NTVDM on windows 10 x64
Reply 81 of 89, by superfury
xcomcmdr wrote on 2022-10-15, 20:07:
superfury wrote on 2022-10-15, 09:46:
It was20 years ago, at least. How is that "not too distant" ?
If you look at the "examples by microsoft" part of the article, I see:
- 2007 mentioned.
- Enforcing MAPI that's proprietary (2020).
- WSL2 is mentioned (which still probably performs EEE through it's DirectX components afaik today).
And DirectX is definitely proprietary (confirmed by looking at https://mspoweruser.com/microsoft-ports-direc … tes-wsl-kernel/ , which clearly requires Windows to run). So that's the second E of EEE right there.
UniPCemu Git repository
Reply 82 of 89, by xcomcmdr
WSL2 uses a real Linux kernel and HyperV, no relation to DirectX...
Reply 83 of 89, by Falcosoft
xcomcmdr wrote on 2022-10-16, 13:28:
https://devblogs.microsoft.com/directx/directx-heart-linux/
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 84 of 89, by xcomcmdr
Still nothing to do with EEE, since Linux is entirely distributed and open-source...
Reply 85 of 89, by superfury
xcomcmdr wrote on 2022-10-16, 14:15:
Well, D3D isn't. It provides the .so which links back to the Windows (closed-source) OS.
Is that even allowed with Linux licenses (GPLv2)? Or does that fall into the binary -blob-that-needs-to-be-updated-for-every -linux-kernel-release category that's allowed (and will break when updating kernels)?
That's pretty clearly already the second E(extend) of EEE.
Reply 86 of 89, by xcomcmdr
It's allowed by the GPLv2, just like the blob for the nvidia linux kernel driver...
It also won't extend anything, it's not like you can use that on native Linux...
Reply 87 of 89, by jlnhlfan
Thanks. But once I do that, I then have to go through Windows Defender scanning it, finding a "virus", and swiftly disposing of the program.
Reply 88 of 89, by leecher
Then open windows defender, chose to restore the files from quarantine and add to the exclution list. so that it leaves it alone.
Alternatively, disable Windows defender during download, unpack .zip file and add unpack directory to the exclusion list before reenabling Windows Defender.
The installer script then tries to add the loaders to the exclusion list itself, but first, it's mandatory that the files remain in place, so that they can be installed, of course.
Microsoft is notorious for not even add the loader to their false positive list, when they are requested to do so and I cannot write them everytime I make a loader update. So nothing I can do about the false positive detection of crappy AV-programs.
Reply 89 of 89, by TechieDude
xcomcmdr wrote on 2022-10-16, 15:29:
First off, my apologies for not replying to you earlier, I totally missed your reply.
Second, that's precisely the point. You can only use it on WSL2, hence the EEE claim.
