Reply 7020 of 59338, by Lukeno94
I ran some benchmarks on the laptop, they're on Phil's Ultimate VGA database. Going on what I can see from the system unit block diagram in the maintenance manual (which curiously never mentions the chipset outright - curious because it is very detailed otherwise, even to giving various pinouts), I think it has a random, proprietary Toshiba T6W23A chipset, which I can't really find any information on whatsoever, other than a magazine article that had a Satellite Pro 420CDS using said chipset in a comparison test. I do know that the chipset has no issues handling 6GB drives, although the drive isn't formatted as such (has two smaller partitions) - I installed it in another system, because I don't have a floppy drive for this system, and neither Windows 95 nor the laptop will boot from a CD. I was *very* lucky that mine came with the 32MB RAM card installed when I bought it, because those can be a bitch to find (proprietary to the model, or at least, the model line). As for 1MB v 2MB VRAM, I'm sure that there was at least one game I have that wanted a 2MB SVGA card to go with something like a P90 or P100, but I honestly don't remember what it was, and I may be misremembering.
Also, good luck doing LAN gaming - mine has no ethernet port 😜 The laptop has a microphone though, which is better than many modern ones - even though it was a bargain-basement laptop when new!
Reply 7021 of 59338, by devius
Doesn't it have PCMCIA slots? Mine also didn't have an ethernet card, but I bought a PC Card one and it works great. Even without ethernet it's still possible to do some null-modem gaming in most of the late-DOS games. Not sure about Windows95, since I never tried that, but I did play a lot of Hexen back in the day with a simple serial cable 😀 Ethernet cards were stupidly expensive back then, so no one apart from businesses had them.
Reply 7022 of 59338, by Lukeno94
It does, yes, but they're keyed for 5 volt adapters only (which is annoying, because I can't find any obvious 5V PCMCIA to USB 1.1 or similar cards anywhere), and since I'm not likely to use it on the internet, I don't see much point in hunting down an ethernet card. I have ordered a null-modem cable though for file transfers, which also means I can actually check the serial port functionality of systems (in theory).
EDIT: Does yours have L2 cache? I don't believe mine does, so that could make a difference.
Reply 7023 of 59338, by Stiletto
The Toshiba T4900CT maintenance manual describes the Toshiba T6W23 (not the T6W23A) as so:
http://www.minuszerodegrees.net/manuals/Toshi … ce%20Manual.pdf
Super Integration (SI) T6W23, which stores the following components: • Two Direct Memory Access Controllers (DMAC): 82C37 • Two […]
• Two Programmable Interrupt Controllers (PIC): 82C59
• One Programmable Interval Timer (PIT): 82C54
• One Floppy Disk Controller (FDC): TC8565
• One Serial Input/Output Controller (SIO): 16550
• One Variable Frequency Oscillator (VFO): TC8568
• One I/O Controller
• One Printer Port Controller
• One Speaker Controller
do the Fandango!" - Queen
Stiletto
Reply 7024 of 59338, by b_rros
I just finished cleaning and seting up my latest find, an almost new Microsoft SideWinder Precision Pro, it came with the drivers CD and I just tried it with Star Wars: X-Wing Alliance. It worked great! 😀
I was never a flight simulator kind of guy but I'm ejoying this one, any recomendations on games I should try?
Reply 7025 of 59338, by Lukeno94
Stiletto, that's about as much info as the 200CDT's manual has on the T6W23A. No real indication of specs or anything like that. Based on guesswork, I think the main difference is that the T6W23A was used with split voltage CPUs, whilst the T6W23 may not have been, and possibly support for 66 MHz FSBs, whilst the T6W23 there has a 50 MHz FSB. Intriguing that Toshiba didn't even mention what the graphics chip in the T4900CT was in the service manual; a look at the spec sheet elsewhere on their site shows that it is a 1MB C&T 65545, which I would presume is basically the same chip as the 65550, but with half the VRAM.
Reply 7026 of 59338, by sliderider
joe6pack wrote:
It performs nearly (very, very) identical to a 6600GT and slightly worse than a 7600GS. A 6600GT is originally what I was after, […]
obobskivich wrote:
joe6pack: how does that 7300 perform? I've been curious about the "lesser" GeForce 7 cards for AGP, but usually the ones I find are GS or LE or whatnot, not GTs.
It performs nearly (very, very) identical to a 6600GT and slightly worse than a 7600GS. A 6600GT is originally what I was after, so I came about as close as possible but with the added bonus of 512MB of ram.
The chart here has some numbers on the GT/GS/LE/SE difference:
http://www.nvidia.com/page/geforce_7300.html
There's no way a 7300GT comes close to a 6600GT. GeForce 7 was not a ground breaking GPU like GeForce 8 was. It was only a refinement of GeForce 6. 7300GT would have been an improvement on the 6200, but not the 6600. 7300GT has two more vertex shaders but is clocked about 40% lower and uses DDR2 memory while 6600GT uses GDDR3 and has about 40% more memory bandwith. The 6600GT far outstrips it in everything but vertex shader performance and even there it's not that far off. Overall 6600GT is still the better card.
http://www.gpureview.com/show_cards.php?card1=454&card2=190
Reply 7027 of 59338, by Lukeno94
sliderider; there were plenty of 7300 GTs that used GDDR3 RAM as well, but I am also dubious about how the 7300 GT compares to a 6600 GT. I'd imagine that it is some way ahead of the 6200 though - and the specs imply that it was better than a vanilla 6600, which may be the source of some of the confusion. I'd be intrigued to see how a 7300 GT compares to a 6800 LE or XT; it has a lot lower memory bandwith (at least, it does in DDR2 form), but otherwise seems pretty comparable specs-wise.
Reply 7028 of 59338, by pewpewpew
Re: flight sim recommendation
List seems to be missing the first MS Combat Flight Simulator (1998). It's a great period sim. Also Crimson Skies, which was a more arcade-style game based on the same tech.
Reply 7029 of 59338, by vetz
Some stuff acquired over the last weeks:
Brand new Am486 DX4 mousepad. This will go very well in my retro KVM setup 😁:
Creative Video Blaster CT6000
Soundblaster 16 CT1770 (Had this card before, but it died on me)
Canopus Spectra F11 (Geforce 2MX 400) - BOXED
Canopus Spectra 3200 (TNT1 16MB AGP /W SGRAM) - BOXED. YES, this card DOES support Witchdoctor with Canopus Pure3D II cards 😀
Sphere 3D joystick (NIB). This will be great to test out in Descent!
Neon250 PCI! Thanks to Gona for letting me do a trade 😀
Reply 7030 of 59338, by QBiN
Wow... nice pick-up. I've been watching out for a Spectra 2500/3200 to go with my Pure 3D II's for a while now. If you ever don't want it, anymore... hook a brotha up.
Reply 7031 of 59338, by Putas
I've been watching out for a Neon 250. If you ever don't want it, anymore... nah nvm.
Reply 7032 of 59338, by popper
Not that bad..... except the obligatory mess around the power cell
errare humanum est
Reply 7033 of 59338, by devius
Intel must have sold a boatload of 486 DX2-66.
Reply 7034 of 59338, by brostenen
Yes... One of the most succesfull 486's ever. At least in Denmark.
Most people here, skipped cpu's from DX2-80 up to Pentium-133.
(those two cpu's included)
Reply 7035 of 59338, by HighTreason
Probably because of several factors;
> It was 5 Volts, so it did not require a voltage regulator.
> It used a 33MHz BUS which was stable, many devices didn't work well at 40-50MHz and 20-25MHz was rubbish.
> It offered a huge performance gain over an older 33MHz processor and was priced more reasonably than other speeds.
That is a nice looking VLB board, AMI BIOS as well. Don't delay on getting that battery off of it, remove it as soon as possible.
Reply 7036 of 59338, by badmojo
Nice pick-ups Vetz! Love that mouse pad.
I bought one of those too, from the same seller I'm guessing. It worked really well but I must admit that it was too revolutionary for me, I'm too old for learning new tricks.
I suggest giving the driver CD a miss and using the ISO linked to in the last post of this thread:
Seeking Space Orb 360 drivers/software
It's a later version with better game support.
Reply 7037 of 59338, by SquallStrife
badmojo wrote:
Nice pick-ups Vetz! Love that mouse pad. […]
I put the driver on VogonsDrivers just now. HTH.
Reply 7038 of 59338, by popper
HighTreason wrote:
Probably because of several factors; > It was 5 Volts, so it did not require a voltage regulator. > It used a 33MHz BUS which w […]
Right; i removed it after finishing the photos....
I too like AMI BIOSes (and Phoenix) better than AWARD ones. When i have done some fixes on the board (the battery, as i wrote and you can see, caused some corrosion) i will play around with it and see what it is capable of.
errare humanum est
Reply 7039 of 59338, by badmojo
Thankyou, yes it does.
