Reply 80 of 334, by Artex
- l33t
Just a quick update..
Got the Asus PCI/I-486SP3G loaded up with RAM - all slots in use for a total of 32MB. After removing the sticker on the BIOS chip, I don't see a UV window so I'll try to flash it to the latest 1999 BIOS this evening. If it doesn't work, I'll need to burn a new a new chip and go from there. I did throw an ATI Rage PCI card in there, my CF->IDE card (directly connected to the IDE controller native to the motherboard), and the 100Mhx AMD processor and all appears well (despite the BIOS not being updated to allow write-back mode).
Going back to the ASUS VL/I-486SV2GX4 side of things, a VOGONS member has graciously burned some new EPROM chips for me and those should be arriving soon! Once the new chips are dropped in place on these boards I'll continue the benchmarking - most likely using my Intel DX4-100 in write-back mode vs the AMD alternative.
