Reply 60 of 64, by feipoa
Those are pretty incredible speeds when put into the context of what we are achieving here on the 486SXL - around 2 MB/s.
Reply 62 of 64, by rjbrown99
Can the folks doing benchmarks also please share their scsi2sd and card BIOS configs? IE - how do you have the SCSI speed limits set, are you enabling SCSI2 mode, for the BIOS on the card are you limiting it to 5MB/s or allowing 10MB/s?
Asking as my 1540CP required the BIOS to be set at 5MB/sec to properly detect my card/drive (with a SCSI2SD v6 model).
Thanks in advance.
Reply 63 of 64, by feipoa
Everything was set at the optimal settings. I wasn't using any limits. It is at 10 MB/s.
Could you be running the 1540CP with DMA at the full bus clock instead of BUSCLK/2? This should be a motherboard BIOS setting.
Reply 64 of 64, by rjbrown99
My motherboard has a very limited set of options, it's an ISA-only board with a 1991 BIOS. Right now the 1540CP is set to 5MB/s and the SCSI2SD is set to "No limit (safe)" but with "Enable SCSI2 Mode" checked.
I'll benchmark it as-is with the working config and see if I can adjust one or both to get to 10MB/s.
My working (but slow) config is attached in case anyone else stumbles across the thread. I also found that it was best to disable termination in SCSI2SD and let the Adaptec card handle it. This is for a Sandisk 16GB SD card split into two similarly sized ~7.5 gig drives.
    486_scsi2sd.xml.txt
    18.47 KiB
    71 downloads
    SCSI2SD config
