VIA zero bytes AGP memory bug | Navigation thread
Reply 60 of 70, by Sly_Botts
Here's what I had to do.
Getting my ASUS A8V-MX to work with my Radeon x800 Pro.
It is possible to commit no errors and still lose. That is not a weakness, that is life.
Reply 61 of 70, by bloodem
Sly_Botts wrote on 2026-09-06, 14:38:
The bug described in this thread affects Windows 98 (not applicable in your case, since you used Windows XP).
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 62 of 70, by mockingbird
bloodem wrote on 2026-09-06, 16:41:
My previous challenge in this thread stands. Thus far, no one has been able to provide any empiricism in that the massive performance advantage of a PCIe video subsystem can't make up for the lack AGP texture acceleration.
I'll be glad if someone can prove otherwise.
(Decommissioned:)
Reply 63 of 70, by bloodem
mockingbird wrote on 2026-09-06, 17:15:
We already know that PCI Express is king on Windows 98 (I have one such system running a Core 2 Duo E8600 and a Radeon X850XT PE and saying that it's fast would be a major understatement).
Still, not really relevant for the VIA AGP bug itself, is it? Or maybe I'm misunderstanding what you mean.
Reply 64 of 70, by Sly_Botts
I plan on giving it a shot over the next few days I'll get back to you if I get anywhere.
Reply 65 of 70, by Dothan Burger
bloodem wrote on 2026-09-06, 17:25:
I agree, the only GPUs better in AGP than PCI-E are GeForce FX cards.
Reply 66 of 70, by Sly_Botts
So my motherboard doesn't seem to have this issue.
Asus A8v-MX.
VIA K8M800
I have win98 se running with ATI x800 pro. 3dmark tests running smoothly.
Reply 67 of 70, by Geri
Bruno128 wrote on 2023-08-14, 12:04:
collectively known as "VIA 0 bytes AGP memory bug" or "VIA AGP GART bug".
This is not a bug. Its a feature.
Manufacturers did this intentionally: few years into the standard, nerfing basically all AGP features (not just agp memory but the rest of the special features too).
The reason for this is, they never worked as intended in the existence of agp standard, and causing stability or severe performance issues.
Eventually the manufacturers realized they have to use whitelists if they wanted to safely allow certain features.
As these features in practice bring almost nothing to the table, they stopped caring, and AGP as a standard turned into merely a bandwidth increasing standard.
Under linux, they didn't had to remove too much of them, because overwhelming majority of them never actually got implemented.
Also most of the AGP 8x motherboards will outright run 4x in secret, or even if the transfer rate is reporting 8x, all the new 8x features will be disabled, otherwise the system would be hard crash in every minute or so.
For example with the previously mentioned 775dual-vsta, you have to manually disable certain agp features in the bios (such as agp power calibration) to have agp 8x mode even work with certain newer graphics cards, or limit the agp speed to 4x. Not to mention you frequently have to test like 3-4 graphics drivers to find one which works on these newer via chipsets, because the chipset is quite buggy (the pci-e implementation is buggy here as well, but thats offtopic now).
In short, you can safely ignore the missing features and be happy it even works, and operates without stability issues.
When i used a 3850 agp in my 775dual-vsta i also had to play with every settings, and block certain features in the bios till i finally had agp8x working properly without stability issues, but agp 4x mode worked fine out of the box, in retrospect i would just simply set the speed to agp 4x and not bother with it.
TitaniumGL the OpenGL to D3D wrapper:
https://titaniumgl.uni.hu/index.html
Reply 68 of 70, by Zoomer
Geri wrote on 2026-09-11, 08:34:
You're throwing everything together and overgeneralize. This topic is only about the very specific VIA chipset bug, that is observed only on some motherboards, chipset revisions and OSes, namely (but not limited to) Asrock 775dual vsta and its siblings.
It is confirmed, extremely specific bug, that applies only to Windows 98, degrading the AGP GPU performance significantly.
The same system running Windows XP won't be affected by this bug. In some cases, rolling back to an earlier BIOS revision would remedy the situation, however not all late motherboards have this bug-free revision available.
In other words, this is very likely a software (probably BIOS level) bug and has nothing to do with white lists, driver version combination, etc.
So, please don't be that dismissive and don't derail this thread.
MB: Asus P3B-F 1.03 (2x ISA)
CPU: PIII-S 1.4GHz/VIA C3 800MHz
RAM: 256MB PC133
Video: GeForce 4600Ti/Voodoo 5 5500/Voodoo 3 3500 for DOS Glide
Audio: SB16 OPL3 + Audigy Platinum Ex
OS: Windows 98
Reply 69 of 70, by Geri
Zoomer wrote on 2026-09-11, 09:23:
You're throwing everything together and overgeneralize. This topic is only about the very specific VIA chipset bug, that is observed only on some motherboards (...)
I don't see how i derailed the conversation by using the very specific motherboard as an example which is also listed in the first message of the topic.
What you are chasing after, is just a symptom, and you are missing the point. The real problem are multiple layers of design flaws which are being exposed as various types of strange behavior, if you don't understand this then you will not be actually understand your problem itself.
Reply 70 of 70, by bloodem
Geri wrote on 2026-09-11, 11:00:
This behavior only occurs in Windows 98 and it's a BIOS bug, as it has been extensively discussed and confirmed through testing in the past (I know I've spent tens of hours debugging this issue many years ago).
Not a design flaw, because it can't be reproduced in Windows XP at all, and a design flaw would not be fixed by simply reverting to a BIOS version that was released prior to early 2005.
