Battle of the platforms: socket 754!
Reply 620 of 731, by nd22
greasemonkey90s wrote on 2026-01-04, 22:45:
Does the kv8 pro support Newark at all? its the only reason i kept my dfi nf3 250gb and msi neo's. Awesome work by the way . big s754 fan but i stop at agp based boards though.
Thank you sir. I am sorry but I do not have any mobile Athlon 64's. I tested personally the following processors:
1. Athlon 64 2800 ClawHammer revision CO
2. Athlon 64 3000 clawhammer revision CG
3. Athlon 64 3200 Newcastle
4.Athlon 64 3200 Venice
5. Athlon 64 3400 clawhammer revision CO
6. Athlon 34 3400 clawhammer revision CG
7. Athlon 64 3400 Newcastle
Reply 621 of 731, by nd22
AlexZ wrote on 2026-01-05, 14:19:
So Radeon X1950 PRO, despite being a significant upgrade from 7800 GS still does not deliver satisfactory results in Quake 4 and FEAR. Compromise would have to be made in resolution/details. It's a decent choice if one can get it cheap in AGP version. For PCIe there are much better alternatives.
For PCIe ABIT board, one should consider at least slim NVIDIA GeForce 9800 GT (to avoid blocking SATA ports). It is 1.5 years newer and a significant upgrade from Radeon X1950 PRO. GeForce GTX 2xx is a safe bet, but they are large and won't fit well on some 754/939 boards due to blocking SATA ports. They also run hot and need repasting/cleaning/BIOS fan curve adjustment to live long.
I will say at the end a few words as a conclusion but I can already state that I strongly believe that socket 754 is a replacement year for year for socket A that is the 2000 - 2004 period. I believe that year 2005 games are already pushing the platform too far! Either, as you said it, a good enough GPU to play 2005 games is going to block the SATA ports or you are going to exceed the 2gb memory limit that is required on socket 754 in order to have the CPU run in sync with the RAM.
Reply 622 of 731, by nd22
57. Final test is the infamous Tom2D. After repeating the test countless times on all the systems the following scores remain:
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 623 of 731, by nd22
VIA crushes all competition with the Clawhammer 3400! All the advantages in the previous tests for the nforce4 is for naught as the colossal score of the VIA K8T800 PRO obliterates everything else and washes away all NVIDIA's nforce4 victories in the vast majority of previous tests!
Reply 624 of 731, by nd22
Clawhammer has been tested through all 57 benchmarks. No score summary yet as we head into the last chapter: Newcastle with radeon x1950 pro on all 4 platforms. After a simple CPU change we now got a bump in speed by 200mhz and a L2 cache reduction to 512kb:
C. ULI
D. nforce4
Reply 625 of 731, by nd22
A. nforce3
B. VIA
Of course the FSB of all systems has been manually set to 200 before the start of the tests!
Reply 626 of 731, by nd22
With all 4 systems ready to go it is time for the final battle! As usual the first test is Code creatures pro - a directx 8.1 benchmark - at the default settings:
1. Code creatures 1024*768
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 627 of 731, by nd22
2. Again an excellent start by nforce4! 1024*768 and sound is next:
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 628 of 731, by nd22
3. CODE CREATURES PRO 1024*768 AA 4 X:
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 629 of 731, by nd22
4. CODE CREATURES PRO 1024*768 AA 4X, SOUND enabled:
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 630 of 731, by nd22
5. CODE CREATURES 1280*1024 max details:
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 631 of 731, by nd22
6. Code creatures 1280*1024 max details with sound:
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 632 of 731, by nd22
7. Code creatures pro at the highest resolution: 1600*1200
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 633 of 731, by nd22
8. Final and most demanding settings: 1600*1200 with sound enabled
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 634 of 731, by nd22
Nforce4 is starting strong, leading across all resolutions and settings! Let's see if the trend continues with Aquamark 3, a DirectX 9 benchmark that should be more demanding than CC pro.
Reply 635 of 731, by nd22
9. Aquamark3 - default score:
A. nforce3
B. VIA
Reply 636 of 731, by nd22
C. ULI
D. nforce4
Reply 637 of 731, by nd22
Excellent score obtained by nforce4 - best of all 4 platforms!
10. Aquamark3 1024*768 max details including sound:
A. nforce3
B. VIA
Reply 638 of 731, by nd22
C. ULI
D. nforce4
Reply 639 of 731, by nd22
11. nforce4 stays in the lead. We increase the resolution to 1280*1024 max details, no sound first:
A. nforce3
B. VIA
