DOS CD-Rom issues
Reply 60 of 81, by snufkin
Bernkastel7734 wrote on 2021-05-11, 12:54:
So that's the autoexec.bat and config.sys connected to CDROM and that soundcard : [autoexec.bat] SET BLASTER=A220 I5 D1 T4 LH C […]
[autoexec.bat]
LH C:\DOS\MSCDEX.EXE /D:CDROM /L:D
[config.sys]
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\SOUND\CS4232C.EXE /V /O /VSS4232.INI
DEVICE=C:\DOS\DOAKCDROM.SYS /P:360,11 /D:CDROM
I'm guessing it's just a couple of typos there. What does that CS4232.INI file look like?
Reply 61 of 81, by weedeewee
Why is this still reading 360 and not 168 ?
Do not ask Why !
Reply 63 of 81, by Bernkastel7734
snufkin wrote on 2021-05-11, 13:07:
[PNP]
WssIO=534
WssInt=5
WssDmaPlay=1
WssDmaCapture=0
SbIO=220
OplIO=388
OplInt=Disabled
GameIO=200
4232IO=538
4232Int=Disabled
MPU401IO=330
MPU401Int=9
CDIO=360
CDInt=11
CDDma=3
Device4IO2=Disabled
Device5IO=Disabled
Device5Int=Disabled
[IniUpdate]
SysIniFile=c:\windows\system.ini
;SoundBlasterIRQ=[sndsys.drv],SoundBlasterIRQ
SoundBlasterAddr=[sndsys.drv],OldMSDOSGameIOAddress
;SoundBlasterDMA=[sndsys.drv],SoundBlasterDMA
UsePnP=[sndsys.drv],UsePnP
WSSIRQ=[sndsys.drv],Interrupt
WSSAddr=[sndsys.drv],IOAddress
WSSPlayDMA=[sndsys.drv],DMADAC
WSSCaptDMA=[sndsys.drv],DMAADC
MPU401IRQ=[mpu401.drv],int
MPU401Addr=[mpu401.drv],port
CS4232Addr=[sndsys.drv],CS4232Control
FMAddr=[csfm.drv],portFM
; For now keep this disabled
;FMIRQ=[csfm.drv],Int
;JoystickAddr=[sndsys.drv],Joystick
Reply 64 of 81, by snufkin
Ok, this might be back-to-front, but try changing the CDIO line to 168, or 36E (the resources given in win98)
Reply 65 of 81, by Bernkastel7734
snufkin wrote on 2021-05-11, 13:15:
Already tried with 168, will try with 36E
Reply 66 of 81, by weedeewee
could you try without loading the soundcard driver in config sys. It might be messing up the config of the chip since there are some differences between the 4232 and 4237.
you will have to experiment with the io,irq adresses again.
and you might want to give unisound a try to set up the card.
Do not ask Why !
Reply 67 of 81, by Bernkastel7734
Will try without that line in config.sys. Already tried with unisound, if nothing changes I'll focus on it
Reply 68 of 81, by snufkin
If you try the Unisound option, then take note of Oetker's post from before:
Oetker wrote on 2021-05-10, 12:18:
I'm not familiar with the stock drivers for that card. However UNISOUND should support it. UNISOUND - Universal ISA PnP Sound Ca […]
I'm not familiar with the stock drivers for that card. However UNISOUND should support it. UNISOUND - Universal ISA PnP Sound Card Driver for DOS v0.82a
Note that the readme says
Anyway as this tool is launched after config.sys, if you want CD-ROM support you'll have to load CD driver (like vid […]
Anyway as this
have to load CD driver (like vide-cdd.sys) with device driver loaders
like DEVLOAD after Unisound IDE port activation.
Maybe that's the issue you're having wit hthe stock drivers as well? That they initialize the card after the cd driver tries to do its thing?
I think the devload referred to is here: https://www.infradead.org/devload/, which should let you load oakcdrom later.
Incidentally, the project write up is quite funny. Essentially an exercise in trying to get around college IT restrictions to be able to run Adobe Type Manager, and then submitting it as their A-Level project.
Reply 69 of 81, by weedeewee
snufkin wrote on 2021-05-11, 13:34:
It is also possible that the soundcard gets everything initialized due to the onboard eeprom and some plug'n pray magic and that the seperate driver screws it up and misconfigures the crystal chip, thus making the cdrom inaccessible.
Do not ask Why !
Reply 70 of 81, by Bernkastel7734
Maybe, maybe.
Also, in the configurator there is and option like Override PnP BIOS and '/o 'following the initializator in the config.sys is responsible for that.
Reply 71 of 81, by Bernkastel7734
Have tried to initialize it with unisound. Still the same, sound works, but ' No device found' when trying to set up the CDROM
Reply 72 of 81, by Bernkastel7734
But I think I know what can cause a problem with unisound. It says 'Loading Unisound default settings. And the IDE is disabled by default. I've put 'C168' in the 'SET BLASTER' line but it seems to ignore it.
Reply 73 of 81, by snufkin
Ok, so what's your autoexec.bat looking like now? And what does unisound /r output (should read the current settings)? Are you using devload to load oakcdrom.sys after running unisound? I notice in the unisound.txt instructions that it sets up the IDE IRQ based on the address. Given Win98 had the CDROM using IRQ 11 then it might be worth trying forcing the address to 1e8 as that would apparently be the normal base address for an IDE controller on IRQ 11 (tertiary controller would be 168/10, quaternary 1e8/11, according to random internet page).
Reply 74 of 81, by Bernkastel7734
it worked with 1e8/11. Now the CDROM works
Reply 75 of 81, by Bernkastel7734
Also, I've noticed that it works only with atapicd.sys. Both vide-cdd.sys and oakcdrom.sys crash the PC.
Reply 76 of 81, by snufkin
Bernkastel7734 wrote on 2021-05-12, 12:55:
Yay! Sort of. Wonder why that happens. Still, good enough for the moment.
Could you post your config.sys and autoexec.bat so that if anyone else has a similar problem then they don't have to read through the whole thread?
Reply 77 of 81, by Bernkastel7734
Okay, so the entires in autoexec.bat are:
SET BLASTER =A220 I5 D1 H1 P330 C1E8
[path]UNISOUND.COM /V80
[path]DEVLOAD.COM [path]ATAPICD.SYS /D:CDROM
[path]MSCDEX.EXE /D:CDROM
And config.sys does not contain any changes.
Reply 78 of 81, by weedeewee
Bernkastel7734 wrote on 2021-05-12, 13:31:
Okay, so the entires in autoexec.bat are: SET BLASTER =A220 I5 D1 H1 P330 C1E8 [path]UNISOUND.COM /V80 [path]DEVLOAD.COM [path]A […]
Where did the atapicd.sys file come from?
Just wondering if it might be useful for @matskatsaba, 286 16mb ram, cdrom driver issues who is trying to get an atapi cdrom working on his 286 with more than 4MB of ram 😀
Do not ask Why !
Reply 79 of 81, by Bernkastel7734
weedeewee wrote on 2021-05-12, 14:21:
https://www.hiren.info/downloads/dos-files
