DOSBox Game Launcher (DOSBox Frontend)
Reply 760 of 2212, by kolano
rcblanke wrote:
kolano wrote:
Is there a reason that the x64 version of this is packaged differently than the x86 one (i.e. tar.gz)?
The only difference between the 2 linux packages is in the included DOSBox executable.
Though I'm just grabbing the jar atm, it would be nice to have a Windows x64 package as well.
Reply 761 of 2212, by rcblanke
Why? The current Windows package works perfectly fine on both x86 and x64.
Reply 762 of 2212, by rcblanke
Hi everybody,
Another minor update (0.72f), this time with:
* a fix for an importer bug which could cause booter games to fail to start (disk img2 and img3 were incorrectly set)
* a fix for an expandbar scrolling issue on Linux
* an Italian translation update from code120
* fine-tuning of some default dialog sizes for Linux systems
All the latest files, to upgrade just grab the jar as usual.
Regards,
Ronald
Reply 763 of 2212, by rcblanke
Hi all,
Inspired by Kris Asick's Ancient DOS Games webshow, I've made a new gamepackarchive for DBGL ready, containing all non-commercial games reviewed so far (excluding games that are available in existing packages) , together with some of Kris' freeware games. In some cases the shareware/demo versions are packed. Comments are very welcome. The package consists of:
Captain Comic, The Adventures of
Command & Conquer
Cybersphere
Cybersphere Plus
Dangerous Dave
Descent
Flightmare
FX Fighter
Jade Fighter Arena
LineWars
Magic Carpet
MegaZeux - Caverns of Zeux
Round 42
Sango Fighter
Snarf
Space Fortress
Star Gladiators 2
StarMines II : The Planet of Mines
Star Wars: Dark Forces
Stunts (4D Sports Driving)
Supaplex
System Shock
Tank Wars
Teenagent
Thor's Hammer
If you think anything is missing, shouldn't be in the package, or is inappropriately configured, please let me know!
Regards,
Ronald
Reply 765 of 2212, by rcblanke
You're probably right, will be removed, thanks.
EDIT: done.
Needless to say, if anybody wants to contribute his/hers own (legal) package, please let me know, and I might put it up.
Reply 766 of 2212, by code120
Are System Shock and Dark Forces legal? That is, "abandonware" in general? I'd like to make a pack with SSI Goldbox games, but I don't know if it's really legal.
Reply 767 of 2212, by wd
Rank DOSBox Author
DOSBox Author
Abandonware is NOT legal.
Reply 768 of 2212, by Qbix
Rank DOSBox Author
DOSBox Author
and those two games specificly are not legal distribute.
Water flows down the stream
Reply 769 of 2212, by rcblanke
Calm down guys, the ones included in the package are demo/shareware versions.
Reply 770 of 2212, by wd
Rank DOSBox Author
DOSBox Author
The replies were for code120 who asked if "abandonware" in general is legal.
Reply 771 of 2212, by rcblanke
Hi all,
Release 0.73 is up, enjoy!
Reply 772 of 2212, by Neville
I have a small request, although I can't tell if I should send it to rcblanke or the DOSBox devs. Many DOS games use unusual keys, and I'm tired of the sticky keys option popping out every now and then, it's not exactly user friendly.
Could you do something to disable sticky keys while running DBGL or DOSBox?
Reply 773 of 2212, by steveJ
Maybe there is something I don't understand, or maybe this is a feature request, but each game seems to be tied to a specific DOSBox version. When I install another version of DOSBox, I seem have to edit each game to run with the latest version. When I try to remove old, no longer required, DOSBox versions, I am told that I can't because they are being used. If I actually delete the DOSBox version from the file system, without first editing the profile, it becomes impossible to edit the profile.
What I would like to be able to do is simply assign the DOSBox version for each game to "default". Then, when I upgrade, I will always use the latest version of DOSBox, and can get rid of earlier versions of DOSBox easily.
Reply 774 of 2212, by wd
Rank DOSBox Author
DOSBox Author
Why the hell do you have that enabled???
Reply 775 of 2212, by Neville
I'm not even surte it's enabled... every time I pres certain keys I get this annoying screen and DOSBox loses focus. I've tried getting rid of it, seriously, but the damn thing is not exactly user friendly.
Reply 776 of 2212, by wd
Rank DOSBox Author
DOSBox Author
Press shift some times, then click on that "how to disable it" thing. Should be somewhere in the controlpanel depths.
Reply 777 of 2212, by SKARDAVNELNATE
In Windows XP
Control Panel
Accessibility Options
Keyboard >
StickyKeys
Settings > Use shortcut: uncheck
Reply 778 of 2212, by Neville
Done, thank you. 😊
Reply 779 of 2212, by kolano
There are a few ways to account for this currently...
1: Use multi-edit to mass update the relevant profiles (i.e. select them all and then select edit). Such will allow you to update the profiles all at once to your new DOSBox version. This unfortunately is difficult if you've configured different profiles to use different versions.
2: Use the same "Title" for the new versions as used for the former DOSBox version.
