Reply 7420 of 59344, by rick6
kithylin wrote:
rick6 wrote:
Woot?
There were Geforce 3 TI500 with 128mb of vram?
Yes: http://en.wikipedia.org/wiki/List_of_Nvidia_g … GeForce3_Series
Oh ok, i thought their maximum was 128 mb but i didn't knew they were ever made..Although...that chart also states APG\PCI bus, but i have never seen a pci Geforce 3. But if you have a 128MB ti500 than that's a given. I must get one myself now, i only ever seen ti200 with 128mb.
My 2001 gaming beast in all it's "Pentium 4 Williamate" Glory!
Reply 7421 of 59344, by ODwilly
128mb ti500 is my favorite Geforce card.
Reply 7422 of 59344, by King_Corduroy
Didn't buy it, I pulled it out of the trash last night on my way home from work. Works great but only does 640x480, picture looks fantastic though. 😁
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 7423 of 59344, by pewpewpew
Sweet. And so strange to see one so clean and white. Not even grime in the corners. It's like it's fresh-baked.
King_Corduroy wrote:
only does 640x480
maybe not?
http://pbclub.pwcsite.com/PBFTP/monitor/8537.html
Reply 7424 of 59344, by jwt27
DUDE you hit the JACKPOT! That's a 0.39mm tube right there. http://pbclub.pwcsite.com/PBInfo/PB%20Info%20 … 537SOVW.asp.htm
It looks identical to my Hewlett Packard. And it's made in Korea too, so it might even be the same thing. In that case it's really a Samsung 😀
Reply 7425 of 59344, by King_Corduroy
Thanks, yeah it was certainly a lucky find. 😁
I couldn't believe how clean it was either, I mean I did scrub it a little before taking the pictures but it basically looked exactly like this when I found it. Just had a light layer of dust.
Hmm when I tried to run it at 800x600 it went all funky but hell maybe it's because I'm using a KVM. I should try it without the KVM and see what happens. 😁 Thanks for the info.
Reply 7426 of 59344, by King_Corduroy
Naw I just tried again and it really doesn't like 800x600 or 1024x768
Reply 7427 of 59344, by Evert
Another Audigy 2 ZS ($10):
S3 Trio 3D/2X 8Mb AGP ($7):
S3 Trio 3D/2X 4Mb AGP ($7):
Edit: Okay, hopefully everything is now as close to 100% correct as they can be.
Reply 7428 of 59344, by jwt27
800x600 at 60Hz, 1024x768 at 50Hz or 1024x768 interlaced at 87.5Hz ought to work.
edit: wait the horizontal max is only 35.5kHz. That'll be 56Hz at 800x600 then... might be painful.
Reply 7430 of 59344, by RacoonRider
Evert, the first one is not Virge and the second one is not 2D/2X 😀
Reply 7431 of 59344, by Evert
D'oh! This is what happens when you don't use your own pictures. Thanks!
Reply 7432 of 59344, by devius
The last one is still not a PCI card... In fact I don't think they ever made 3D/2X in PCI form.
Reply 7433 of 59344, by Evert
Really? I did not know that. Well, it's still cheaper than trying to get a Trio64+, one will set me back $40.
Reply 7434 of 59344, by 133MHz
Is my Samsung CVL4955 a 0.39 tube too? I can't seem to find any information about it on the web. Could it be a sibling of yours and King_Corduroy's?
http://133FSB.wordpress.com
Reply 7435 of 59344, by RacoonRider
Nah, I got one 😀
Reply 7436 of 59344, by King_Corduroy
Sure looks that way. Your samsung and my Packard Bell monitor look identical. Could you maybe try and take some pics of it from the some angles I did? Also, does your power button get stuck some times? Mine is really hard to press in at times.
Reply 7437 of 59344, by devius
RacoonRider wrote:
Nah, I got one 😀
Really? I guess it makes sense that a PCI Trio 3D exists, since it barely uses the AGP capabilities anyway, but I never saw one. The one in the picture above is still AGP though 😜
Reply 7438 of 59344, by RacoonRider
devius wrote:
RacoonRider wrote:
Nah, I got one 😀
There's actually quite a lot of them 😀 Makes double sense since it remained a lowest-end bestseller probably until the days of Vanta/M64 and with PCI you could install them into then outdated Pentium as well as systems with absent/glitchy AGP.
Reply 7439 of 59344, by Lukeno94
Well, I received the Toshiba T1200 I ordered today (at last):
It's supposed to work, but the moment I plugged the power supply into the wall, there was a loud bang and now the power supply is dead (it's supposed to work on 240V and the seller was in the UK, so it wasn't due to that.) Thankfully, it wasn't plugged into the T1200 at the time, but I know it's not just a fuse in the plug, because I tried a different one to check, and nothing. Just my luck. It has two floppy drives, and also came with the DOS floppy (and that I know does work, because my Vaio PCG-FX601 was able to boot off of it). So now begins the hunt for a replacement PSU that doesn't cost more than the Earth.
