trying safe mode.
You should be able to learn about your sound card if you know which mainboard you have. Maybe you can find that out more easily
Reply 70 of 111, by Joey_sw
create a restore point first, and see if the audio devices can be "Roll Back Driver",
automatic windows updates are often updating device drivers as well.
-fffuuu
Reply 71 of 111, by Tanukitsune
I don't have a previous driver to "roll back" to.
Now that I have time I'll try disabling programs in the Task Manager and hope one of them is the culprit.
Reply 72 of 111, by Jorpho
Judging from http://wiki.scummvm.org/index.php/Compiling_S … M/Visual_Studio it still uses 1.2.
Reply 73 of 111, by Tanukitsune
OK, I've made some progress:
-My Motherboard is a F1A75-M PRO that uses "Realtek® ALC892 8-Channel High Definition Audio CODEC"
-Starting is Safe Mode works.
-I closed all non essential processes in normal mode... it still didn't work.
Should I mess with the task manager services? I don't any related to audio specifically, but who knows.
Reply 74 of 111, by Dominus
DOSBox Moderator
You could with the drivers https://www.asus.com/Motherboards/F1A75M_PRO/#support
Further than that I'm too inexperienced with Windows these days.
I'm curios why Scummvm works and both Dosbox and Exult crash. Initialization of MIDI perhaps?
Reply 75 of 111, by Tanukitsune
The driver version number seems to be the same, which would explain why it's not updating or "rolling back".
Reply 78 of 111, by Tanukitsune
I have to disable all devices attached to the Realtek device to get DOSBox to work.
Reply 79 of 111, by Jorpho
Isn't this fun? I'm wondering if the fastest way to get to the bottom of this is to write a small SDL program that outputs more useful debug information. (Or does something like this already exist somewhere?)
