AMD K6 3DMARK, aiming for stars.
Reply 700 of 725, by MikArt
Some old SS7 benchs -
ASUS P5A rev. 1.03, ALi Aladdin V+ rev. E, ext. tag-ram
128MB / GF3 ti200
Win98
AliAGP 1.9
Nvidia 7.76
ALiAGP = Turbo, agp 2x
Stock:
The attachment 019.png is no longer available
120x5.5
The attachment 036.png is no longer available
The attachment 041.png is no longer available
124x5.5
The attachment 048.png is no longer available
The attachment 051.png is no longer available
Reply 701 of 725, by MikArt
WPC:
The attachment 015.png is no longer available
Reply 702 of 725, by MikArt
DFI K6BV3+/66 rev. B2, VIA MVP3
1MB L3
128MB / GF3
Win98
DX 8.1
VIA 4in1 v4.35 + Viagart.vxd v4.16
7.76_Ti_w9x
vlatency_v019
UDMA/66 tweak:
Stock:
The attachment 007.png is no longer available
120x5,5:
The attachment 066.png is no longer available
Reply 703 of 725, by MikArt
WPC:
The attachment 038.png is no longer available
Reply 704 of 725, by MikArt
Tekram P5M3-A+
VIA MVP3
1MB L3
The attachment 20260205_125926.jpg is no longer available
128MB / GF3
Win98
DX 8.1
7.76_Ti_w9x
vlatency_v019
The attachment 20260205_114410.jpg is no longer available
Stock:
The attachment 045.png is no longer available
WPC:
The attachment 017.png is no longer available
UDMA/66 tweak:
The attachment 032.png is no longer available
Reply 705 of 725, by MikArt
115 x 6
The attachment 071.png is no longer available
The attachment 073.png is no longer available
124 x 5.5
The attachment 056.png is no longer available
Reply 706 of 725, by MikArt
133 x 5
The attachment 062.png is no longer available
120 x 6
The attachment 20260205_124841.jpg is no longer available
Reply 707 of 725, by Mamba
MikArt wrote on 2026-10-01, 12:10:
Some old SS7 benchs - […]
128MB / GF3 ti200
Win98
AliAGP 1.9
Nvidia 7.76
Stock:
120x5.5
124x5.5
Your cpu is a beast
Reply 708 of 725, by MikArt
Mamba wrote on 2026-10-03, 14:11:
Your cpu is a beast
I can't send a PM, reply here.
Spoiler
I replaced the original cache on my P5A 1.03 with LP61L64128F-4:
The attachment 20241124_175017.jpg is no longer available
The attachment 20241124_174828.jpg is no longer available
The attachment 20241124_174737(0).jpg is no longer available
Reply 709 of 725, by Mamba
MikArt wrote on 2026-10-04, 11:00:
Your cpu is a beast
Spoiler
The question was, how did you get the cache working at such high FSB frequencies.
Reply 710 of 725, by MikArt
Mamba wrote on 2026-10-04, 11:23:
4 ns new cache vs the original 5 ns
It just works.
Of course, it also depends on the revision of the motherboard, the chipset version, VCCio, etc.
GA-5AA, FSB=135, winXP, L3=on:
Spoiler
The attachment 044.png is no longer available
Reply 711 of 725, by Mamba
MikArt wrote on 2026-10-04, 11:50:
4 ns new cache vs the original 5 ns It just works. Of course, it also depends on the revision of the motherboard, the chipset ve […]
It just works.
Spoiler
Same external tag ram chip?
I have exactly your P5a revision.
You just changed the chance chip??
Reply 712 of 725, by MikArt
Mamba wrote on 2026-10-04, 11:58:
Same.
Only cache chip.
Reply 713 of 725, by bloodem
What’s the purpose of that wire connected to one of the SRAM pins? It shouldn’t be needed for the cache upgrade…
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 714 of 725, by MikArt
bloodem wrote on 2026-10-05, 05:59:
In the early pcb revisions, this wire is not routed.
Reply 715 of 725, by MikArt
A16:
The attachment image-5.png is no longer available
The attachment 20250426_124944.jpg is no longer available
Reply 716 of 725, by Mamba
MikArt wrote on 2026-10-04, 12:04:
Same.
Only cache chip.
Can you share the type of chip used in P5a?
I assume it is pin to pin compatible?
Reply 717 of 725, by MikArt
Mamba wrote on 2026-10-05, 16:53:
obvious LP61L64128F-4
Reply 718 of 725, by Mamba
I see but this is 1mbyte, I mean just a pin to pin 4ns chip of 512kb.
I do not intend to do the 1mb mod.
Reply 719 of 725, by bloodem
Mamba wrote on 2026-10-05, 17:21:
If you simply replace the cache chip with a larger pin compatible version (like the aforementioned LP61L64128F-4), the board will work just fine and treat the chip as a 512kB SRAM (if you don't change the resistor configuration). I know I did this test on one of my P5A-B rev 1.04 boards and it worked fine.
Though, truthfully, you might as well just go all the way and increase the cache to 1 MB, changing the resistors takes a few minutes. 😀
