Decided to stick with the SB16 for now, as it's not needed elsewhere.
I was trying to figure out a way to have Adlib from the internal speaker and retain the front mounted volume control, but it seems that it'd require some modifications to the audio board. I'll just use a small set of speakers for the SB16.
Yep it's 220V - these were sold for a while in UK Tandy stores. Don't imagine they sold many though.
This particular monitor is a rebadged Philips CM8833, I'm not clear whether this was what Tandy sold with the TL/2 in the UK originally or whether it was purchased later. Maybe the CM-5/CM-11 that people in the States use is 110V only, so Tandy had to source a 220V monitor for the UK and Australia? Anyway it has SCART and TTL input.
Final push last night to get this system finished. Mounted the XT-IDE and installed an activity LED in the spare drive bay's blanking plate. Looks OK I think.
EGA card installed, I have some plans to modify VSWITCH to allow switching between Tandy and EGA. May even be able to use the EGA feature connector so both signals come out of the EGA card.
The little dot on the left is the activity LED, I did a similar thing on my XT.
The system itself is very compact, shame about the Tandy keyboard 🤣
