Reply 6160 of 32070, by bjwil1991
- l33t
wrote:I have a PC Speaker hooked up to my Lo-Tech Tandy Compatible Sound Card that sounds distorted, and I don't know if I should make a cable that has a 100ohm resistor and a 1ųf capacitor or solder on a potentiometer (volume wheel/knob) to the speaker to remove the distortion. I'm also planning on making an IBM PC Speaker wire from the motherboard to the Lo-Tech Tandy Compatible Sound Card with a 100ohm resistor and a 1ųf capacitor as well to prevent distortion and shorting the motherboard.
Found the issue. Apparently, I had the volume set to max on the card, so after turning down the volume to the right setting, it's playing back without issues. My next project would be to hookup the PC Speaker header between the motherboard and Tandy card.
