SIS chipset? What are your experiences?
Reply 80 of 86, by ODwilly
W.x. wrote on 2021-03-06, 06:06:
So, what is latest SIS chipset, that supports Universal AGP (3.3v signaling), as far as I see, SIS 645dx is ok, but doesnt support 800 Mhz FSB and HT, and Prescott CPUs.
651 seems same as 645dx, only better integrated graphics? Also built in support for USB 2.0. What about 648fx? This supports HT for sure, 800 Mhz p4 too, but not sure if there are some boards, that supports Universtal AGP 2x,4x, so 3.3 v signaling. Because Asus P4S800 doesnt support it, only 1.5v AGP cards. Not sure, if this apply to all 648fx motherboards.
Anyway, what's last SIS chipset for P4, that can support AGP 2x 3.3v cards?
Iv got a 645 chipset that only takes 533fsb Northwood CPU's and doesnt support HT with a universal AGP Pro slot. It actually takes the 3.06ghz Northwood just without HT. So the 645dx will actually work with the same chip and HT enabled. EDIT: Apparently it's only the B stepping of the 645dx chipset that allows HT and you also need a bios with HT support after reading a couple old Overclocker's forum threads.
Reply 81 of 86, by StIwY
Talking about SiS chipset under Windows98/95 and <2000 year My experience with SiS chipset is as good as Intel / Via chipsets, never had any particular problem. And i also think that SiS chipsets from series 5xx onwards are underrated. Especially the SiS 630T / ET. Motherboards under my hands had optimized very quick boot times ( faster than more famous brands ), performance similar to other chipsets and perfectly reliable under Windows 98 and games. Latest motherboard with SiS chipset was the Asus CUSI-FX and ran perfectly fine, under stress, no driver problems......etc
Reply 82 of 86, by Many Bothans
Whoa, necropost. While on the topic, Scrap Computing revisited the SIS 540 chipset last year and had some interesting results tweaking the FSB with PC133 SDRAM.
https://youtu.be/_hemUMLIhWw
It's a shame the majority of boards with this chipset are PCChips.
Reply 83 of 86, by The Solutor
Socket 7 mobos ranged from crap to mediocre
Mobos for slotted CPUs and newer tended to be pretty good and required less "gymnastic" with AGP drivers than contemporary VIA mobos.
Albeit nobody cared at the time, they run fresher than other chipsets from Intel/VIA and others.
Reply 84 of 86, by MikeSG
The SIS 85C406/411/431 is the only universal baby-AT EISA motherboard for socket 3 (486). Very fast when I tested it.
Reply 85 of 86, by mixal11
I had several boards for PII/PIII - and really liked ECS P6S5AT with DDR. Maybe best board for Slot1/Socket370 I had
Reply 86 of 86, by dionb
The Solutor wrote on 2026-09-12, 05:37:
That's two different things: how the chipsets ran/performed and the quality of the motherboards they were used on.
I agree with SiS chipsets being generally trouble-free; the only chipset issue I commonly saw was a driver issue with the SiS900 10/100Mb Ethernet controller in combination with Windows XP: Windows XP had a built-in driver for this NIC that offered basic functionality (so users rarely saw the need to install an updated one) but had a bug around the MAC address: the driver read out the wrong, non-unique, location so all systems with SiS900 NIC and WinXP default driver reported the same MAC address. This caused huge fun on LANs and on early ISP networks where people still directly hooked up PCs without a router.
As for the motherboards though... there was some awful crap out there. Few tier 1 retail manufacturers made boards with SiS chipsets, although Asus gets an honourable mention for consistently making 'high end' boards with SiS chipsets from So7 up to at least P4. They just never marketed them... what you did see were either OEM solutions (the OEMs loved SiS' low-end intgrated VGA solutions) which were stable but feature-poor and of course all the PC Chips/Amptron/Etrontech/ECS mess out there. Occasionally they produced really good boards like the K7S5A (fastest and cheapest Athlon board on the planet on relase) and P6S5AT (arguably best all-round So370 board), although even there, early BIOS had horrible bugs (floppy data corruption on K7S5A vs BIOS updates...) and build quality was paper thin. And for every board like that there were many more that were just crap.
Later Asrock upped the ante a bit, with late SoA and So478/775 boards with good SiS chipset implementations, clearly riffing off the success of ECS' K7S5A - I mean the best-selling Asrock SoA board was called the K7S8X 😉
