Pentium MMX 233 aiming for the stars!
Reply 60 of 103, by Sphere478
cyclone3d wrote on 2022-02-18, 03:46:
Would benches with dual CPUs be ok?
yes
Sphere's PCB projects.
Reply 61 of 103, by Imperious
Sphere478 wrote on 2022-02-17, 21:38:
Imperious wrote on 2022-02-17, 13:01:
I've re-run most of my previous benchmarks with 7.58 driver, it's a fair bit faster. I tried 3.2v with the cpu at 300mhz, still blue screens. I'm not wasting any more time with this cpu aiming for 300mhz. I might put my 200mmx in at a later date. Also I have a Tillamook cpu that may work with this motherboard if I do the cpu mod.
For some reason the 233mhz screenshot is corrupted. The score was 1340
the score was corrupted in the screenshot? weird..
can you upload the driver you are using in a zip please I'm having trouble finding a working version that has a working download link
I re-ran the 233mhz bench and updated the post, also added the driver.
Reply 62 of 103, by Sphere478
Imperious wrote on 2022-02-18, 09:19:
Thanks 😀
Reply 63 of 103, by meljor
Will go for a record tomorrow with Asus p5a, 128mb pc133, Asus geforce2 gts and a 233mhz@300mhz hopefully....
Reply 64 of 103, by Imperious
For those wondering about ATI video cards, I ran this with a radeon 8500. Interestingly it has the exact same memory IC's as the Geforce 3 Ti200, which means the memory on the GF3 has a fair way to go from 430 to 550mhz, well theoretically anyway. I used the 2.2 driver. No idea if a later one will improve performance or not.
Reply 65 of 103, by Sphere478
Imperious wrote on 2022-02-20, 12:29:
Very nice :p btw, if any of you guys are running usb2.0 cards. Take them out when doing benchmarks. Just being there can drop your score a few hundred points
Reply 66 of 103, by Aebtdom
1369 3DMarks with 3dmark99 default @ 233Mhz (3.5 x 66) Voodoo2 SLI.
Anyone who Can do better at default settings I dare ya 😉
Builds:
Xp3000+ gf3 ti200 + vd2 SLI 12MB + 768MB + SB live @ WinXP & 98 Dualboot.
P2 350mhz + Diamond Viper V550 + 3Dfx Voodoo 2 12MB + AWE64 + 128MB SDR @ msdos / win98.
Reply 67 of 103, by Sphere478
Radeon 9200 pro pci
Stock windows drivers
Tyan tomcat s1564d
512mb simms
Pentium 233 x2
Windows xp sp2 installed for single processor.
(Only one cpu working)
3dm 2001 and 2000
No mouse, hence no cpuz in same screen. Just putting up for reference, not a record or anything 🤣. Seems this card is better than a 7000, but not as good as a 7500
    1.7 MiB
    1.87 MiB
Reply 68 of 103, by Imperious
Aebtdom wrote on 2022-03-01, 19:29:
I don't know how but I beat it, barely. similar configuration to Yourself, except Epox EP-MVP3G5 Stb Voodoo 2 SLI, P233mmx at default speed.
This was about the 10th run. I tried the other voodoo 2 as the output, not that I have any idea whether that made any difference or was just sheer fluke.
Reply 69 of 103, by GigAHerZ
Took a moment and ran a benchmark myself too.
Specs:
Pentium MMX 200MHz@3x83MHz /w 512kB L2 cache
Tyan S1571 motherboard
2x128MB PC100 SD-RAM
GeForce 2 MX-400 PCI (32MB) (Detonator 23.11 drivers)
Sound Blaster AWE64 (CT4520)
RTL8139C PCI NIC
8GB CF card as HDD
Reply 70 of 103, by Sphere478
GigAHerZ wrote on 2022-04-01, 15:11:
Took a moment and ran a benchmark myself too. […]
Specs:
RTL8139C PCI NIC
8GB CF card as HDD
I like your mobo.
Which version of the video card is that? Do you have a pic of the card?
Using vga I assume?
I haven’t had much luck getting my mx400 working on my tyan s1564d
Reply 71 of 103, by GigAHerZ
Specs:
RTL8139C PCI NIC
8GB CF card as HDD
Same machine, but now used RivaTuner to OC the card a bit.
I achieved 255MHz core, 380MHz RAM.
138.02 KiB
Sphere478 wrote on 2022-04-01, 16:26:
I like your mobo. […]
Specs:
RTL8139C PCI NIC
8GB CF card as HDD
I like your mobo.
Using vga I assume?
My MX-400 has only VGA. And yes, I use it together with a very nice high refresh rate Sony Trinitron CRT. (CPD-G200p)
1.71 MiB
1.34 MiB
Reply 72 of 103, by Sphere478
GigAHerZ wrote on 2022-04-01, 17:17:
Same machine, but now used RivaTuner to OC the card a bit. I achieved 255MHz core, 380MHz RAM. gfx_oc.jpg […]
Specs:
RTL8139C PCI NIC
8GB CF card as HDD
Specs:
RTL8139C PCI NIC
8GB CF card as HDD
I like your mobo.
Using vga I assume?
Thanks 😀
I wish mine was red. It’s a tan colored one. But it has dvi.
Re: Geforce 2 mx 400 woes
Reply 73 of 103, by Garrett W
Specs:
RTL8139C PCI NIC
8GB CF card as HDD
That's pretty cool. You might be able to achieve even better performance if you limited yourself to just 64MB RAM, not just in 3DMark 2000 but for most games you'll ever play on this. This has been discussed before, but the i430TX chipset that your motherboard integrates can only cache up to 64MB with performance degrading after that point.
Reply 74 of 103, by GigAHerZ
Garrett W wrote on 2022-04-01, 18:20:
Specs:
RTL8139C PCI NIC
8GB CF card as HDD
No worries. I use top 192MB of ram for ramdisk and Windows only recognizes 64MB 😉
Reply 75 of 103, by Sphere478
GigAHerZ wrote on 2022-04-01, 18:23:
Specs:
RTL8139C PCI NIC
8GB CF card as HDD
🤔 heh, put the swap file on it😂
Reply 76 of 103, by MarmotaArmy
Hello
With a NVS 280 PCI I got : 957 3dMarks (3dMark 2000) , using the 45.23 drivers
Pentium MMX 233
MSI 5128 Motherboard
256kb Coast Module
64 MB EDO RAM
a PCI USB2.0 card
Windows 98 SE
This is my first post, I'm glad to be here with you.
Reply 77 of 103, by Putas
With such memory it should be a MX200, or am I wrong?
Reply 78 of 103, by GigAHerZ
Putas wrote on 2023-02-15, 13:32:
The card identifies itself as MX400, just like the sticker says.
Maybe this is what a MX400 PCI variant was like?
Reply 79 of 103, by Sphere478
See if score goes up without usb card
