Reply 6960 of 58564, by alexanrs
jwt27 wrote:
Most 19" and 21" screens from that time support 1600x1200 at 75Hz, and usually the "recommended" resolution was 1280x1024 (5:4) at 85Hz. They're very common now around here.
We were talking 17" (unless I'm seeing things again, which could happen), that's why the resolution amazed me.
Reply 6961 of 58564, by Skyscraper
The mystery box I bought arrived today 😀
Its was a heavy package and I had to carry it 1.5 km (about a mile in medieval units)
Inside the box we find a 286 system with a HDD 😀
A pretty fast 286, with the standard free pubes for a real authentic experience.
The video card seem to be really nice, an 8 bit ISA VGA card compatible with the IBM 5150 and it does also support both EGA and CGA!
Reply 6962 of 58564, by Godlike
Mystery box looks good, try Catacomb 3D on it
I see it comes with FPU as well right?
ASUS P2B-F, PII 450Mhz, 128MB-SDR, 3Dfx Diamond Monster 3D II SLI, Matrox Millennium II AGP, Diamond Monster Sound MX300
Reply 6963 of 58564, by obobskivich
Stiletto wrote:
Neat. What software does it use to do that, I am pretty sure Windows can't do anything like that natively?
Windows, as pointed out, can rotate it to either "side." To sub-divide it I'm using DisplayFusion Pro, but I know that ATi Hydravision (which is a free optional component of Catalyst) offered a similar "grid" feature at least through XP (I don't know if it still exists in Vista/7/8).
Reply 6964 of 58564, by Skyscraper
I do not think there is a FPU installed but there is a socket for a 287.
Reply 6965 of 58564, by Godlike
Is it works then?
Reply 6966 of 58564, by kithylin
Local used computer hardware store that's closing down is selling their "stock", display cases and other things inside. Part of that is some "card storage blocks" they had in the back and brought out recently. They're just blocks of wood with slits cut in em, but spaced perfectly to store lots of dual-slot cards, or single-slot cards, and just spaced perfectly so that they don't actually touch each other no matter which way they tilt. The "brackets" on the end touch but not the actual cards. Well I picked up 4 blocks @ $2.50 each. I finally have a proper way of storing all my cards where they won't get damaged. Happy days.
Larger: http://www.outfoxed.net/wood-block-1.jpg
Larger: http://www.outfoxed.net/wood-block-2.jpg
This is just a fraction of my collection, and I need proper shelves to keep this stuff on some day. For now at least they're not just laying around random on most of my desks anymore.
Reply 6967 of 58564, by 5u3
luckybob wrote:
5u3 wrote:
luckybob wrote:
You ladies need to get on my level. http://m.ebay.com/itm/221057230823
Neat!
Does that one support proper VGA (720x400/640x350/640x400 [not just the VESA modes], 4:3 aspect, 70Hz) on the 15-pin sub-D input? This is difficult to test, but maybe you already know...
at first I was like "WHAT?" then i realized my particular monitor ONLY has dvi input. The one i linked obviously is an update, and has the full gamut of inputs.
Thanks anyway! Yes there are obviously two versions around, and the one with the analog inputs could possibly be a nice solution for current and retro gaming usage. According to some reports it is IPS, but can apparently handle more than 60 Hz, and it has high resolution, which is always good with interpolation. However, I've found nothing on aspect ratio handling or low resolution support, and I'm not willing to risk 650€ to find out...
Reply 6968 of 58564, by Sutekh94
I got my Inspiron 8100 in today! 😎 Did notice quite a bit of damage around the USB ports, more than likely because of a combination of shipping hijinks and mediocre packaging by the seller. Also, it was very dirty and had that musty basement smell. Nonetheless, it does work perfectly, despite a tiny bit of screen damage that might be visible in the pictures.
Specs:
Intel Pentium III 1.0GHz
256MB PC100 RAM
nVidia GeForce 2 Go, 32MB
ESS Maestro 3 audio
20GB Hitachi HDD
Windows 98SE
And this is Unreal Tournament, running smoothly at native resolution (1400x1050) with maxed-out settings. UT's the only game I've tried out on this so far.
My YouTube | My DeviantArt
Reply 6969 of 58564, by Slaventus86
My dreams come true! I've got THE BEAST - Evans & Sutherland SimFUSION 6000q with FOUR Radeons 9700 Pro on it and 1GB RAM total!
I've also got original driver disc, I can make iso-image if needed.
Videocard Virtual Museum
Reply 6970 of 58564, by luckybob
Oh my...
Reply 6971 of 58564, by Artex
Whoa! I never heard of that one but damn!
Reply 6972 of 58564, by rick6
And the only one you'll ever need 😁
Joking, but try Unreal 1 with the latest patch also. I was able to make it run quite good (65+ fps) on a cheap Geforce 2 mx400 with both S3TC and detail textures (16bit).
What sorcery is this?
I didn't even knew such thing existed. Benchmark the hell out of it and show us the results 😀
My 2001 gaming beast in all it's "Pentium 4 Williamate" Glory!
Reply 6973 of 58564, by havli
Is it possible to run it in normal AGP (AGP Pro) MB?
Btw... I can't help myself 😁
Reply 6974 of 58564, by alexanrs
I... never knew this card could even exist oO
It is like better than Crossfire before Crossfire... on AGP!
Reply 6975 of 58564, by jwt27
Whoaaa. I thought 3dfx/Quantum3D was the only company crazy enough to use multiple GPUs on one card.
Reply 6976 of 58564, by Callahan
Came to me today Intergraph TD-30, in excellent condition. I bought it for $ 30 here in Poland.
Clean, working with dual silent fans.
Original keyboard and mouse, only speakers do not work (i think amplifier is damaged)
(2nd cpu with green heatsink from old zenith z station)Dual P133, 4x16MB Simm Ecc, CMD Ultra ATA PCI,
Integrated Onboard: infamous 430NX, Matrox Millenium, Adaptec 7850 SCSI, PCMCIA, AMD Network (Eth with TokenRing), SB Vibra 16.
Cpq: ap550(2x1G/256k), sp750(2x900/2MB), 5100(2xpII300)
TD-30 2xP166 NT 3.51
HP Vectra XU 6/200 2x PIIOD 512MB FPM Banshee
Super S2DG2@550/2MB SCSI 15k V5 5500
P4T533-C P4 3,06 Ti4600
Dell T700r @P3-700 V3 3500
PR440FX-2x PIIOD Voodoo 4500 PCI r320 CT1920
Reply 6977 of 58564, by F2bnp
Slaventus86 wrote:
My dreams come true! I've got THE BEAST - Evans & Sutherland SimFUSION 6000q with FOUR Radeons 9700 Pro on it and 1GB RAM total! […]
God damn...
Reply 6978 of 58564, by Artex
Exactly what I thought... Alchemy!
Reply 6979 of 58564, by rick6
That should be a easy fix. Is that also an embedded microphone that i see on the keyboard?
