DOS Questions
Reply 80 of 258, by Harry Potter
DustyShinigami: I don't remember what card I have, as the computer is at my mother's house--and worse, she's currently homeless 🙁--but it's a nonstandard one.
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 81 of 258, by DustyShinigami
Ah, that sucks. Sorry to hear that. 🙁
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 82 of 258, by DustyShinigami
Is there a switch or command that lets you get information about a file? I want to see the size of a particular file.
OS: Windows 98 SE
Reply 83 of 258, by Harry Potter
Try "DIR <file>." It should give you information about the file. If you want more information about DIR, type "DIR/?."
Reply 84 of 258, by DustyShinigami
Awesome. Thank you. 😁
OS: Windows 98 SE
Reply 85 of 258, by DustyShinigami
How do you move a folder and all its contents from one location to another? Every time I try, it either moves just the files from the folder or tells me it's 'unable to open source'. I've even tried move c:\dospro\throttle *.* c:\dospro\cpu but I just get the latter error for each file.
OS: Windows 98 SE
Reply 86 of 258, by Harry Potter
Try the /e switch: it should move the folder and all its subfolders.
Reply 87 of 258, by DustyShinigami
Harry Potter wrote on 2026-01-17, 14:14:
Ahh, great. Thanks. 😀
OS: Windows 98 SE
Reply 88 of 258, by chronoreverse
I believe the DOS move command can't do that and won't even take the /e switch.
Use xcopy /e instead and the once the copy is done, you can deltree the source.
Reply 89 of 258, by DustyShinigami
I've run into a bit of a problem with a game, which wasn't an issue before. Whenever it runs my BAT file it gives me an error saying EMM386: DMA mode not supported. Press Enter to reboot. If I try to load the game executable, it just unloads the sound pak. This particular game has been funny with EMS in the past, I think. However, when I tried it previously, it was fine. I'm guessing it's because my Yamaha was initialised first...? And the SB16 was daisy-chained through it...? Now that my Yamaha has gone kaput, I have no choice but to use the SB16, but for that to work, it requires EMS. So if I try to run the game and it can't initialise the sound card/driver, the game won't load anyway.
I've tried setting the card and the game to use DMA 1 and 3 and the same issue happens. I've also tried putting the resources back to A220 I5 D1 H5 P330 and at A220 I7 D3 H5 P330 and I get the same error. I've also tried deleting the game and doing a fresh install, along with configuring the audio. Same result.
I don't know if, the last I tried it with the Yamaha installed, my custom DOS menu hadn't been set up, so I'm not sure if there's something in my autoexec.bat or config.sys files that's triggering it. This is what they're like... Most things have been commented out to see if they were the cause, but no such luck.
The attachment IMG_5255.JPG is no longer available
The attachment IMG_5256.JPG is no longer available
OS: Windows 98 SE
Reply 90 of 258, by Harry Potter
Try using AdLib or PC Speaker sound. They are worse than SB--especially PC Speaker--but may allow you to run the game.
Reply 91 of 258, by DustyShinigami
Harry Potter wrote on 2026-01-19, 00:00:
Not an option, sadly. The PC Speaker, I mean. The setup won't let me use AdLib either. It says it wants port 388, which is set to OPL according to my Sound Blaster, but it fails to detect anything.
OS: Windows 98 SE
Reply 92 of 258, by DustyShinigami
Okay, some progress at least. Did an experiment. Backed up my autoexec and config files, created some new ones, and added the bare essentials - SHSUCD, mouse, EMS, BLASTER - and the game loaded! So there's clearly something in my main files it doesn't like. I'm wondering if it's UMBs. Will do some more testing tomorrow.
OS: Windows 98 SE
Reply 93 of 258, by Harry Potter
Try formatting a blank disk using "format a: /s" then copy your modified config files to it. You can use this disk as an alternate boot disk to run just this game or maybe any other troublesome games.
Reply 94 of 258, by Harry Potter
You can also add a menu to your DOS setup, but that would take some extra effort. Unfortunately, I don't know where to find the information online. 🙁
Reply 95 of 258, by DustyShinigami
Harry Potter wrote on 2026-01-19, 14:18:
That's a good idea actually. Thanks. But I am determined to find the root cause so I can leave notes for myself for future reference. 😀
OS: Windows 98 SE
Reply 96 of 258, by DustyShinigami
Harry Potter wrote on 2026-01-19, 14:21:
As in, a custom boot menu? With various DOS options - one for XMS, one for EMS...?
OS: Windows 98 SE
Reply 97 of 258, by Harry Potter
You're welcome, and yes, a custom boot menu.
Reply 98 of 258, by DustyShinigami
Yeah, that's what I have set up, which I followed from someone else's on here. 😀
Also, my guess was correct, regarding the issue. Though it's strange because when I tried enabling it using 86Box, it didn't complain. But disabling UMB in the Config file fixed the issue. 😀 By the way, the game in question is the DOS version of Simon the Sorcerer.
I would take some pics of the memory using my phone, after UMB is disabled and with them enabled, but for some reason in the daytime/afternoon, all the characters are blurry. Never an issue in the evening though.
OS: Windows 98 SE
Reply 99 of 258, by Harry Potter
If you want, you can type "mem/c>c:\out.txt" at the command prompt, and DOS will divert mem's output to the indicated file.
