AMD K6 3DMARK, aiming for stars.
Reply 620 of 655, by schlang
my friends how big is the penality on using a gf4 4600 with a k6-3+? 5%? 10%? more?
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 621 of 655, by noshutdown
schlang wrote on 2025-08-09, 03:08:
extreme, i would say that the k6-3+ would only unleash less than a quarter of the ti4600's full power.
Reply 622 of 655, by schlang
ok let me rephrase my question: will my system be faster if I replace the gf4 with a gf3, and if so how much?
Reply 623 of 655, by Mamba
Gf3 and gf4 have the same features.
I guess in dx8 games gf4 will be faster.
In benchmarks like 3dMark 2000, not at all.
But I guess you do not live to reach the better score in benchmarks (?).
If you have a good GeForce 4Ti that works well in your system, stick with it.
If you want to see better scores, you need a GeForce 3, not because it is faster, but because it is compatible with older drivers with far lesser overhead that will behave better with poor AGP implementation of SS7.
Reply 624 of 655, by noshutdown
schlang wrote on 2025-08-09, 12:50:
i don't think it will be, but driver version matters.
in a general trend, older drivers are more friendly to slow cpus, while newer drivers will sometimes run faster with a very fast cpu, and are often needed to run newer games.
for k6 cpus and geforce256 to geforce4, i think 30.82 is a generally suitable version.
Reply 625 of 655, by DarthSun
K6-III+ / R9800Pro is the real deal in this era. The rest is just a fairy tale.
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 626 of 655, by Mamba
DarthSun wrote on 2025-08-09, 18:58:
I have yet to see a (really) working 9800 pro on a SS7 system.
Not sure what you mean…
Reply 627 of 655, by schlang
Mamba wrote on 2025-08-09, 13:38:
Gf3 and gf4 have the same features. I guess in dx8 games gf4 will be faster. In benchmarks like 3dMark 2000, not at all. But I g […]
nah idc about benchmarks, I did that back in 1999 and 2000 when we had nothing else to do.
thank you my friend, I will just keep the gf4 because it has dual head and outputs both vga and dvi at the same time
Reply 628 of 655, by DarthSun
Mamba wrote on 2025-08-09, 21:27:
Didn't you see...? I already published it in 2021:
https://logout.hu/bejegyzes/darthsun_a_legval … sztek_es_k.html
Reply 629 of 655, by Mamba
Sorry but this is cherry picking to me.
You were successful in 2021 with your MVP3G2 and 9800pro combination.
This does not mean that it can be done on a regular basis with any SS7 motherboard.
At all.
Reply 630 of 655, by DarthSun
Mamba wrote on 2025-08-10, 06:09:
Sorry but this is cherry picking to me. You were successful in 2021 with your MVP3G2 and 9800pro combination. This does not mean […]
At all.
For example, the R9800Pro doesn't work on the P5A-B, it doesn't even give a picture, but it does on all other SS7 motherboards.
Reply 631 of 655, by Mamba
DarthSun wrote on 2025-08-10, 11:41:
At all.
Ok,
Show me your SS7 system with a working 9800pro.
Reply 632 of 655, by DarthSun
Mamba wrote on 2025-08-10, 12:00:
At all.
Ok,
You can find it at the link to the article, but there are also direct pictures:
The attachment SS7_R9800Pro_1.jpg is no longer available
The attachment SS7_R9800Pro_2.jpg is no longer available
The attachment SS7_R9800Pro_3.jpg is no longer available
The attachment SS7_R9800Pro_4.jpg is no longer available
The attachment SS7_R9800Pro_5.jpg is no longer available
Reply 633 of 655, by Mamba
It is again the mvp3g2 from your test in 2021.
You said the 9800pro works everywhere.
I do not think so.
Reply 634 of 655, by DarthSun
Mamba wrote on 2025-08-10, 12:42:
I do not think so.
I wrote that it doesn't start in P5A-B. It works in my other boards.
The other boards:
- Epox MVP3C2 - works
- PCChips M577 - works
- Shuttle HOT591 - works
- Soltek SL54U5 - works
Reply 635 of 655, by Sphere478
gf2 and gf3 with the right driver are among the fastest cards (with the right driver) that you can possibly run on a k6-3+ as far as 3dmark is conserned.
I however have had basically zero luck getting them to work. My go to are radeon 7500, 9200, 9250, 9800 pro
Mobo and card combos that work together are hit and miss. I have made several systems with luck for 9800pro but indeed, not all like it. That goes for any card though.
9250 and 7500 seem to work in the most mobos in my experience
Sphere's PCB projects.
Reply 636 of 655, by frankmonk
Okay, so far i have pretty good results with my ga-5aa 3.2 Board 256mb single ram stick and ti500
My k6-3+ is running at 6x100mhz
Im pretty sure that i can get 5000+ points when I install a SATA PCI Controller and push with 5.5x115
Current Score is 4717 at 6x100
Reply 638 of 655, by frankmonk
Win98se regular, 77.76,AGP 1.82, wpcredit memory latency tweaks only, BIOS fastest settings
Reply 639 of 655, by Mamba
My contribution here.
Ga-5ax 5.2 (E) bios F4 Soggi
K6-3+ 115*5.5 ext cache enabled
256mb cas2
Geforce 2 GTS 220 core 380 memory - Det 7.76
Ali agp 1.82
GAT 2
Windows 98 SE with unofficial sp2
Rloew memory patch (somehow it gives me better results even with only 256mb)
Opti USB card 1.1
Will try faster cpu frequency with disabled ext cache
Not sure there are further bios tweaks I can use, know very little about that.
