Socket A: Nvidia vs Via - battle of the platforms!
Reply 600 of 819, by nd22
10. Same resolution but with maximum details, including sound:
Abit KT7A-raid
Reply 601 of 819, by nd22
Abit KR7A-raid
Reply 602 of 819, by nd22
Abit AN7
Reply 603 of 819, by nd22
11. We increase the resolution to 1280*1024, max details:
Abit KT7A-raid
Reply 604 of 819, by nd22
Abit KR7A-raid
Reply 605 of 819, by nd22
Abit AN7
Reply 606 of 819, by nd22
12. Same resolution, 1280*1024, but this time with sound:
Abit KT7A-raid
Reply 607 of 819, by nd22
Abit KR7A-raid
Reply 608 of 819, by nd22
Abit AN7
Reply 609 of 819, by nd22
13. And finally, the grand daddy in the retro world: 1600*1200!
Abit KT7A-raid
Reply 610 of 819, by nd22
Abit KR7A-raid
Reply 611 of 819, by nd22
Abit AN7
Reply 612 of 819, by nd22
14. The final and most demanding settings: 1600*1200 max details with sound:
Abit KT7A-raid
Reply 613 of 819, by nd22
Abit KR7A-raid
Reply 614 of 819, by nd22
Abit AN7
Reply 615 of 819, by nd22
Aquamark 3 summary: any hope for KT133A to finally catch up with its DDR cousins is gone! In all tests that include sound there is a large performance hit compared to KT266A and nforce2 ultra; also as the resolution and level of details increase the delta between KT133A/SDRAM and KT266A/nforce2 grows! The more demanding the settings the bigger the hit on performance!
Nforce2 ultra does not have an advantage over KT266A in tests done without sounds; however in all test with sound there is a minimum 10% advantage NVidia has over VIA!
Based on the average FPS, sound storm helps nforce2 ultra secure the first clear victory!
Reply 616 of 819, by nd22
As I forgot to take some screenshots with the KT7A+1200B containing the system info I am going to put up now a few.
Abit KT7A-raid is a well known board who gets a lot of attention so I decided to put together fast a system with the second board with which I checked the results obtained with the first.
Very little recognition and very little attention is given to another highly capable Abit board: KT7E - the twin of the famed KT7A!
Reply 617 of 819, by nd22
This board has the KT133E chipset according to Wikipedia, however it is practically a KT133A and supports all Thunderbird models with both 200 and 266 MHz FSB. I must mention that there is absolutely no way someone could install a 266 MHz T-bird on the KT7-raid. However KT7E runs just fine with all T-birds and also with all Palomino and T-bred up to 2000 just like the KT7A.
In the pictures below you can see the clock generator and the 686B southbridge together with the most relevant BIOS settings.
Reply 618 of 819, by nd22
15. Going back to the benchmarks we are now at 3dmark 2000.
First is 1024*768 resolution with default settings - that means 16 bit colors depth!
KT7A-RAID
KR7A-RAID
AN7
Reply 619 of 819, by nd22
16. Results at 1280*1024 resolution:
KT7A-RAID
KR7A-RAID
AN7
