What do you drive?
Reply 781 of 1124, by BitWrangler
chris2021 wrote on 2022-08-13, 05:28:
The LT-1s were capable of towing something like 5000lbs, maybe 6000, with the towing package (a differential w/the proper gear ratios). Not that it was necessarily a good idea according to some. But the vehicle sat lower to the ground and had an actual cast frame so I'm not necessarily seeing why it would be an issue, actually preferable to a truck, which was a bit more top heavy. In theory anyway. But what do I know.
The Caprice, the Roadmaster (91-96) and the Fleetwood (93-96) could be equipped to tow 7000lb, but right axle final drive and gear ratios necessary, which either came with tow package or "commercial" chassis (Typically hearses, though there might have been an ambulance or two). In the regular model they could do 5000lb. Ideally you wanted a load levelling setup to get the weight on the axles because there was a bit of rear overhang.
It was only when these models were gone that the "Only trucks can tow" BS train really got moving, because it was hard to argue when the full size cars had the same damn engine, same damn gearbox, same damn rear axle, same damn rear springs. Typically their brakes were more effective though, because the disks were the same size inside a 15" wheel as the trucks, but the trucks would have 235/75 and the cars maybe 215/70, so there was more leverage working against the brake on the trucks than the cars. Though it's less of a problem with trailer brakes and a brake controller. However, until WELL into the 2010s, they were selling trucks of equivalent HP and worse brakes than larger sedans and other vehicles., sedans stopping in 140ft or so from 60mph, trucks needing 220ft... in other words, stick a modest 3000lb trailer on 'em when the trailer brakes don't work and the sedans can probably reign it in 10s of feet shorter than the trucks could. Assuming decent levelling and sway equipment. Then somehow this makes trucks even more perfect for more weight, given spare GVWR for hitch weight. Sometimes that wasn't the case though, you could option trucks weird, have only 700lb cargo available, yet somehow still be rated to tow 10,000 (Doesn't happen now though since shakeup) meanwhile your vehicle with 1700lb cargo capacity, 50+ft better braking from 60, gets a "token" 1 or 2,000lb tow rating if they bother to rate it at all.
The actual fly in the ointment with this, appears to be the crash testing, passenger vehicles aren't allowed to kill other passenger vehicle occupants when rear-ended, but trucks are. Therefore to have an official tow option it has to be designed as a breakaway piece that goes under the vehicle and doesn't make the impact absorbing zones less absorby, whereas you can have a girder across the back of a truck... though in your econobox you're probably ain't gonna rear end it unless you're really asleep, it's got crappy stopping distance remember. Since it's megabucks to engineer the strong but not too strong offical tow options, they don't bother on vehicles "not for towing" even though up to medium weights at least, they would likely be superior for it.
Reply 782 of 1124, by CwF
BitWrangler wrote on 2022-08-14, 03:18:
The Caprice, the Roadmaster (91-96) and the Fleetwood (93-96) could be equipped to tow 7000lb,...
Almost true. This is why the 'truck' category really starts with 3/4 Tons, considered 'light trucks'. At that level there are no car equivalents. The engine, tranny, axles , brakes, are all significantly beefier. My '06 Duramax will stop within 15' of the Caprice unloaded, and likely shorter at load. The Disc won't fit in a 15" wheel. Significantly more powerful all the while getting better mileage.
The closest GM ever got to building a 'truck' level car was maybe an 80ish Caprice Coupe with a 6.2L. Very strange. I'd like to have one.
The coolest tow setup has to be the beetle with a goose ball on the roof. 360 flexibility! I've thought of doing that to a Fiero. I think it would to a 5th wheel well, no bumper pulls...
And lowering a Truck does make it tow better.
And no, GM never used a Cummins.
I used to know what I was doing...
Reply 783 of 1124, by chris2021
People used to tow everything under the sun w/cars in the 90s and earlier. It was not uncommon to see smaller camper-trailers pulled by sedans in those years. No one as far as I can tell is saying a sedan is an all around replacement for a truck (or van, like my old Chevy g10 1/2 ton). Most of the old cars had cast (or welded?) frames, basically non existent since the mid 90s. And could tow another car at least with ease.
Chevy used some other make of diesel engine for a while. Don't know which it was. As I understand it the first reputable diesel engine made by them was the D*.
Reply 784 of 1124, by BitWrangler
CwF wrote on 2022-08-14, 04:31:
Yeah, should really have said I was talking about half tons in the main. Which didn't help the perception problem, since they were egregiously overrated through the noughts until halfway into the tens. So you got "if my F150 can only really do half it's tow rating then your Dodge Magnum can't tow a popup" when it was more like the Dodge Magnum should also be capable of half the F150s tow rating.
Reply 785 of 1124, by Demetrio
BMW G310 GS
Reply 786 of 1124, by Intel486dx33
“Smokey and the Bandit” and “Rocky” Movie helped make the Pontiac Trans AM popular in the 1970’s , and 80’s
Reply 787 of 1124, by Repo Man11
Demetrio wrote on 2022-08-15, 18:36:
BMW G310 GS
That looks like fun. I used to ride my street bikes in places they really weren't meant to go; I once rode my Suzuki Bandit almost all of the way to Round Valley on Highway 162 in northern California, which is mostly a dirt road in very poor condition. After getting back on pavement, I noticed that the headlight seemed to be vibrating. Once I got home and inspected my bike, I realized that all of that off road riding destroyed the rubber mounts for the fairing! I had to replace them to fix the problem, and I resolved to not ride such long distances on that sort of road again. Much better to do that sort of thing with a bike meant for both.
Reply 788 of 1124, by Repo Man11
Intel486dx33 wrote on 2022-08-17, 21:21:
Undeniably a good looking car. And it's a good thing it looked good, because they weren't fast. Even worse, because of California's enhanced smog regulations you couldn't get these cars with a manual four speed here, only the three speed automatic transmission.
Edit: my snip of the performance numbers was repeatedly compressed to the size of a postage stamp, so I'll just copy and paste instead.
"C/D TEST RESULTS
60 mph: 9.3 sec
100 mph: 29.3 sec
1/4 mile: 16.9 sec @ 82 mph
Top speed: 110 mph
Braking, 70–0 mph: 213 ft"
https://www.caranddriver.com/reviews/comparis … omparison-test/
Reply 789 of 1124, by Meatball
“Smokey and the Bandit” and “Rocky” Movie helped make the Pontiac Trans AM popular in the 1970’s, and 80’s
Yep. Don't forget Knight Rider.
My first "Hot Wheels" car (that I can recall) was the 'Smokey & the Bandit'-styled Firebird.
I don't care for the re-styled update used in Rocky with the 'block' headlights (Bandit version looks much better to me), but I did love when Pontiac switched to the hideaway headlamps with the next generation Firebird.
Reply 790 of 1124, by Demetrio
Repo Man11 wrote on 2022-08-17, 21:42:
BMW G310 GS
Yeah, in fact I prefer to drive in roads with good conditions, even because I got the A driving license from like 2 months 😅
BTW, it is really a lot of fun 🙂
Reply 792 of 1124, by robertmo
my favourite
Reply 794 of 1124, by robertmo
i normally try not to cross that speed in the city too, (i just place the dot 1 digit to the left 😉
Reply 795 of 1124, by BitWrangler
BMW G310 GS
I'm always hankering for something like a lower power enduro for "going exploring". Wanna have something road legal for a bit of backroad to get there, then just mosey along down dirt roads and easy trails. I don't want anything too frigging heavy though, both for reasons of maneuverability in close quarters, maybe having to lift it over a downed tree trunk once in a while or something. Then also because I'd like to be able to move it longer haul on a hitch rack. I really like the CT90/CT110s, but they got suddenly too well known to be decent prices (Damn you Aussies for getting a crapton of them as Postie bikes and laughing at this)
Now Ontario is hella strict on bike registrations, they can't be "rebuilt" or have any accident history (Because chop shops were stealing bikes to order to reVIN them etc) which means you don't want anything slightly hinky on a bikes ownership/registration papers if you want it road legal. Meanwhile the savages who seem to own most of the CTs and other bikes of similar stripe (Sold as road legal, but offroadable) maybe have only used them offroad and seem to "lose" ownerships or have one from 20 years and three owners ago, never updated. So yeah, there's bikes out there, but you have to roll a dice on "stolen", "legally unrepairable", "Has dealer lien on it still because never paid off", "okay but you have to chase 3+ former owners down to make the paperwork right" and the unicorn "Have ownership, and it's not out of date, and it's actually in my name at my current address, and btw (whatever condition) this bike is fully "restored" and I am asking $4000+".... I keep thinking it's actually easier to import one.
edt: Yah "restored" don't mean crap any more, it means anything from "I was forced to finally get the mainenance somewhere near up to date and wipe all thr crap off with a rag" through "I had it apart, then I put it back together again, stripping or overtorquing every fastener in the process" to actual nut and bolt white glove inspection and verification of all parts to spec, replacing and rebuilding to actual perfection. IMO the first two are equivalent to runner/survivor unknown condition if optimistic, and 5 years of correcting somebody elses failed project screwups, pessimistically.
Reply 796 of 1124, by CwF
Earlier in thread I mentioned my 94 R1100GS. Without a doubt one of the best calls I've made. I rode it yesterday, I'll ride it today. Fortunately I broke all the weak links before the unlimited mileage warranty expired. At 2-1/2 years I broke the shaft, 1st in NA they told me. It went back to Germany for inspection. An irritating 3 months later it came back with a fresh drivetrain. I beat 3-4 recalls to the punch, 'Ya, figured that out'. As original owner of the first batch of a new generation it took some faith. Did I mention I'll ride it today.
Reply 797 of 1124, by Almoststew1990
What is a normal car website for buying second hand cars in the US? In the UK we have https://www.autotrader.co.uk/ which is the general second car sales.
The reason I ask is because I'm getting interested in nissan 300ZX (Z31 - the 80s one) and judging from the mainly US YouTube videos they seem to be dirt cheap over there. Over here they're entering classic car price territory at £10k for a good one.
Reply 798 of 1124, by y2k se
Almoststew1990 wrote on 2022-09-17, 09:20:
We have a bunch. A few off the top of my head...
https://www.carvana.com
https://www.cargurus.com
https://www.autotrader.com
https://www.vroom.com
https://www.bringatrailer.com
Tualatin Pentium III-S 1.4, ASUS TUSL2-C, 512MB RAM, GeForce 4 Ti 4200, Voodoo2 SLI, SB Live!, 3Com 3C905C, 80GB IDE HDD, Dell 2001FP
P233MMX, Intel LT430TX, 64MB RAM, Sierra Screamin' 3D, AWE64 Gold, 3Com 3C905B, 40GB IDE HDD, Viewsonic A75f
Reply 799 of 1124, by chris2021
And you have the inyention of shipping it to the UK? I guess so if you're asking. It seems the cost to ship would nullify any savings.
