Reply 60 of 113, by jnemo2004
OK. Thank you very much. This motherboard is not for me. I paid only 5 euros but for nothing.
I will put a cord on it and i will hang it up on the wall for decoration.
Regards
Reply 61 of 113, by jnemo2004
Hello, could you please help me to identify this motherboard?.
Thank you very much and regards
Reply 65 of 113, by DrSwizz
Could somebody please help me identify this ISA Card? (I hope the images of it are being displayed properly, me only attaching them to this message).
Reply 66 of 113, by Tiido
It looks like some sort of an industrial process control card with its onboard 680x type CPU, ROM, RAM and extra peripherals. Neat thing but probably useless without the rest of the machine it went into...
Reply 67 of 113, by DerBaum
DrSwizz wrote on 2023-10-16, 19:15:
I see a maxim max232 on there. Maybe you can find where the serial interface on the connector is and try some serial interfacing. Maybe it answers something.
FCKGW-RHQQ2
Reply 68 of 113, by DrSwizz
Thank you guys for your input. 😀
Figuring out how to set a serial connection with the card might be beyond my (rather limited) limited knowledge of electronics, but I might give it a try anyway.
Reply 69 of 113, by jnemo2004
Could you please help me to identify this motherboard?
Reply 70 of 113, by jnemo2004
All the ICs in sockets have been removed.
Reply 71 of 113, by BitWrangler
Same design as PC Chips M601, but I can't spot the subtleties as to revision.
Reply 72 of 113, by weedeewee
BitWrangler wrote on 2023-10-24, 14:01:
yep,
https://theretroweb.com/motherboards/s/pcchips-m601-ver.-1.3
also known as the amptron DX-6600, which is clearly visible on the pcb 😀
Do not ask Why !
Reply 73 of 113, by jnemo2004
Thank you a lot, thank you very much.
Reply 74 of 113, by rain
Here is..
_retired retro pc user_
Reply 75 of 113, by BitWrangler
Seems like one of these... https://theretroweb.com/motherboards/s/dataex … i-scamp-80386sx but IDK if you were just pointing CPU out to someone, but don't see the post referred.
Reply 77 of 113, by jnemo2004
Hello Sirs, a coleague has an 8086 motherboard with a chip burned. Could you please help me to get the IC datasheet?
Reply 78 of 113, by jnemo2004
Hello, could you please help me to get information of this motherboard?
Thankyou very much
Reply 79 of 113, by weedeewee
jnemo2004 wrote on 2023-11-10, 10:21:
Thankyou very much
This one comes fairly close. likely slightly different revision, though not a lot of information there.
https://theretroweb.com/motherboards/s/tk-tk82230-2s-d03-01
Do not ask Why !
