Reply 60 of 238, by gerwin
- l33t
Again thanks for testing compatibility, and sharing your findings.
DosFreak wrote on 2022-05-08, 20:55:So was checking out Vista 64 and decided to see if Ion Fury would run.
The build with 11-17-2021 grp does run but it has the same issue as later builds of eduke32, ran it through dependency walker and saw this: https://docs.microsoft.com/is-is/windows/win3 … readdescription
So guess later builds of eduke32 are for Windows 10/2016+ 🙄
Noted. Glad there are more portable and functional packages from earlier dates (as below).
DosFreak wrote on 2022-05-08, 20:55:Use this build for XP with builds of Ion Fury older than 11-17-2021 eduke32_win32_20211006-9651-a891732fd
I think you are mistaken there. In the other thread we talked about the nastiness starting right after eduke32_win32_20210927, 2021-09-27. I tested it again and that 20211006-9651-a891732fd is no good.
