List of Web Browsers For All Operating Systems
Reply 80 of 294, by Bruninho
So far I tested the releases from RoyTam1 on Windows 98SE (with KernelEx 4.5.2016.24) as of January 31, 2020:
K-Meleon 1.5.4 - Works but no CSS and no login on Vogons either. Almost nothing renders correctly. Forget YouTube.
K-Meleon 74 (Goanna 2.2) - The best of all I tried so far. Can render Vogons, I haven't tried to login yet, but fonts are messed up. The browser menubar icons are messed up. Does not play YouTube (Crashes, but I haven't installed a codec yet either)
RZBrowser and Retrozilla 2.2 (TLS 1.2) - Works, stable, renders Vogons without CSS, no YouTube, It can barely load any page without JS or CSS.
Pale Moon (for Win2000): I tried to load with compatibility set for Win XP SP2, but crashes on me even before the window. So no dice.
Retrozilla can log into Vogons, but needs to be tweaked as per comments above from other users here. And no CSS.
It seems to me that with a more polished work, K-Meleon 74 could be the best option for Windows 98SE actually. It needs more work.
JOBS, Steve.
Reply 81 of 294, by Bruninho
RoyTam1's updated Firefox 3.6.28 works almost better than any other browser for Windows 98SE. CSS is not perfect, VOGONS didn't render well (but at least has CSS, compared to RetroZilla 2.2). I'm posting it with FX3.6.28. I had to do the same cipher tweaks used in RZ.
JOBS, Steve.
Reply 82 of 294, by ntalaec
Can you provide a download link for vanilla Windows 98 SE?
Reply 83 of 294, by Bruninho
ntalaec wrote on 2020-02-11, 08:30:
Try winworldpc.com, they have some isos
Fx3 (above mentioned) and K-Meleon 74G (Goanna) albeit unstable, they somewhat work. Both need work but show signs of being capable to maintain w98 alive if Kernelex is installed.
Meanwhile I’m on Win2k with BWC and I have two perfect browsers: SeaMonkey 2.49.5 and latest New Moon from RoyTam1.
JOBS, Steve.
Reply 84 of 294, by ntalaec
Bruninho wrote on 2020-02-11, 11:54:
Try winworldpc.com, they have some isos […]
No, I meant a download link for Firefox 3.6.28 for vanilla Windows 98 SE, without using KernelEx.
Reply 85 of 294, by Bruninho
ntalaec wrote on 2020-02-11, 14:43:
Try REMOVED they have some isos […]
You cannot use that version of Firefox on Windows 98SE without KernelEx, because the last version officially supported is 2.0.0.20.
You need KernelEx and the modified Firefox 3.6.28 from RoyTam1 for Windows NT 4.0 (https://retrosystemsrevival.blogspot.com/2018 … dows-nt-40.html)
For Vanilla Windows 98SE you need RetroZilla 2.2 (already mentioned some posts ago by DosFreak here) which is based on Fx 2.0.0.20pre and with TLS 1.2 support
JOBS, Steve.
Reply 86 of 294, by ntalaec
Ah, ok. I thought it also worked with vanilla version.
By the way, does anyone know if RetroZilla limits the download speed?
In my computer (P200MMX, 64MB, W98SE) all downloads (both with Internet Explorer 5 and RetroZilla) were limited to 200KB/s. After tweaking the network settings with TCPOptimizer, I get about 2MB/s with Internet Explorer but only 600KB/s with Retrozilla. I'm using a 3Com PCI card (10/100) in a Socket 7 (430VX) motherboard.
It happens with these versions:
https://github.com/rn10950/RetroZilla/releases/
http://rtfreesoft.blogspot.com/2020/01/other- … s-20190131.html
Reply 87 of 294, by Bruninho
@DosFreak: Opera 12.02 on Windows 98 somewhat works for me, but it refuses to accept connection with VOGONS because...
Secure connection: fatal error (40) from server.
https://www.vogons.org/
Failed to connect to server. The reason may be that the encryption methods supported by the server are not enabled in the security preferences.
Please note that some encryption methods are no longer supported, and that access will not be possible until the website has been upgraded to use strong encryption.
That is when I try the https. If I try http, Opera panicks in and I get a BSOD.
JOBS, Steve.
Reply 88 of 294, by DosFreak
Yeah those versions of Opera don't support the cipher that VOGONS uses. Only option there is to use a proxy. Not sure why you're getting a BSOD. Is this with just regular KernelEx or with the Core updates for KernelEX installed?
You can try 10.70 Build 3488 or older which will work on regular 98 to see if it's a KernelEX issue or a 9x issue.
Make your games work offline
Reply 89 of 294, by Bruninho
DosFreak wrote on 2020-02-11, 21:39:
I tested with both KernelEx 4.5.2 (regular) and with Core Updates. Same behavior.
I'm gonna try 10.70 now
Edit: No luck too.
Secure connection: fatal error (70) from server.
Handshake failed because the server does not want to accept the enabled SSL/TLS protocol versions.
JOBS, Steve.
Reply 90 of 294, by DosFreak
Opera
I just meant for testing if the OS BSOD not for connecting to vogons. Those old versions of Opera have outdated ciphers. Only way to update would be to download the leaked source code and add the ciphers. It's kind of amazing that hasn't been done yet.
Firefox
For download speed you can try these tweaks: https://www.techwalla.com/articles/how-to-inc … peed-in-firefox
On testing retrozilla on Windows 10 I went from 1300 KB/sec to 2000 KB/sec with steps 4 and 5.
If confirmed then may be worth mentioning to roytam to enable by default or include in a Readme.
https://developer.mozilla.org/en-US/docs/Mozi … ing_preferences
Reply 91 of 294, by roytam1
got some free time to test on NT 3.50, every mozilla build are not working. early builds which use MSVC5 to compile has no unresolved APIs but system freezes upon running apprunner.
Reply 92 of 294, by Tommaso72
I unfortunately didn't have time to read the whole thread, but just from my experience lately I have a retro system with Windows XP SP2 and use FireFox, not sure the version, but I believe it is the newest one available for WinXP. I have no problems with any sites. YouTube works flawlessly, even if I can only watch up to 480 quality without any skips, but I have a 3.06 Ghz Northwood and a Geforce 6800 TX with 128 megs video Ram and 2 gigs DDR1, but also worked just as well with 512 megs DDR1. I find it amazing that a 2003 computer can do anything a new system can, within reason of course, and much slower. But for what I do it works great for retro games and browsing the net/ printing manuals, even the odd movie.
One bad thing that happened lately is I believe I got a Remote Procedure Call virus because of all virus definition files being out of date, actually I don't even use virus protection. The way I combat this is on a seperate drive I have a backup made with Norton Ghost 9, so if anything happens I just restore and all is well again. I also try to stay away from sketch sites and don't collect any email from this system. Easy fix and has only happened once in about a four month period of using the internet every night. I do stay away from sketchy sites on purpose, but I love browsing with such an old system. Brings back good memories. I want to be able to do this with my Windows 95 IBM Aptiva, but not sure if its possible yet.
Just my 2 cents.
TGT
Reply 93 of 294, by Bruninho
I was thinking... how hard it could be to add some ciphers to a Netscape 9.x so it can visit Vogons?
I mean, netscape 9.0.0.6 is a Firefox version, a “few” versions (2.0.0.12 I think) behind Retrozilla. I tried adding them through about:config but no dice. I then started to think about swapping some files between Netscape and Retrozilla to see what happens. Nothing.
JOBS, Steve.
Reply 94 of 294, by roytam1
Bruninho wrote on 2020-02-20, 11:22:
replacing NSS files with retrozilla's files only enabling TLS 1.2. adding ciphersuites can't be done in this way.
Reply 95 of 294, by roytam1
but of course I can hack around it.
download: http://o.rths.ml/gpc/files1.rt/ns9-nss-update.7z
Reply 96 of 294, by Bruninho
roytam1 wrote on 2020-02-27, 10:41:
but of course I can hack around it. download: http://o.rths.ml/gpc/files1.rt/ns9-nss-update.7z […]
Jesus Christ. You’re a legend.
JOBS, Steve.
Reply 97 of 294, by Bruninho
Trying to post this from Netscape! Although it renders similar to Retrozilla (almost no CSS), it just works.Good. That will do for some great nostalgia.
JOBS, Steve.
Reply 98 of 294, by krcroft
Roy, amazing work!
Seeing Netscape Navigator, before the bloated jump to Firefox, embedded with the last 13 years of cypher progress is truly a thing of beauty.
Are you hosting your changes somewhere? I would love to build and run this on Linux.
Reply 99 of 294, by roytam1
krcroft wrote on 2020-02-28, 17:31:
Roy, amazing work!
sure.
https://github.com/roytam1/RetroZilla/commit/ … 203fb1ceb933cbf
but building on non-win32 is totally untested.
