Reply 6640 of 30158, by PTherapist
Unsoldered a leaked battery from an old Parallel/Serial/Game/RTC ISA card. Luckily the damage is mostly just surface level coating around the battery area, no damaged traces - if this was installed in a PC, instead of laying flat in storage, the damage could have been much worse! I don't have any motherboards on which to test the card at present, but at worst it may need 1 resistor replacing which has a slight green coating (though it scrapes away pretty easily).
Also did some experimenting on my 386SX system, installed GEM/3 Desktop for old times sake. I'm looking to build a 286 PC soon and will probably go with GEM for it's GUI, so just getting reacquainted.
