Mamba wrote on 2026-09-11, 18:33:
$SOLID$ Necro wrote on 2026-09-11, 07:10:5185 3DMARK 2000
324 CPU score
Changed the motherboard from a GA 5 AX Rev 4.1, to the P5A-B Rev 1.04.
3.8VIO setting allowed th […]
The attachment 5185 3D2K K63@632 GF 3.jpg is no longer available
The attachment 3D2k CPU 324 points.jpg is no longer available
The attachment K6-3 632mhz CPUZ.jpg is no longer available
The attachment CAS 2-2-2 128 MB ram 3D2k.jpg is no longer available
5185 3DMARK 2000
324 CPU score
3.8VIO setting allowed the CPU to run at 5.5x115FSB, I was stuck at 6x105=630mhz on the GA5 since it stuck at 3.5v VIO.
CPU is a K6-3+ 400 ATZ using 2.4v.
PNY GF3 TI200@ 220x460
Nvidia 7.76 Det. GPU driver
ALI 1.82 AGP driver, Turbo mode enabled
2X AGP and 129MB aperture.
128 MB Ram @ 2-2-2-6-9-8
Win 98SE/ DX- 7
6x multiplier slows down memory read/write values.
5.5x is perfect for K6plus
I had heard that before, but I am not so sure its true in call cases. I had to use 6x because I was limited to 105FSB on the GA5 AX due to no VIO adjustment o the rev 1.04 I have. That same board ran at 125fsb with a K6-2 500, so the 2+ and 3+ seem to need more VIO (Using 3.6v) to get high FSB from the newer style chips with Cache on them. I dont think it hurts that much if at all, will have to do further testing to confirm.
I was able to break 5k (5018) using 6x at 632mhz on the GA 5 AX . 5185 was my previous best on the P5A B with 5.5x115, pretty sure the extra points came from the increase in FSB and the P5A B having more memory bandwidth (not 6x vs 5.5) and other optimizations on the ASUS since the CPU speed was similar. Adding a second stick of 128mb (265mb total) was worth a few points, many people report a single stick of 128mb is faster, but I am over 5200 now!
I got your PM, sorry but I am unable to reply, not enough time on this forum. I can post detailed pics here later if that helps.
