IBM PS/1 Consultant 1993 with Sound blaster.
Reply 60 of 67, by Intel486dx33
The box
Reply 61 of 67, by BLockOUT
Intel486dx33 wrote on 2021-09-02, 01:41:
BLockOUT wrote on 2021-08-25, 23:34:
Intel486dx33 wrote on 2021-08-25, 23:06:
See my posts above with the manual white pages. It shows the jumper settings for 486dx2. Use that jumper setting for 33mhz. CPU […]
Or maybe it was the Pentium overdrive CPU setting.
You need to switch the jumpers for 286kb of cache too when used.
See photos above.
Update:
Actually, your motherboard is different from mine.
I don’t see your motherboard in the hardware manual.
Look on the back of your computer and see the “Machine type model”
It’s something like “2255”
Then search the internet for that model type manual.
interesting , in the manual you posted today that motherboard model from our pictures is not included in the manual designs.
but if you say that setting the board jumpers to overdrive...will also work with a dx2 66mhz and a transposer i might give it a try.
I am going to try one of these in my other PS/1 with a 486sx-33. It has an Intel Overdrive socket but only excepts 169-pin CPU’s
So this adapter with a 486dx4-100 should work.
please let me know if it works, test it leving the pc on for 20 minutes to see if it glitches or hangs
Reply 62 of 67, by Caluser2000
BLockOUT wrote on 2021-09-14, 15:31:
Be aware. his person makes fake post about non existent systems he has. He gets pic of the internet and claims they are his systems
Reply 63 of 67, by Intel486dx33
Okay, I have that computer stored away in my garage so I will have to pull it out.
Reply 64 of 67, by Caluser2000
Intel486dx33 wrote on 2019-09-01, 13:00:
The 486 IBM PS/1 came preloaded with DOS and Win3.1 ( 16-bit operating systems ). Windows 95 was a 32-bit operating system. It w […]
AlessandroB wrote:
Intel486dx33 wrote:
Yes, The 1993/94 IBM PS/1 came preloaded with DOS 6.21 and Win3.1 Windows 95 came out in 1995 and by that time the Pentium CPU w […]
Windows 95 came out in 1995 and by that time the Pentium CPU was well available.
The IBM 350 came with a Pentium CPU and Win95.
https://en.wikipedia.org/wiki/IBM_PC_Series
you haven't reply at my post, the graphic and ide chip on the mainboard, are connected to the system in ISA or VLBUS??
Windows 95 was a 32-bit operating system. It was a different era in computing and hardware.
https://youtu.be/ZBbvmORcgSo
Some of the fastest video cards available for the VLB slot where the Cirrus Logic 5426, 5428 and 5429.
The 5430 was only available on PCI and was onboard on the 486 IBM 330 computer.
You still haven't replied to AlessandroBs question.........
Reply 65 of 67, by Intel486dx33
AlessandroB wrote on 2019-09-01, 10:22:
AlessandroB wrote:
Yes but is connected via the slow isa bus instead vlbus...
This model ps/1 computer is all ISA. I am not sure If the onboard IDE controller is 32bit ?
Reply 66 of 67, by Caluser2000
Intel486dx33 wrote on 2021-09-16, 06:45:
You have easy access to the IBM PS/1 series workshop manual so you should know.
Reply 67 of 67, by Intel486dx33
I modified the Autoexec.bat file and loaded all the drivers “HIGH” in upper memory.
So its now working with only 3mb. Of Memory used in DOS 5.0.
But when I Start Win3x it loads all of the 32mb of Memory and that’s Okay.
What good is MEMORY if the computer is NOT using it Right ?
Thats how I see it.
So this modification Free’s up “Conventional memory” so I can play DOS games that require allot of Conventional Memory.
Are there any draw backs to loading device drivers HIGH ?….
