HWiNFO support of vintage hardware
Reply 720 of 799, by muro
Hi Martin,
I was just running hwinfo on a Windows NT 4 machine. It crashed and the debug file said there was an error writing the driver - the fix it simple, the C:\TEMP directory didn't exist - all worked after I created it.
thanks for the nice tool!
Reply 721 of 799, by Mumak
muro wrote on 2025-03-07, 18:22:
Hi Martin,
If you could attach DBG file of the crash, I will look at that.
Reply 722 of 799, by zuldan
Getting duplication of data with a Gigabyte GA-7VT600. Also, the CPU fan speed should be in the 2000's. I can work around it by using the divider but just thought I should mention it.
The attachment HWiNFO.png is no longer available
The attachment Gigabyte GA-7VT600 Debug.zip is no longer available
Reply 723 of 799, by zuldan
In relation to my post above, these sensors values from another application match what's in the BIOS.
The attachment Sensors.jpg is no longer available
Reply 724 of 799, by XboXC
Maybe HWinfo for win 3.1 ? 😁
Main "PC":
Mac Pro Xeon 2x 3GHz (Quad), 12GB RAM, MacOS 10.15, Radeon HD 5770
Retro:
Apple Macintosh Quadra 650, 68040 33MHz, 64MB RAM, Mac OS 8.1
PC (clone): Intel 80486 DX2 66MHz, 64MB RAM, Windows 3.11 WfW, ATI Rage2
Reply 725 of 799, by GemCookie
While my Pentium 4 isn't exactly vintage, I still thought I'd give HWiNFO a shot on it.
The CPU and motherboard are detected properly; however, HWiNFO 8.24 fails to display most of the GPU specs. I've attached an additional screenshot and report from HWiNFO 8.00, which does not exhibit this issue.
The program reports that my RAM runs at 6-9-9-15 timings, which seem a bit strange for DDR. It also lists a 500 GB HDD connected over SATA; while I do have one attached to the machine, it's plugged into a USB port.
Gigabyte GA-8I915P Duo Pro | P4 530J | GF 6600 | 2GiB | 120G HDD | 2k/Vista/10/Debian
MSI MS-5169 | K6-2/350 | TNT2 M64 | 384MiB | 120G HDD | DR-/MS-DOS/NT/2k/XP/Gentoo
Dell Precision M6400 | C2D T9600 | FX 2700M | 16GiB | 128G SSD | 2k/Vista/11/Gentoo
Reply 726 of 799, by red-ray
GemCookie wrote on 2025-04-21, 12:57:
I looked in the .DBG file and it contains as below, so it's not reading it correctly or the hardware has an issue, what does my SIV utility report?
MCHBARset[0:0:0_44]=1
MCHBAR:
MCHBARmap
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 0123456789ABCDEF
0000: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
0010: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Reply 727 of 799, by GemCookie
red-ray wrote on 2025-04-21, 18:54:
SIV reports 3-4-4-8 timings for the RAM, as expected.
Reply 728 of 799, by vorob
Hi, can you please name me last version that is fully compatible with win vista without any dependencies? Tried last one, but caught requirements. In current case it’s easier to use old version rather then install updates. Thx.
The attachment IMG_4431.jpeg is no longer available
Reply 729 of 799, by red-ray
GemCookie wrote on 2025-04-22, 13:25:
Good, this means your hardware is OK, I wonder how long HWiNFO has been wonky...
I noted the SIO voltages and temperatures reported by SIV need adjusting, if you PM/Post/E-Mail me the two Menu->File->Save Local files I will adjust them.
vorob wrote on 2025-04-22, 17:00:
It will be very very old, we have had to use SHA2 since around 2015, the last SHA1 signed SIV Driver is Version 4.53 released on 14-Mar-2015
You could boot with driver signature enforcement disabled or install the KB.
Reply 730 of 799, by Robbbert
It's much easier to install the KB, only takes a few moments.
Reply 731 of 799, by Mumak
Sorry folks, I wasn't getting any notifications about new posts, so I missed the reports. Going to look into that now...
Reply 732 of 799, by Mumak
zuldan wrote on 2025-03-08, 00:28:
This will be fixed in the next (Beta) build.
Reply 733 of 799, by Mumak
This will be fixed in the next build too.
Reply 735 of 799, by ultra_code
I started doing testing on my Asus P4C800-E Deluxe again after nearly two years of not doing anything with it, and I noticed under Windows XP that after I use HWINFO to probe for system sensors and try to restart the system, the board gets stuck at POST code do. I am running XP Pro SP3 fully-updated, default services, latest Intel chipset drivers (not that they matter much), and have accounted for effectively all the hardware (with both the motherboard and video cards tested being fully-recapped).
I did not have any issues with HWINFO back when I tested this board two years ago, and sure enough, the version from around the time I was doing testing on the board (v7.22) worked without issue. I then went version-by-version to find the culprit - v7.40, the first version to display this behavior. Turning-off SMBus support does prevent the issue from occurring, but I'd think that's less than ideal.
I generated reports and then generated debug files from opening in "sensors-only" mode for 10 seconds for 7.36, 7.40, and the latest 8.24, both with and without SMBus support enabled and with resets in-between, attached to this post.
Builds
Reply 736 of 799, by Mumak
ultra_code wrote on 2025-04-28, 12:32:
Thanks for the detailed report. Can you please try to enable SMBus Support back and tick the boxes belonging to 0x61 and 0x62 in the "SMBus Device Exclusion" table and let me know if that fixed the problem.
Reply 737 of 799, by ultra_code
Mumak wrote on 2025-04-28, 18:43:
Unfortunately, with the following settings, it did not fix the problem, both with v7.40 and v8.24. 😔
If you want me to perform any more testing, let me know.
Builds
Reply 738 of 799, by roytam1
ultra_code wrote on 2025-04-28, 23:40:
I think you should tick these 2 instead?
The attachment untitled.png is no longer available
Reply 739 of 799, by ultra_code
roytam1 wrote on 2025-04-29, 02:33:
pfffft I'm dumb. You are correct. Thanks!
Disabling x16 and x26 and enabling x61 and x62 did solve the problem! Can confirm with both v7.40 and v8.24.
Builds
