HWiNFO support of vintage hardware
Reply 60 of 809, by Mumak
vorob wrote on 2020-01-16, 12:07:
I did, no file was generated.
Tried random old version (3.51.748) and it works.
That's very strange. Does the welcome window show up at least, or the BSOD happens before you get a chance to see that screen (and enter the Settings or press Run) ?
Reply 61 of 809, by vorob
Exactly.
Reply 62 of 809, by Mumak
That's very strange. HWiNFO doesn't perform and hardware access before the welcome screen is shown, so this might indicate some other problem in your system, most probably driver/kernel related.
Is there any other special software installed? Do other tools like CPU-Z or SIV work properly there?
Reply 63 of 809, by vorob
I just got this laptop and was unable to do a clean install of windows. I will do it later. Tried more random old builds:
351 okay
444 okay
504 and later BSOD
Does this help somehow?
Reply 64 of 809, by Mumak
I'm sorry, that doesn't help much 🙁
I have once seen a similar problem, but on that system other tools like CPU-Z, AIDA were crashing in the same way.
Reply 65 of 809, by vorob
CPU-Z 1.91 works okay.
Reply 66 of 809, by FreddyV
Hi,
what is the HWInfo version working for 8086 ?
and for 386/486 ?
I did the same as you, downgrade my .MOD Player to 8088 😀
Reply 67 of 809, by Mumak
FreddyV wrote on 2020-01-22, 09:59:
Hi, […]
Hi,
and for 386/486 ?
HWiNFO for DOS v4.4.1 requires 386+, all later should run on 386. The only issue is the conventional memory requirement. Hence I recommend to boot from a clean DOS 5+ without unnecessary drivers. Also make sure to load HIMEM.SYS and DOS=HIGH.
I don't have a record which version runs on 8086 anymore, but I suppose it was somewhere before 4.0.0.
Reply 70 of 809, by vorob
Here you go. Also may there is a way to control cooler?
Reply 71 of 809, by Mumak
Thanks. I will remove that invalid sensor, but reporting GPU temperature on that GPU is very difficult and problematic.
Reply 72 of 809, by vorob
Any way to copy aida64 code? 😀
Reply 73 of 809, by Mumak
vorob wrote on 2020-01-27, 22:32:
I don't need to copy/steal anything, I can ask Tamas (AIDA64 author) 😉
But AFAIR the method was pretty complicated and in the past I decided not to implement it.
Reply 74 of 809, by vorob
You know any other tool that will work as Aida but will show min max values? Cause I need this to understand how hot this chip becomes and Aida only shows current state.
Reply 75 of 809, by Mumak
GPU-Z should be also showing min/max if you click the sensor item. But not sure if it will support this GPU properly, it has issues with older models AFAIK.
Anyway, I will look into this how feasible it is to implement.
Reply 77 of 809, by vorob
It's a laptop from an age where only manufacturer produced drivers... So to install smth newer i'll need to work on inf files and so on. I want to skip it for now.
78.17 is my driver
Reply 79 of 809, by vorob
Sadly that’s exactly my version. It’s manufacturer driver.
The attachment 25A77F4E-C5B0-4489-ABF1-9C8168C134A8.jpeg is no longer available
