Reply 7640 of 53082, by Lukeno94
Not true - it entirely depends on the display you're using. I've played many a game on my Sony Vaio PCG-FX601 laptop at resolutions below 640x480 (even some random ones, like 512x384 - native res for some early 3D GPUs of course, but not this system), but my 19" Dell flat panel display throws a fit if I try to use anything below 640x480.
Reply 7642 of 53082, by kanecvr
I have three Asus P/I-P55ST2 boards, slightly different models/revisions (one is green) - I don't use them because one has no PS/2 header (looks like the one on top but with green PCB), and the other two have no coin cell holder (dallas RTC like the one pictured above).
Reply 7643 of 53082, by Skyscraper
The VRM heatsink on that Asus socket 7 board gets very very hot, I had to put a 80mm fan on the CPU heatsink so it would cool the VRM heatsink aswell otherwise you could get burned when touching it!
Have have a few audio/video cards for the special slot aswell 😀. Its a motherboard I intend to use but never really do.
Reply 7644 of 53082, by vetz
They are one of the best Socket 7 boards, very fast and stable with the Intel 430HX chipset. Supports 83mhz FSB. The Dallas RTC can be switched out and Rev 2.1 (with green PCB) does have a PS/2 header (all rev does):
http://www.ebay.com/itm/ASUS-p55t2p4-Rev-2-1- … =p2047675.l2557
If you want PS/2 and coin cell battery built in I recommend getting rev 3.0 of the ATX version. No 83mhz FSB, but you get those features 😀
Reply 7645 of 53082, by tokroger
Today's haul
A-Link 4-port USB 2.0-card, ALi M5273 5-port USB 2.0-card, Opti861 2-port USB 2.0-card, 2 x Hynix 512 MB PC2-4200-CL4, 2 x Infineon 512 MB PC2-5300, Intel Pentium II 350 MHz SL2WZ
QuickJoy V Superboard SV-125 fully operational
Reply 7647 of 53082, by devius
Lukeno94 wrote:
... my 19" Dell flat panel display throws a fit if I try to use anything below 640x480.
That's what I was talking about, since we were discussing standalone displays. I know laptops usually support lower resolutions, but you can't really connect your 486 PC to it can you?
There should be a thread about flat-screen monitors that support resolutions lower than 640x480. Personally I don't know any.
tokroger wrote:
... Intel Pentium II 350 MHz SL2WZ
Intel must have sold a boatload of Pentium II 350MHz.
Reply 7648 of 53082, by Lukeno94
Well, if a 2001 laptop display is going to support a lower resolution, I can't see why something like a 15" TFT wouldn't support it. It may actually be that my 19" Dell did work fine with those lower resolutions, but doesn't like the refresh rates that my HP Vectra tries to drive it at when using them; I honestly can't remember, because it's been at least two years since I tried it on anything else with games of that type, and I won't be able to check for another month. Might hook up the Vaio to my 22" LG 1080p monitor and see what happens when I get chance though. Tis also worth noting that both of these are widescreens anyway, and I really can't remember what the 15" TFT I had several years ago was like.
Reply 7649 of 53082, by kithylin
Picked up a couple interesting items at local store that's (Sadly) closing very soon, some time this month I think.
I've been looking for an early intel socket-7 motherboard that will run my 50 Mhz socket7 chips natively, and have not found a decent one for a while.
I found one yesterday at used store, paid $7.85 out the door for it.
Larger: http://www.outfoxed.net/bought-stuff/DSC05406.JPG
Also: I've never seen a socket7 board with this "TX PRO III" chipset, so performance will be interesting to see later.
I picked up this other item for two reasons.
1.) I don't have any GeForce MX series video cards in my collection.
2.) It was white. I mean come on, how many white video cards do you see, that's cool! 😎
Larger: http://www.outfoxed.net/bought-stuff/DSC05412.JPG
Larger: http://www.outfoxed.net/bought-stuff/DSC05413.JPG
Bonus: Someone already replaced the onboard fan with an 'aftermarket' one with motherboard fan header leads. I may actually use this in my athlonXP Win98se planned build soon, because I don't have a good basic gpu for it yet, that one will be decent enough combined with a voodoo2 12MB card.
Reply 7650 of 53082, by Sutekh94
kithylin wrote:
I've been looking for an early intel socket-7 motherboard that will run my 50 Mhz socket7 chips natively, and have not found a d […]
<snip>
That's a PC Chips M573, and the chipset is actually a VIA Apollo VPX. PC Chips had a habit of renaming chipsets by VIA and others to names like "TX Pro". That being said, it should be a decent board.
My YouTube | My DeviantArt
Reply 7651 of 53082, by kithylin
It did have sb16 compatible onboard sound, but it used some custom plug header that I'm sure I'll never again see in my lifetime, so probably try and disable that with jumper or bios and use a sound blaster card instead. Likely better performance anyway. I would still like to try the onboard sound if I could ever find said header... 😒
Reply 7652 of 53082, by QBiN
petro89 wrote:
Got a Slot-A 750 with a Thunderbird core! Time for another old skool rig build with some Voodoo 2 SLI lovin!
Slot-A's with Thunderbird cores were OEM only. Do you have a motherboard that can run/recognize that?
Reply 7653 of 53082, by tayyare
kithylin wrote:
Yeah. Make a thread about it or something, skyscraper. And post the link here, I wanna hear about that and what it is. Looks like Pentium-MMX. But using both sdram and 72-pin ram together is weird, normally I would of thought most systems wouldn't allow that.
It's ok for at least some boards. There was a conversation recently about it:
New 1997 Build (GA-586STX2)
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 7654 of 53082, by kanecvr
Got 7 video cards today from an acquaintance who was clearing out his place - A GF 4 MX4000, a GF4 MX440 with swollen caps, a radeon 9250, a S3 Savage4 PRO (been looking for one of these - just hope it works) a matrox dual-head AGP and another PCI S3 trio 64 (can never have too many of these).
I also got the 486 machine I posted pictures of on page 382. The case has a 386 Deskframe logo under the A-Open sticker, and a 486DX 33MHz in it with a Siemens chipset motherboard (unidentified - no model written on it). Motherboard is ISA only. Battery leaked a little but looks like no real damage. Inside of it is a TSENG ET3000AX VGA/EGA ISA card with what looks like 1MB of VRAM (this is the 7th card), a Adaptec SCSI controller, an ISA modem, a 2TB NEC IDE HDD form '97 and a 1992? Toshiba double thickness 1GB SCSI Drive. It also has a 5,25" FDD and a TEAC CD-RW in it. Haven't tried to turn it on yet.
The 486 was found in front of a dumpster and rescued by my cousin. He called me after finding it and he's been holding onto it for me since then. Finally picked it up today.
2.85 MiB
2.67 MiB
1.7 MiB
^^To the left is my K6-2 450/Voodoo Banshee rig and next to it is the aforementioned 486. ^^
I also discovered that Nitro paint prep / cleaner is good for whitening yellowed PC cases (to an extent)
Reply 7655 of 53082, by obobskivich
Finally found a Matrox Parhelia for a price that I can live with; it should arrive next week sometime. I'm hoping to actually take advantage of the triple-output with my primary desktop monitors.
For anyone that owns one - when it comes to drivers, am I best off just downloading the latest drivers off of Matrox's website, or should I look for a specific version of drivers for compatibility/performance?
Reply 7657 of 53082, by dogchainx
Bought a Samsung 19" 995df CRT monitor, BRAND NEW in box. I have my 21" CRT, and its way too big and has some issues. My 17" is a tad on the small portion. I'm hoping this will be my final replacement CRT for awhile and lasts a long time. It should, since I only turn my CRT on on the weekends for 2-3 hours for retro gaming. I'll post pictures later.
Not the BEST 19" CRT monitor, but 1280x1024 is more than adequate for retro 1980 to 1999-2000 gaming.
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
Reply 7658 of 53082, by pewpewpew
Search the BIOS string that appears in the lower left during boot. It will look like "40-0102-001292-00101111-050591-SIS-486-F". That one is from my ASUS ISA-486 and the "1292" in the third group is the OEM code that tells you it's ASUS.
Tap the Pause/Break key to halt the screen so you can copy the number, and spacebar to resume. And forgive me for telling you what you probably already know, but it'll be useful new info for somebody.
Reply 7659 of 53082, by kanecvr
I haven't had the chance to power it on yet - I don't even know if it works...
