Reply 720 of 986, by Nunoalex
PC@LIVE wrote on 2025-01-28, 15:22:I did a boot test, first with the Pentium 133, later I changed CPU, and I put a Pentium 200 MMX, with this I made measurements, […]
I did a boot test, first with the Pentium 133, later I changed CPU, and I put a Pentium 200 MMX, with this I made measurements, to look for VCORE lower than 2.8V, the PC always started, but the measurements on the Mosfet or in the inductor, were all quite strange, I have to try them again, because even changing position to the jumpers I see a strange 3.06V, even when it should only do 2.2V, I think I have to find the PINs in the back of the CPU (socket 7), and see what's really there, usually that type of measurement works very well, but Here maybe there are other components in the VCORE line, which could lower the voltage of 3.06V to the selected one.
This card does not have the VCORE self-detection function, and there is no BIOS function that can modify it, now I do not remember if there is a hardware monitor in the BIOS, with the relative voltages, I will see if there is and what it shows.
The Intel Pentium MMX 200 CPU, is of the blocked type, it only makes 166 and 200 MHz, so it is not possible to overclock at 233 and underclock at 133.
For now since the VCORE is high, I will not try any AMD K6-2 CXT, only when I am sure that the 2.2V corresponds to something similar, I will be able to do the CPU change, and redo the tests with undocumented VCORE settings.
The BIOS version is the factory one (?), it reads BT-1B2, and the motherboard should have a 1 Mbit BIOS chip, I will see later to update it to the BT-1B7 version, if I can make some progress with the undocumented VCORE.
Hi
I have this Soyo motherboard SY-5BT and it is currently with a pentium 133 but it currently displays on the POST screen BT-1B7 and the bios date is 02/04/1999
The full POST string is: 02/04/1999-i430tx-w977-2A59IS2BC-00
The setup program is full of tweaking options and this version doesn't seem to be on the retro web motherboard site
Is this the correct BIOS for this board? some "hacked" unofficial version ?
