Reply 720 of 3464, by sharangad
I'm having trouble installing the Total 3D drivers on Windows 11. My W98 VM is down. The exe can't be unzipped directly. I can run it, but I'm not sure where the files will go because it's running under otvdm (I think).
https://patreon.com/Rready
Reply 721 of 3464, by sharangad
Try this:
https://1drv.ms/u/s!As-dKk-N73dSmE4kAAifTtcP_wZM?e=XRqzLS
MD5: 2faebd564a41db7e77e88ea6ed390629ca12a452
See if you still get the error and let me know if the game works.
Reply 722 of 3464, by Agent of the BSoD
Logs from the wrapper and the dlls.
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | SB Pro 2 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Reply 724 of 3464, by Agent of the BSoD
System folder but yes.
The linked files do the exact same thing as the others. Same error, game runs perfectly. I haven't had a chance to try to clean the drivers yet though.
Reply 725 of 3464, by sharangad
This should run on a V1000 without the error:
https://1drv.ms/u/s!As-dKk-N73dSmE8_XmHL55en8nRA?e=GUQwwB
MD5: c98f4e55a5bc34c7292ee17f0c00fc39
If this works, I'll update the binary in the other thread.
Reply 727 of 3464, by Agent of the BSoD
Uninstalled the Canopus drivers, removed remaining files from system folder (device was already removed from device manager from Canopus driver uninstall) and installed Canopus drivers only. Game refuses to launch with stock dlls in the game folder. Your new files do indeed not show the error popup anymore, game runs exactly as it has been. There is no corruption on closing, that was only happening when installing the game's included device drivers.
Actually, after cleaning the files, replacing those three files into the system folder still doesn't allow stock F1 to load. Must be something else it needs as well.
Reply 729 of 3464, by Agent of the BSoD
Yeah F1 definitely wants files from the rredline folder in the system folder to run (without wrapper). I know that not all of them were put in the system folder from when I cleaned it out, like the .nms files. The missing files that are not included in my driver package are display.drv, v1000.dll, v10002d.uc, v100032.dll, v10003d.uc, verite.drv, verite.vxd, veritex.dll, and winspd3d.uc. Putting those in the system folder lets the game run with no problems, no corruption on close.
Reply 731 of 3464, by Agent of the BSoD
Ok, so I was deleting those mentioned files one at a time to see which ones the game actually needs, and it turns out that most are unnecessary. It only needs display.drv, v10003d.uc, verite.vxd, and winspd3d.uc in the system folder and runs just fine.
Edit: winspd3d.uc is actually not needed either.
Reply 734 of 3464, by Agent of the BSoD
I guess I can get away with display.drv gone. When I tried that before, the system hard reset when launching the game. Now it's fine (???). Verite.vxd is still needed though. So really it's just verite.vxd and v10003d.uc.
The game folder contains redline.dll and verite.dll.
Reply 735 of 3464, by sharangad
I think most V2000 boards come with verite. Vxd. Would be interesting to see if just slapping the F1 rredline dll pair into the game folder and v10003d.Uc into system allows games to run on a V2000.
Reply 736 of 3464, by robertmo3
robertmo3 wrote on 2024-03-15, 14:25:
i think the one not assigned device is simply not a dos device
it's firewire IEEE 1394a
Reply 737 of 3464, by robertmo3
I configured bios so that all assignable devices listed irq 7 (smbus, usb, usb, sata, sata, sata, ide, net, sound, sound, gfx), only firewire got NA.
But in windows 11 in device manager all irqs were unchanged.
So you can have different irqs for devices in dos and windows (at least win11)
Reply 738 of 3464, by RaVeN-05
I need to retests all latest FIFO exe's i think, my HDD Fails , i got files with funny content inside, thats maybe reason why we got some random date inside v2000.rom etc.
Do i need test something, i just out of spot a liitle bit.
P.S. Playing Rebel MOON , this game gem , underrated masterpiece =0
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 739 of 3464, by robertmo3
there is a rebel moon on rebel moon rising engine
