Reply 6880 of 6888, by RandomStranger
Joseph_Joestar wrote on 2025-05-21, 07:26:
Finished Tomb Raider (2013).
Ugh. I hate that game with burning passion of a thousand Suns.
Anyway. Still on Morrowind, about 120 hrs in. I didn't have as much time to play lately, but at this point, I'm the one who takes his time with the game avoiding the main quest line.
Reply 6881 of 6888, by ElectroSoldier
Just bought TRS2004.
Seems like there is a bug that makes the trains drive backwards instead of forwards when you set it to drive to a particular place which is weird.
The played scenarios dont seem to have an actual end to them.
The idea on one level is to stock up fuel in the deep mine to make it work, then take coal to the power station so the lumber mill can work, so you can move the logs to the lumber mill. Once fully stocked its over.
But I cant seem to get enough fuel to keep feeding the mine. Just keeps filling the train with aviation fuel instead of diesel.
Very strange game.
Reply 6882 of 6888, by badmojo
I've been trying to play my old favourite time waster, Trials Evolution: Gold. But it seems that those fuckers Ubisoft have been messing around with that damn 'Connect' app, and now it asks me for a password every time I load the game. This is unworkable - I've tried all of the things suggested on the interwebs but nothing fixes it. I read somewhere that this is intentional for older titles, so maybe there is no fixing it. I've tried the dodgy crack on GameCopyWorld and it did actually allow the game to run without Connect, but it was super laggy.
Does anyone know if it's possible to play this game without Ubisoft Connect? There's a DVD version around I see (I bought it on Steam), but from the screenshots of the DVD case I can see that it's 'Connect Enabled', so I assume I'd still be dealing with it even if I installed it from DVD.
Why does everything have to be so hard?
Reply 6883 of 6888, by Joseph_Joestar
badmojo wrote on Yesterday, 07:44:
Yeah, Ubisoft DRM from that time is peak enshittification. I'm in the same boat with Splinter Cell: Conviction. For that game, I just gave up on the PC version and played it on my Xbox 360. True, it runs in 720p @ 30 FPS, but at least no internet connectivity is required.
BTW, @DosFreak mentioned an uPlay emulator here. Not sure if that works for your game though.
Reply 6884 of 6888, by badmojo
Joseph_Joestar wrote on Yesterday, 07:57:
Thanks but I couldn't find an emu option sadly. Out of desperation I went back and tried the GameCopyWorld nocd crack options again. There are 2 there, the first one really triggered Microsoft defender and was instantly deleted regardless of the browser I used, the second one caused the game to not run properly as mentioned previously.
Risking life and limb I turned off Defender and tried the first one (PROPHET), and it works great. I've had to put an exclusion in Defender to stop it from deleting it on sight but I've been using GameCopyWorld cracks for years without incident, so I'm sure it'll be fine. Bypassing Uplay Connect is worth the risk anyway - I've now uninstalled it and feel a great has been weight lifted 😁
Reply 6885 of 6888, by appiah4
badmojo wrote on Yesterday, 12:10:
You could consider running it in a VM..
Reply 6886 of 6888, by badmojo
That's a good thought but the lazyness is strong with this one 😅
Reply 6887 of 6888, by DracoNihil
Managed to get the mediocre MS-DOS port of T-MeK running again.
I don't understand why I'm so driven to these stupid games.
― Κυνικός Δράκων
Reply 6888 of 6888, by newtmonkey
The Elder Scrolls: Morrowind
I've tried playing this many times over the years, beginning with the XBOX version and then the PC version once I upgraded my PC. I thought the game was very interesting, but never got very far into it because I wasn't very disciplined at playing games back then. That's especially true for RPGs, which I played more as sandboxes simply to explore and see what I could find, and I'd usually stop playing if I got stuck or the challenge became too high... only to restart months later and do it all over again.
Since then, I've learned how enjoyable it is to figure a game out and complete it, and especially over the last few years I've been having a blast completing a bunch of console and PC RPGs. That includes Skyrim (bland, but nice graphics and music), Oblivion (surprisingly decent once you figure out how the level scaling works), and Fallout 3 (annoying), so it's time now to finally play what many RPG fans consider to be one of the top RPGs of all time: Morrowind.
I played Skyrim and Oblivion as a fighter with some minor magic abilities, so I decided to go with a pure mage for Morrowind. It seemed like it would be a nice change of pace, and I read that the magic system was quite interesting, complete with spell creation, equipment enchantment, and alchemy.
Compared with my attempts at playing the game as a fighter in the past, I had a pretty rough start as a pure mage. Everything a mage wants to do costs money, and it's difficult to make money early on without fighting... and you want to avoid fights against enemies that would actually drop coins or equipment you could sell for coins (and you also don't want to carry around too much stuff to sell, since it negatively affects your fatigue, which makes casting spells harder). Following the main quest, I arrived at Balmora, where I joined the Mage Guild and started doing the trivial tasks I was assigned. One problem here is that Mage Guild quests don't reward you with coins, but instead with potions and scrolls. These are definitely useful, but I was really lacking in funds to create spells and enchant some equipment.
However, with a bit of exploration and by fighting enemies I could reliably kill with my spells, I ended up making just enough to enchant a dagger with the "Bound Dagger" spell on hit, which basically transforms the dagger into a high-level weapon for a short period of time. It takes 18 seconds to recharge, so if you set the duration to 19 seconds, it will never run out of charges.
After some more exploration, I ran into a traveling merchant who wanted to be escorted to her destination, and promised a reward of a pair of "Boots of Blinding Speed." Due to how slow walking is in this game, I knew I had to have them, and so I did it. The funny thing about these boots is that they are sort of a joke. They do make you walk/run REALLY fast, but the "blinding" part is not just a colorful description; they cast a 100% blind spell on you when worn. My character is a Breton, so I have 50% resist magic, which means instead of going completely blind, the screen just gets somewhat dimmer. It's playable, but I wondered if 100% resist magic would actually prevent blindness completely... I did some research online and found that resistances stack, so the next step was to make myself a cheap 50% resist magic spell to cast before putting on the boots. This worked great, and is quite a game changer for a mage. It's not only easier/faster to get around, but you can easily outrun enemies, and since walking with the boots on is much faster than even running without, you really never have to worry about becoming fatigued just by running around.
My next step is to go around to other Mage Guilds and do their quests, and try to make enough money to get some new spells and play around with making some custom spells.
So far, the game is simply amazing. Each class has real strengths and weaknesses, so as long as you aren't playing as a custom class, you really have to sit there and think about how to play the game properly as your chosen class. Exploration is a joy thanks to the unique world and hand-placed content. The world itself is fascinating and feels totally alien at times, especially compared with the generic "high fantasy forests and castles" of Oblivion and generic "viking world" of Skyrim. I also really like the conversation system in Morrowind, though it has been criticized as the elder scrolls: wikipedia. It's just surprisingly enjoyable and immersive to walk into a new town, talk to the first person you see, and ask directions... and instead of marking the location on your map, the game provides you with actual working directions to follow ("head east toward the river, cross the bridge, then head south. His house is right next to the bookseller there").
