Reply 60 of 75, by ediflorianUS
Nexxen wrote on 2023-07-06, 14:22:
Thanks mate! One thing I couldn't figure out (among many) is the connector model of the FDD connector. I could buy a new one and […]
ediflorianUS wrote on 2023-07-06, 07:27:
Nexxen wrote on 2023-07-05, 11:42:
Quite some movement today! :) […]
Quite some movement today! 😀
@snufkin: everything is welcome, this project is love and frustration! Mostly love though 😉
@ediflorianUS: the pictures are of a busted laptop, not mine, that I'm using for spares. It's all crusty and even some pins of the chipset ICs are rotten and gone... I just need the courage to get back to it - 🤣
Yes, I think I have the same manual, unless by "service CD" you mean the schematics: that would be awesome x10²⁵.
Now I feel compelled to restart repairs 😀
just wait till I check at least the name of the cd.... and see what toshiba's lurking in my collection.
Thanks mate!
One thing I couldn't figure out (among many) is the connector model of the FDD connector. I could buy a new one and make a cable.
My old project is to have a normal FDD as an ext drive.
Well, I'm not fretting over anything, take all your time.
It's a standard Japaneze FDD connector usually used by Toshiba/Fujitsu/NEC and other japaneze production stuff , it's from mid 90s
someting like this for the external :
https://www.thinkwiki.org/wiki/Floppy_Connector
?u=https%3A%2F%2Ftse3.mm.bing.net%2Fth%3Fid%3DOIP.aVHovIxQQ1cEmpVpnRZhkgHaFj%26pid%3DApi&f=1&ipt=21bec1506726da8d9e4bc242ad963242651ae0f56167777a5a6965d3f6bf9a6d&ipo=images
will search for internal also. (L.E> it seems to have a Interface .ATAPI (Enhanced IDE) port...) - sadly I cannot find the internal flexible cable configuration anywhere
LE. here (photos)
I found the repair service manual's Named:
Toshiba Atlasi CD 1995 iso
Toshiba Atlas CD 0497 iso
link main page
sn readme
and a few more stuff here :
https://www.minuszerodegrees.net/manuals/Toshiba/Toshiba.htm
My 80486-S i66 Project
Reply 61 of 75, by Nexxen
Video of the POST sequence.
I'm using a generic card found in the usual places.
Stops at 55 displaying KBC ERROR on screen.
https://www.youtube.com/watch?v=KvE0oTv7oKY
Just to add a bit of something 😀
    731.59 KiB
    712.34 KiB
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 63 of 75, by Nexxen
Now I get these two messages at power on.
If I reset it cycles to "blinking" cursor and code 5A
If anyone has a BIOS image for this laptop, please post. I can burn it.
    150 KiB
    160.1 KiB
Reply 66 of 75, by Nexxen
snufkin wrote on 2024-03-23, 16:02:
Image is compressed, I can't burn it directly.
I have to switch to Windows.
Update:
I soldered the PS2 connector and keyboard lights up, 3 leds, and when it stops at 5A, numlock is lit and can be pressed to change state.
I left for a few minutes and came back to (see pic) and I could press keyboard keys to move forward (F1 to BIOS).
Sequence:
1. Power on
BIOS issue, diskette to flash
2. Reset
cycles to blinnking cursor
-- 2/3 minutes wait
Bad RTC battery
Bad check sum (CMOS)
Check system. Then press [F1] key. (blinking cursor)
3. F1
BIOS
4.
Reboots
Self Test
Memory Test
linking cursor
(pause 3-5minutes)
5.
Insert system disk in drive.
Press any key
(if FDD 1st in bios it'll loop with no message but a cursor)
Replacing the 187HP did the trick.
I still have issues with the bios asking the update.
I have to power it off etc but I can do something about it now.
    206.49 KiB
    119.5 KiB
    296.64 KiB
    223.59 KiB
Reply 67 of 75, by snufkin
Nice, so does that mean you've got two probably broken 187hp and one working? I'm hoping that's the one I sent...
That .exe is a self-extracting zip, looks like you can just unzip it. It includes a few files, including a couple of files that can be just be put on a 720kb floppy which can then be used to update the BIOS without needing to create a disk image. Might need to use the laptop keyboard as it need F12 working.
Reply 71 of 75, by Nexxen
snufkin wrote on 2024-03-23, 21:04:
Damn. Feels like it was sort of close, but also a possibly endless 'just one more thing'. Blame hidden battery damage, that's what did for the one I had.
Powering on, w/o a vid card, POST codes go:
FF 00 FF and stops
Now it stops with the vid card like w/o. Go guess if it is the vid card or what was involved.
All this happened after I plugged in the sound card + HDD board back in place.
Was it that? At this point I'm moving everything in the basement and forget it exists.
IDK if I have to pass it on to some kamikaze of the Toshiba tribe or sell parts.
Maybe it's just a cap misbehaving...
Absolutely beyond my abilities.
A big thanks to everybody, thank you Snufkin for the kind donation and let's aim to something less troublesome 😀
Last thought:
ok, they are nice laptops but if something fails and it is not obvious and available, it's just a pile of tech trash to dispose of.
Repairability is nil IMHO.
Reply 73 of 75, by Nexxen
ediflorianUS wrote on Yesterday, 15:14:
what I miss? did you reflow stuff? bios did you ever found it? wasn't one on Archive org?
I threw a temper tantrum caused by psychological fatigue.
As of now I boxed the whole thing and stored it in the basement. In the future I'll try different things, in fact new ideas arose watching others trying to fix similar stuff.
Bios? No, the one I found didn't work. It has to be update via floppy drive but I don't have the enclosure to connect it to its port. No flash.
Thus why I need an image from someone, to be 100% sure it works.
I plugged in the HDD minicard and it stopped working. Something is either fried or ... No POST codes, like bios chip could be dead... or...
Please, don't make me go back there. It's cold, dark and ugly. And my parents are gonna kill me if they know... 🤣
Reply 74 of 75, by ediflorianUS
Nexxen wrote on Yesterday, 16:04:
I threw a temper tantrum caused by psychological fatigue. […]
I want to help (sort-of hopefully)
https://archive.org/details/toshiba-satellite … oppy-images.-7z
https://archive.org/details/200cdsdrv
https://www.minuszerodegrees.net/manuals/Tosh … ce%20Manual.pdf
https://support.dynabook.com/support/viewCont … ontentId=106115
https://www.donrigo.com/mirrors/www.minuszero … cifications.pdf
maybe try here for bios : https://forum.vcfed.org/index.php ?
(btw I'm in sort of same predicament with my japaneze B142 FujitsuLifebook.... , no beeps no image , posted about it no help , may be a ram issue on gpu side -for me).
Reply 75 of 75, by Nexxen
ediflorianUS wrote on Yesterday, 16:22:
I want to help (sort-of hopefully) https://archive.org/details/toshiba-satellite … oppy-images.-7z https://archive.org/details/2 […]
Thanks! Gonna read it all.
